Overkill SKinz - JeepForum.com
post #1 of 7 Old 08-29-2010, 03:55 AM Thread Starter
kuruma
Overkill SKinz
Anybody using any of these products? These things look bad to the bone but not much information I can find on them. Post pics or reviews please if you are using them.
kuruma is offline
post #2 of 7 Old 08-29-2010, 09:05 AM
robncar
robncar's Avatar
3/16 steel?
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #3 of 7 Old 08-29-2010, 09:19 AM
QuickSilverCon
sounds like they would be a PITA to install, why not just use a separate set of corners and rockers? What's the advantage to having it be one piece?
Originally Posted by timberwolf0122 View Post
I think you are confusing the right to free speech with the right to be a **** bag, only one is protected by the constitution.
QuickSilverCon is offline
post #4 of 7 Old 08-29-2010, 02:52 PM Thread Starter
kuruma
I'd like to know that as well.I can see it both ways. 1) shocks would transfer energy throughout the entire area which would dissipate it better. 2) different parts would probably allow the body to slightly "move" better in flexing situations. Not that twisting the body is good but I can see how allowing it to move slightly would be a bit better for the Jeep. Not so stiff.
kuruma is offline
post #5 of 7 Old 08-29-2010, 04:14 PM
Dogman
Dogman's Avatar
Personally I would go for aluminum (Savvy) for the weight savings.
John 3:17
Dogman is offline
post #6 of 7 Old 08-29-2010, 05:16 PM
robncar
robncar's Avatar
Yep, I'm with ya...
robncar is offline
post #7 of 7 Old 08-29-2010, 06:16 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
IF there was an advantage and that's a bit of a stretch, it would be overcome fairly rapidly by poor material usage on the laser table, installation difficulty, higher material costs if you scrap one and we all do on the manufacturing side, higher shipping costs, and the real big one, I have yet to see two TJ's with the same relationship between the top of the tub and the top of the door sill.
Plus, if you damage a rocker, now you get to replace both.
As time goes by and the TJ gets older and older, you will see more of this. Folks do stuff just to be different and not because it's a good idea.
As far as I'm concerned, no set of corners should ever be cut around the tailgate hinges, just simply no need for something that NEVER fits correctly.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
Overkill Engineering Skinz jeeper91 TJ Wrangler Technical Forum 3 03-26-2010 04:15 PM
4.56 or 4.88 (sorry if this is overkill) sdlemaster TJ Wrangler Technical Forum 20 10-08-2007 09:59 AM
Is 500+ hp overkill? mikeyz3385 TJ Wrangler Technical Forum 46 10-27-2006 04:53 PM
Skinz Soft Tops ? Tops that rest on roll bar ? tire_smoke YJ Wrangler Technical Forum 2 06-30-2002 02:45 AM
Skinz soft tops and soft top fit? tire_smoke YJ Wrangler Technical Forum 2 06-25-2002 01:16 PM
