Quantcast Oversize Tire on Stock Rear Tire Carrier? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Oversize Tire on Stock Rear Tire Carrier?
Truck-Lite's New LED Headlamp SeriesNEW! Poison Spyder RockBrawler BFH Bumpers!Poison Spyder BFH Rear Bumpers
Old 06-27-2007, 11:52 AM   #1
VirginiaCountry
Will a 31 X 10.5 X 15 inch tire on a stock Canyon wheel (15 X 8 inch) fit on the stock rear tire carrier of a 2003 TJ without modifications? I have a P235/75R15 on there now on a stock Jeep steel wheel and there appears to be enough room top and bottom but it may be close. Also, the Canyon wheel is wider than the steel wheel. Will that require any modification?
Thanks!
John
VirginiaCountry is offline   Reply With Quote
Old 06-27-2007, 11:56 AM   #2
Chris_
You can modify it to fit just about any size tire. What I would be more concerned with is the weight of the tire and wheel, more so than the size of the wheel and tire.
I don't see why it wouldn't fit.
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline   Reply With Quote
Old 06-27-2007, 11:58 AM   #3
tcox
i have my 33x1250 on my stock tire carrier. all i did was remove the 3rd brake light, remove the bumpstops, and add some spacers to the bottom lug to move the bottom of the tire out so it didnt hit the bumper. before that i had a 31x1050 on the stock spare rim on the rear with only the bumpstops removed
stuff
tcox is offline   Reply With Quote
Old 06-27-2007, 12:52 PM   #4
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Yes.
TheBoogieman is offline   Reply With Quote
Old 06-27-2007, 01:13 PM   #5
luk4mud
A 31 will be just fine. It's when you get to the 33's that things start to get a little hairy on the stock carrier.
Originally Posted by Divinitous
I did something like this a while back for my corolla. I poked a hole into the ducting and ran a hose to stick into my shorts. It didnt work thew best cause I never plugged up the vents, but it did help.
luk4mud is offline   Reply With Quote
Old 06-27-2007, 01:44 PM   #6
jmreagan
A 31 is what the rubicon's come stock with and I don't see any difference than their stock carrier is with any other TJ. You should be fine. Just make sure the tire is tightened firmly against the rubber stops so it doesn't rattle.
03' Sport, 4.0L, 3.73, 5 speed, D44/D30, 3 inch coil/shock lift, RE track bar, Tera disco's, 35x12.50's Dunlap Mud Rovers MT's, Spidertrax spacers, Viper 5000 alarm, Tuffy console, LOD extreme bumper/tire carrier and front bumper, A-Z rockers, AA SYE, Tom Woods DS, JKS Rear UCA's.
Originally Posted by KKiowaTJ
Sorry master, Dont whips me, I's do betta next time..
jmreagan is offline   Reply With Quote
Old 06-27-2007, 01:44 PM   #7
KUK9
Pockets Officially Empty
KUK9's Avatar
I had a 33x12.50x15 on mine for a few years before I finally bought a swing-away rear bumper. With the offset of the wheel, it fit fine, but it would rub a bit on the rear bumper. A 31 will be just fine.
2000 Jeep Wrangler Sport
4.0L 5sp 4" Pro Crap lift, 1.25" JKS BL, 1" Brown Dog MML, 35 Maxxis Bighorns, Lock-Right up front & Detroit out back, Super 35, Jeeperman front bumper, Warn XD9000i, Raingler nets, homemade discos, Poison Spyder cage.....In the middle of a re-birth!
Yellow Jeep Club Member #66
Colorado Jeep Club Member #66
KUK9's 00 TJ Stretch Build
KUK9 is offline   Reply With Quote
Old 06-27-2007, 02:00 PM   #8
SecondTJ
Yes it will fit...
http://pg.photos.yahoo.com/ph/thamole187/detail?.dir=64e0re2&.dnm=8f66re2.jpg&.src=ph
http://pg.photos.yahoo.com/ph/thamole187/detail?.dir=64e0re2&.dnm=6885re2.jpg&.src=ph
I needed a couple of washers under the 3rd brake light. Otherwise fits fine.
'00 Sport. 5-speed, Detroit TrueTrac Dana 44 rear, Detroit TrueTrac front, 4.10's, 2" RE BB, OME shocks, 31" BFG MT, JKS Quicker Disco's, Borla, Chicago Electric 10k winch
'99 Z28 M6, some goodies
'94 'Vette, A4 all stock
SecondTJ is offline   Reply With Quote
Old 06-27-2007, 02:32 PM   #9
BYuen
Wahoowa
BYuen's Avatar
I fit 33s on my stock one... I soon bought an extended heavy duty tire carrier though since I don't have the cash for a rear bumper and swing away carrier.
White 01 TJ Sport 4.0 NV3550
BYuen is offline   Reply With Quote
Old 06-27-2007, 04:19 PM   #10
VirginiaCountry
Oversize tire on stock tire carrier
Thanks to all who responded...time to get the checkbook out!
Thanks!
John
Old 10-09-2009, 02:40 PM   #11
LURCH634
I see everything that says 33 max on stock tire carrier, but it may hurt the tailgate. Well I have a 32" tire on my stock wheel. Should the oem tire carrier be no problem to use?
[I][SIZE="4"][FONT="Impact"][COLOR="Red"]SAVE YOURSELF, THEN THE WORLD[/COLOR][/FONT][/SIZE][/I]
[URL="http://www.jeepforum.com/forum/f22/lurch634s-first-jeep-build-journal-870248/"]TJ BUILD[/URL]
[QUOTE=2003X;8181034]come on, less talky talky more pictures, Lurch you have ne more?? You own this thread at the moment lol[/QUOTE]
LURCH634 is offline   Reply With Quote
Glock Forum
