Quantcast Over Sized Tire Swing Carrier Question..... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Over Sized Tire Swing Carrier Question.....
Spartan Lockers FREE SHIPPING Excellent PricesDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ
Old 05-03-2006, 11:30 PM   #1
colbyB25
I have the basic Warn Rock front and rear rock bumper. But of course my spare 33' Tire is just a problem waiting to happen on my tail gate. Any ideas to convert my already solid and tested bumper without having to pull it off, sell it and get the over sized tire swing version?
Colby
03' Red Rubicon • 33' X-Terrains w/ Cragar black 352d wheels • 3.5 Skyjacker • JKS 1.25 BL w/ 1' JKS BMML • .75 front coil spacers • Herculined Tub • Warn Rock Front and Rear Bumbers • Warn 9.5ti Winch • Custom Sound System • Tuffy Center and Over Head Console (w/ CB) • Rear Diamond Plate Corner Panels w/ Euro Tail Light Guards
colbyB25 is offline   Reply With Quote
Old 05-04-2006, 07:10 AM   #2
colbyB25
any ideas?
Old 05-04-2006, 07:14 AM   #3
tjmaximus
NeverEndingWorkInProgress
tjmaximus's Avatar
isn't your Warn rear bumper already drilled to accept the optional tire carrier? I maybe wrong buy I think they are.
White Jeep Club #44
98 TJ Sport
see profile for mods.
tjmaximus is offline   Reply With Quote
Old 05-04-2006, 07:53 AM   #4
erickpl
Nope. They aren't. You CAN order one I believe that will have the spindle already done, but you have to basically custom order it. Jeeperman will do this as well.
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline   Reply With Quote
Old 05-04-2006, 08:15 AM   #5
KaiserJeep
.....or you can order the Bestop Tire Carrier which is OK for up to a 35" tire, and does not require swinging the tire away to get the tailgate open. At $270 it is a reasonable buy as well, and has recently been re-designed for compatibility with body lifts.
If your Warn bumper has a 2" receiver, you could still use receiver-mounted accessories.
Gary
1967 Kaiser Commando
2001 Grand Cherokee WJ
2003 Wrangler Rubicon TJ
KaiserJeep is offline   Reply With Quote
Old 05-04-2006, 08:30 AM   #6
RandyNeagle
Coincidentally, I have the same bumper setup that you do and I had the same concern. After looking at a lot of options and putting in A LOT of design time, I just finished retrofitting mine to accept a tire carrier. It looks exactly like the carrier that WARN offers, except I used a De-Sta-Co latch instead of WARN’s design. This thing is really solid and doesn’t even think about rattling.
I will tell you that it took a fair amount of design and a bunch of welding, but it was a great feeling to be able to get this project done without having to buy a whole new setup. I got really lucky with materials and I have access to welders, but 99% of the labor was my own.
I’ll be happy to give you some advice along the way if you’re going to do it, but some of the best advice I can offer is to look at BESRK’s write-up in the Fabshop of this forum. This is where I started when I was doing research. It gives great details of how the thing will be put together and what I could expect. If you can manage what’s done in this write-up, and you have some time to think about the design, then you should be fine.
I hope this helps. Good Luck.
Randy
2000 TJ Sport
Upgrades by Currie, Rubicon Express, Rancho, Advance Adapters, Tom Woods, Warn, K&N, Precision Gear, ARB, BF Goodrich
RandyNeagle is offline   Reply With Quote
Old 05-04-2006, 08:51 AM   #7
DirtHerder
When did they re-design it?
DirtHerder is offline   Reply With Quote
Glock Forum
