overheating, HELP! - JeepForum.com
post #1 of 6 Old 09-01-2006, 07:39 PM Thread Starter
chrisvr6
overheating, HELP!
I changed the thermostat, flushed the system and it's still slightly overheating in idle. Once I rev it in park and turn on the A/C it goes all the way to the red. Can someone give me an idea whats happening!
chrisvr6 is offline
post #2 of 6 Old 09-01-2006, 07:46 PM
FL 4.0L
Year, engine, history of water pump and radiator? Losing any fluid?
FL 4.0L is offline
post #3 of 6 Old 09-01-2006, 07:53 PM Thread Starter
chrisvr6
99', not losing any coolant, factory water pump, and the second radiator. This happened last week while offroading on a super hot and muggy day. Now its acting up again!
chrisvr6 is offline
post #4 of 6 Old 09-01-2006, 07:58 PM
wcurleyq
Check the radiator cap to make sure it is holding the correct pressure. Make sure you put the correct rated temp thermostat in. Most likely a 195 deg. If it is a 4 banger, make sure the electric fan is comming on. Also check the clutch fan.
wcurleyq is offline
post #5 of 6 Old 09-01-2006, 07:59 PM
opticalwaveguy
opticalwaveguy's Avatar
What and how did you flush it?
What type of thermostat?
How's the engine been running?
What's the last several things you did to your Jeep?
(I find this is a good place to start looking)
OpticalWaveGuy
- an online resource for Jeep information
Proud To Be A FF/EMT/Police/Military Club Member #2
opticalwaveguy is offline
post #6 of 6 Old 09-01-2006, 11:11 PM
fish4life
observe overflow bottle and see how much the water raises from when the engine is cool to when the engine is running hot.
if it raises by like half a bottle then your cap is not holding pressure in.
Touch the top and bottom hoses .... is one of them hot and the other cold when the engine is running hot ???
fish4life is offline
overheating? attackcammel TJ Wrangler Technical Forum 7 07-04-2010 11:58 AM
overheating? Mudzilla6661 Wrangler General Discussion 8 08-15-2009 08:33 PM
overheating 87 danthman YJ Wrangler Technical Forum 6 03-05-2009 06:44 AM
overheating, only at 55+mph ...? TXjeepTJ TJ Wrangler Technical Forum 7 09-19-2007 07:55 AM
Overheating Kel Dub TJ Wrangler Technical Forum 7 01-21-2006 02:25 PM
