Overheating... I think? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Overheating... I think?
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectSave on Warn Winches and TENOFF Promotion!
Unread 02-09-2015, 04:12 PM   #1
YJheretostay
Hey everyone,
So I stopped at a 7/11 today, and upon getting out of my TJ I smelled the worrisome smell of boiling coolant. I sniffed again and decided I was imagining things, but upon exiting the 7/11 I noticed that there was smoke coming from under the hood. I popped the hood and looked and I saw that there was coolant everywhere (I'm guessing it got flung around by my serpantine belt). I had to get to class, but I carefully monitored my engine temp the whole way to school and now I'm even more confused! When I got in, the temp was slightly higher than 210 but not in the red, and I drove for a bit and it stayed right where it was. Then, I turned on the heat in an attempt to cool it down and it went down to 210 where it usually is. It even went below 210 for a bit on the short drive. When I got to school I popped the hood again and there was way more coolant everywhere. My question is, where are some common places that coolant leaks happen? Thanks for reading this wall of text
YJheretostay is offline   Reply With Quote Quick reply to this message
Unread 02-09-2015, 04:22 PM   #2
freeskier93
Is the radiator original? Probably leaking out of the tank crimps and spraying everywhere.
Build Thread
My life in 2010: Chronicles of painting my Jeep
Axle Re Gear and Swap
CU Boulder Aerospace Engineering
freeskier93 is offline   Reply With Quote Quick reply to this message
Unread 02-09-2015, 04:29 PM   #3
YJheretostay
It's actually less than a year old, I replaced it last summer and it has been in good shape up until today!
Unread 02-09-2015, 04:36 PM   #4
freeskier93
What brand/type is the replacement?
Build Thread
Unread 02-09-2015, 04:41 PM   #5
YJheretostay
I'll have to look after class. I got it from Advance Auto Parts though.
Unread 02-09-2015, 04:42 PM   #6
JWebber
Let the engine cool down, fill the rad with more fluid (or water for now) Rent a rad pressure tester kit from your local parts store etc.. Then you will find your leak! But before you do this clean off all anti freeze from under the hood and areas. Unless you know where its leaking?
JWebber is offline   Reply With Quote Quick reply to this message
Unread 02-09-2015, 04:44 PM   #7
YJheretostay
Well the weird thing is, my coolant reservoir is still at the full line! I'm hoping that the radiator isn't failing to pull extra coolant from it.
Unread 02-09-2015, 06:53 PM   #8
chris142
It can leak from the Rad, Hose, Clamps, Water pump etc. If theres a sizable leak the cap wont let it pull from the bottle. When the engine cools it forms a vacuum to pull from the bottle.
Leak= No vacuum. You really need to remove the cap and look in the radiator and look at the rubber seals on the cap too. those go bad and it wont hold pressure or vacuum as designed.
chris142 is offline   Reply With Quote Quick reply to this message
