Outboarding rear shocks AND upper spring bucket relocation - Page 5 - JeepForum.com
post #61 of 607 Old 12-21-2009, 11:33 AM
Robert J. yates
Originally Posted by Alexia View Post
Cutting the frame to weld in the new towers, how does that affect the structural integrity? I doubt it would cause issues for the main suspension since it is behind that area. Would it cause issues for towing? What about getting hit from the rear?
I tow a 1700lb off road trailer quite regularly with my set up which Blaine and I did probably back in late 2001 or early 2002. No issues here.
Robert J. yates is offline
post #62 of 607 Old 12-21-2009, 05:07 PM Thread Starter
Humboldt
Humboldt's Avatar
Originally Posted by mountaineerjp View Post
Do you have any pics of the lower mounts? I am collecting parts and about ready to dive into this project, but I am still a little uncertain as to how to approach the lower mounts/shock stud. Maybe put together a parts list for people?
Stu-offroad has a really thorough write up for the actual shock outboarding with a parts list.
There really was no parts list for the relocation of the upper spring bucket. Grind the welds for the stock one off, cut the tabs to fit and weld it back on where you need it. Just make sure both sides are exactly the same.
As far as my plan for outboarding the shocks, Ill be making lower mounts by first cutting a piece of 3/16" flat stock and boxing in the rear of the lower control arm mounts. This will strengthen the control arm mount and give me something to weld a 3/16" mount to that will hold the shock stud at the same angle as my lower control arms at ride height (17* in my case.) and just far enough back that the shock wont get into the axle at full droop. I will use a piece of 2" X 4" rectangle tube cut into the shape I need to make these. There are SO many ways you can do the lower mounts, it's really only limited by your imagination and skill level with a cutoff wheel. I chose one that makes sense for my setup.
With the lower mount in place, Ill be able to bolt the shock on and begin taking measurements for the upper mount. The plan is to use 90* from the angle of the lower control arm at ride height.
Like most things I do, I'll measure 20 times and get a bunch of pictures
Humboldt is offline
post #63 of 607 Old 12-21-2009, 05:43 PM
wushaw
Rockin jeep
wushaw's Avatar
When I invented this modification, I did it first to move the very vulnerable lower shock mounts up out of the rocks. If you move the bottom of a shock up and keep the same OA length and travel, the top has to move up as well.
In the OEM location, there's no room to move up and with most normal backspacing on the rims, there's no room to fit a shock between the frame and tire. That means clearance has to be made somewhere.
The other two benefits are the ability to fit a longer shock in there for more travel and surprisingly, it improves the ride and handling a fair bit as well as well as practically eliminating that annoying back and forth TJ jiggle you get crossing driveways at angles when you pull into parking lots.
Since you invented this mod why don't you do a sticky or whatever it is and lay out the skinny on how why and what for, list of parts, etc...
Instead of getting this info from others that have followed an obvious great idea/mod for a TJ. Take credit where credit is due.
Pictures would help for the obvious reasons.
wushaw is offline
post #64 of 607 Old 12-21-2009, 06:01 PM Thread Starter
Humboldt
Humboldt's Avatar
Stu did on his site when they first did it on his:
http://www.stu-offroad.com/suspensio...earshock-1.htm
I hope no one has the impression that I am saying I had anything to do with inventing this. My whole goal is really just to document a fun project I decided to do, throw some suspension options out there for people to see, and grab some pictures of specific stuff I wanted to see while researching.
Humboldt is offline
post #65 of 607 Old 12-21-2009, 06:57 PM
wushaw
Rockin jeep
wushaw's Avatar
Thanks Humbolt for the link, and no I was not under the impression you were responsible for this idea. I didn't know Blaine was though, it is just nice to know who is responsible for it.
wushaw is offline
post #66 of 607 Old 12-21-2009, 07:58 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I don't have time to even finish writing instructions for the Savvy Products and if I started documenting all the stuff I've figured out how to do over the years, it would be nearly a full time job.
There are great folks like Stu who are good at this stuff and others like Joe who do great secondary write-ups from different perspectives, and who enjoy it. I don't and I'm not really that good at it.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #67 of 607 Old 12-21-2009, 10:46 PM
glockster
FMI (for my information)
What length are those lower RE arms set to?
Marco
glockster is offline
post #68 of 607 Old 12-21-2009, 11:07 PM
06WranglerX
Believe he said they were fixed length re lowers and enjoyed the length they offered. Perhaps the OP can advise what the fixed length of a re lower is.
Originally Posted by lumpster View Post
he made it clear when he said he was. He didnt ask for a photo ID of you did he.
People need to be a little more trusting, Its not like we are on a convict and rapist forum.
Upon further reflection I've decided I've had enough of this BS and you are now on my ignore list.
06 Red Wrangler X 6 speed hard top
Ford 8.8 Detroit locked, 4 inches of lift, 33 inch BFG KM2's and some other stuff.
06WranglerX is offline
post #69 of 607 Old 12-22-2009, 07:21 AM Thread Starter
Humboldt
Humboldt's Avatar
The RE Fixed length lowers are 16" eye to eye.
Humboldt is offline
post #70 of 607 Old 12-22-2009, 08:12 AM
glockster
Yup....I knew the length of the fixed RE arms. I could have sworn I saw adj arms on a posted picture last night and thus the question. They seemed to be extended out pretty far.
Since my work computer won't show pictures I'll check when I get home tonight. Maybe I'm losing my mind?
Marco
post #71 of 607 Old 12-22-2009, 08:15 AM
rondak46
the uppers are adjustable,,,
rondak46 is offline
post #72 of 607 Old 12-22-2009, 09:45 AM
glockster
thanks rondak, it suck's not seeing the pictures. I knew I saw adjustables, just didn't look close enough.
Marco
post #73 of 607 Old 12-22-2009, 10:05 AM
mdm
Farm Wheeler
One of my jobs in the Army was aircraft tech manual development/writing. When you start documenting the step by step procedures, material and tool requirements, photos/drawings,... it is truly a daunting task even for what can appear to be a simple procedure. It's not something I want to do again unless someone is paying me for it. My hat is off to those that take the time and energy to provide the tech write-ups for us on this and other forums. We all owe them a huge thanks!
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #74 of 607 Old 12-22-2009, 10:15 AM
Stu Olson
Stu Olson's Avatar
Blaine,
Thanks for the kind words.
Please keep doing exactly what you are doing. Your talents, trapped behind a keyboard, would be a HUGE waste and a substantial setback to everyone else in the TJ community.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #75 of 607 Old 12-22-2009, 08:52 PM
J03_TJ
Can anyone tell me if a 110v Mig with flux core would be good enough to re-mount the upper spring mount. Was thinking at a minimum it could be used to tack weld the thing in place and a street drive over to a friends house with a 220v machine?? Not sure if the pad gets that much side loading/stress, just shoved against. Anyone?
J03_TJ is offline
SUA YJs- Outboarding rear shocks….Worth it? supersteez YJ Wrangler Technical Forum 32 02-08-2011 08:18 PM
Stock rear spring mount relocation? Mute9937 TJ Wrangler Technical Forum 4 12-28-2009 04:19 PM
Do I need to change this?...FAST? (Rear tire close to upper coil bucket) SWATmedic TJ Wrangler Technical Forum 35 04-23-2009 09:30 AM
rear upper shock relocation brackets? willyb8 YJ Wrangler Technical Forum 2 03-02-2009 02:41 PM
Outboarding rear shocks TSEJEEPERS YJ Wrangler Technical Forum 8 02-02-2009 03:34 PM
