overheating? - JeepForum.com
post #1 of 8 Old 07-28-2009, 12:53 PM Thread Starter
attackcammel
overheating?
hey guys lately when i park my jeep after driving ive been hearing coolant being sucked out of the overflow bottle. i dont beleave it suppose to be in there unless im over heating am i right? im not amazing at cars and knowing how they work but i dont beleave this is supposed to happen.
what do you guys think?
Anthony
Originally Posted by Hilldweller View Post
Ordinary cars lie to you. They tell you that everything is controlled, warm, safe, smooth ---- we know this is a general falsehood. There is extreme beauty in the world and the best way to find it is to be out in it --- all the way. In a Jeep. Cause you can't get there in a Camry.
attackcammel is offline
post #2 of 8 Old 07-28-2009, 01:25 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
What's the temp reading?If it reads 210,it's not overheating.How can you HEAR it being sucked OUT and not IN?When it's hot,that's where it goes.They make noises after being stopped.It's normal.
TheBoogieman is offline
post #3 of 8 Old 07-28-2009, 01:31 PM
djfuzzy
I'm having the same problem, sounds like someone slurping on a drink when I get done driving. Also, there is a nice aroma of coolant.
USMC 2006-Present
2000 TJ - some stuff
djfuzzy is offline
post #4 of 8 Old 07-28-2009, 01:58 PM Thread Starter
attackcammel
after i shut off the jeep and i walk past the front of it going inside i hear like a slurping like djfuzzy said i opened up the hood and i saw coolant being sucked back into the engine from the overflow.
im thinking maybe theres too much coolant in the engine but then wouldnt it not get sucked back in ?
idk im confused
post #5 of 8 Old 07-04-2010, 10:44 AM
04tjrubi7777
I have the same problem!
I have an 04 rubicon with 33s and it sees a lot of highway use and during the summer it always runs 210 or 215 and i already replaced the fan clutch and the thermostat and had the radiator flushed and it still does it! If i run it without the t-stat it runs about 195 or 200. Is this normal and should i be worried? Could my water pump be going out? Any help would be greatly appreciated.
04tjrubi7777 is offline
post #6 of 8 Old 07-04-2010, 10:55 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
200° is fine. coolant expands when its hot, so thats why its moving in and out of the coolant bottle. its supposed to do that....unless you've got a coolant leak and you're having to add coolant...thats different.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #7 of 8 Old 07-04-2010, 11:35 AM
duanewhatley
I had a hairline crack in my radiator, caused the coolant smell, resevoir to be emptied out. It was so small that I coulndt find the leak.
duanewhatley is offline
post #8 of 8 Old 07-04-2010, 11:58 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
When you first shut the engine off, it's no longer being cooled. The over flow tank will fill more. As the cooling system cools down, the fluid is sucked back into the system...
Knuckelhead is offline
overheating? Mudzilla6661 Wrangler General Discussion 8 08-15-2009 08:33 PM
overheating 87 danthman YJ Wrangler Technical Forum 6 03-05-2009 06:44 AM
overheating, only at 55+mph ...? TXjeepTJ TJ Wrangler Technical Forum 7 09-19-2007 07:55 AM
overheating once again... sandman'sjeep YJ Wrangler Technical Forum 25 03-20-2006 03:47 PM
Overheating Kel Dub TJ Wrangler Technical Forum 7 01-21-2006 02:25 PM
