overheating, only at 55+mph ...? - JeepForum.com
post #1 of 8 Old 09-18-2007, 10:04 PM Thread Starter
TXjeepTJ
TXjeepTJ's Avatar
soo, ive never had cooling issues before. i have an after market radiator to make up for the engine size(recommended) and had a ford escort electric fan/shroud. well last week the ford electric fan starts giving out, soo i took out the assembly and cut out the ford fan and put a high performance electric fan in its place (basicly its exactly how it was before, just a better fan). i had to drain the radiotor in order to get the fan out also i should add.
well i added fluid to the radiator, started the engine and once the thermostat opened i topped off the radiator. then added the 'overflow' can to full. it runs very cool at idle, but once i get on the high way it starts over heating by more than 20 degrees. once i slow down(get off the highway) it goes back to normal
any help would be awesome
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #2 of 8 Old 09-18-2007, 11:37 PM
Dragon158
I ran into the same issue with my brothers Ford pick up a few years back. In his case it turned out to be a clogged radiator. I know you said that you replace yours with after maket, but how many cores do you have? Maybe not enough?
Maybe even something as goofy as an air bubble in the coolant system?
Dragon158 is offline
post #3 of 8 Old 09-19-2007, 12:03 AM
rayar3
If Jeeps could fly...
rayar3's Avatar
We had that problem when we realized that there wasn't a thermostat in a rover a buddy bought a few weeks ago! So much coolant was going through that it didn't have the time to cool down. It was fine around town, and overheated on the highway. It might be that your thermostat has a problem with it.
2000 XJ 2-door (current)
2006 65th Anniversary TJ (sold)
rayar3 is offline
post #4 of 8 Old 09-19-2007, 12:24 AM Thread Starter
TXjeepTJ
TXjeepTJ's Avatar
it has 3 cores, it shouldnt be clogged- its brand new installed a couple weeks ago, i've been running only water in it up until just now- i did a 25%anti-freeze
i had no problems at all with it the past 2 weeks, its almost like i didnt add coolant right or something
the water pump has a thermostat in it soo that knocks that prob. out lol i replaced the water pump about 3 weeks ago
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #5 of 8 Old 09-19-2007, 05:21 AM
BlackJeephunter
Do you have a which or anything in front of the radiator?
Palmetto Tree Stickered Black Jeep Owners Club, Hunting Chapter Member #1110010
BlackJeephunter is offline
post #6 of 8 Old 09-19-2007, 07:31 AM
cj847
Congrats on the V8 swap, that's great.
On the cooling it's a wild guess due all the modifications. First thing I would do is as it overheats turn the heater on hot and high. If this cools it down, it shows you don't have enough cooling capacity. (I don't know if an even bigger radiator is available).
Other wild guesses on my part:
-Is the fan working properly? At highway speed it may actually be in the way and hurting air flow. I would think it should be freewheeling at 55. If it is actually running, it could slow down the air.
-Kinked hose not allowing enough flow?
Good luck
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part.
cj847 is offline
post #7 of 8 Old 09-19-2007, 07:38 AM
Erin Go Bragh
Erin Go Bragh's Avatar
That coolant mix should be 50\50 antifreeze and water. That would increase the boiling point higher than the 25 percent mix you have in there.
"Some days I feel about as sharp as a butter knife."
"It's not the years, it's the mileage. "
"Common sense will take a person far in life, problem is, common sense just isn't very common anymore."
Erin Go Bragh is offline
post #8 of 8 Old 09-19-2007, 08:55 AM
elfman69
you might be collapsing you radiator hoses
97 tj 2.5l fresh rebuild running great, 3 angle valve grind on the head, bored .030 over, new crank, head milled down, running strong
soft top, 31x10.5
2" coil spring boost in front and in back
new set of 31x10.50x15" (street tread! daily driver)
elfman69 is offline
overheating? attackcammel TJ Wrangler Technical Forum 7 07-04-2010 12:58 PM
overheating? Mudzilla6661 Wrangler General Discussion 8 08-15-2009 09:33 PM
overheating 87 danthman YJ Wrangler Technical Forum 6 03-05-2009 07:44 AM
overheating once again... sandman'sjeep YJ Wrangler Technical Forum 25 03-20-2006 04:47 PM
Overheating Kel Dub TJ Wrangler Technical Forum 7 01-21-2006 03:25 PM
