Quantcast OverDrive Button - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > OverDrive Button
TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-RoadGenuine Italian leather shift boots for your Jeep!
Old 07-19-2008, 10:10 PM   #1
12six
OverDrive Button
Hi all, I have searched with no available answer. I have a 04 Wrangler Sport that has 33" tires, that has not been regeard. I have an "Overdrive button" that I would use to get more power. When in use, the rpm is much higher, but it is also in the range where as if I were to regear it. My question is, could I damage anything driving with the "overdrive" all the time? Also, could I use the "overdrive" and eliminate the need to regear?
Thanks in advance
Charly
12six is offline   Reply With Quote
Old 07-19-2008, 10:36 PM   #2
ranger140892
I think you're confusing the button's use. Pressing the button turns the overdrive off, not on. Turning it off doesn't give you more power.
As for using it instead of regearing: Overdrive doesn't change axle gear ratio. It's effectively just another gear. Turning it off will not give you a lower axle gear ratio to accomodate larger tires if that's what you're getting at.
ranger140892 is offline   Reply With Quote
Old 07-19-2008, 10:37 PM   #3
Libtekguy
I've read your post about three times now. I think you are under the impression that the Overdrive button is some kind of supercharger. Overdrive is another name for 4th gear. When you push that button, it just keeps your Jeep from shifting into 4th gear. Which help when pulling a trailer or going up hills.
2003 Jeep Wrangler Sahara: RE 4.5" LA, FOX 2.0 Shocks, 35" BFGoodrich KM2s
2002 Jeep Grand Cherokee Overland: 2" BB. 31.5" BFGoodrich All Terrains
I am looking to get a set of RE 5.5" front coils. I'll trade my 4.5" or pay (not too much though) for them. Send me a PM.
Libtekguy is offline   Reply With Quote
Old 07-19-2008, 10:41 PM   #4
bubbaj27
Libtekguy, SWEET avatar!
[B][FONT="Arial Black"][COLOR="Navy"]Get busy livin' or get busy dyin'.[/COLOR][/FONT][/B]
bubbaj27 is offline   Reply With Quote
Old 07-19-2008, 10:50 PM   #5
Libtekguy
Thanks man!
Old 07-19-2008, 10:54 PM   #6
ranger140892
Originally Posted by Libtekguy View Post
Thanks man!
I like it too. May have to do that with one of my hooah pics.
Glock Forum
