Outboarding rear shocks AND upper spring bucket relocation - Page 4 - JeepForum.com
post #46 of 607 Old 12-20-2009, 09:12 PM Thread Starter
Humboldt
Humboldt's Avatar
Originally Posted by provelogear View Post
Joe,
You going to have that done so you can come out at the end of the year?
Hope you can make it.
Gerald
Definately.
Humboldt is offline
post #47 of 607 Old 12-20-2009, 11:06 PM
Apex
Recon death squad
Apex's Avatar
So the ford shock towers are perfectly fine if you are outboarding with standard shocks?
Apex is offline
post #48 of 607 Old 12-21-2009, 07:34 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Nice work.
I'm doing this mod hopefully real soon. I have a set of Bilsteins that I'd really like to get installed, but I need to move the mounts first.
Wheelin98TJ is offline
post #49 of 607 Old 12-21-2009, 07:40 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Let me guess, you just like to look at the pictures? From post #12
He's not going to be running anything but the normal style shock bushings. If you run the Fox or similar style, then it's not worth the effort that it takes to modify the top of the Ford tower to get them to fit. With his normal shocks, he just has to drill out the holes to 1/2" and he's good to go.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #50 of 607 Old 12-21-2009, 08:10 AM
mattamd_xp
I'm in the process of doing this to my TJ right now. I'm notching my stock skid and reforming the tank to get about 3-4" of stretch. I'm doing a dual-triangulated longarm at the same time and this is perfect for keeping the stock upper mounts I actually started cutting the welds off on Saturday Morning so it looks like that was the day to start this I'm going to finish cutting the welds later this week once I get back out to my garage
99 Wrangler Project Detroit Mongrel 5.3/4l60e/Atlas HPD60/14B coilovers etc...
mattamd_xp is offline
post #51 of 607 Old 12-21-2009, 08:10 AM
Ej132
whats the advantage? Is it the ability to run longer shocks?
Ej132 is offline
post #52 of 607 Old 12-21-2009, 08:16 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
When I invented this modification, I did it first to move the very vulnerable lower shock mounts up out of the rocks. If you move the bottom of a shock up and keep the same OA length and travel, the top has to move up as well.
In the OEM location, there's no room to move up and with most normal backspacing on the rims, there's no room to fit a shock between the frame and tire. That means clearance has to be made somewhere.
The other two benefits are the ability to fit a longer shock in there for more travel and surprisingly, it improves the ride and handling a fair bit as well as well as practically eliminating that annoying back and forth TJ jiggle you get crossing driveways at angles when you pull into parking lots.
I am Savvy
mrblaine is offline
post #53 of 607 Old 12-21-2009, 08:21 AM
Ej132
ok, very interesting, thanks mrblaine
Ej132 is offline
post #54 of 607 Old 12-21-2009, 08:22 AM
Apex
Recon death squad
Apex's Avatar
Nope, I read that...I just wanted to make sure. Nothing wrong with double and triple checking. But I do like the pictures
Apex is offline
post #55 of 607 Old 12-21-2009, 08:29 AM
Dogman
Dogman's Avatar
How do you decide where the the mount is placed? I've seen this method:
Just wondering if it's the same for the Ford towers and what difference your lower mounts make as well.
Where did you buy the Ford towers and how much are they?
John 3:17
Dogman is offline
post #56 of 607 Old 12-21-2009, 08:38 AM
rondak46
At ride height, you use a square to make a line, 90 degrees to the line created by the two lower control arm mounting bolts.
The towers can be bought at the Ford dealer. The part number is on Stu's write-up. I have a pair that I need to get rid of if you are interested. I think I paid $17 a piece.
Cheers, Mike
rondak46 is offline
post #57 of 607 Old 12-21-2009, 08:41 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Roughly, you'd like them at about 90° to the lower control arms at right height. Assuming you're normal and have approximately the same up and down travel, you will push the bottom of the shock back at stuff and pull it forward at droop.
He got the ones in this thread from me and we sorta swap stuff back and forth. He takes care of me and I take care of him.
I am Savvy
mrblaine is offline
post #58 of 607 Old 12-21-2009, 08:44 AM
RubiconRazorbac
RubiconRazorbac's Avatar
There's another HUGE benefit for those of us in the rust-belt. Look at the upper mount in post #45. Even if the mount contracted road-salt-cancer, you can still access the mounting bolt & change your shocks easily.
Compare that to how much trouble it is when the upper mount bolts snap on the OEM set-up.
Thanks again guys!
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #59 of 607 Old 12-21-2009, 09:09 AM
Redarcher89
Great right up. This has made outboarding a little easyer to understand for me. I am a little slow though.
Redarcher89 is offline
post #60 of 607 Old 12-21-2009, 10:00 AM
mountaineerjp
Do you have any pics of the lower mounts? I am collecting parts and about ready to dive into this project, but I am still a little uncertain as to how to approach the lower mounts/shock stud. Maybe put together a parts list for people?
1997 Sahara - 2.5"OME HD Springs and 2" BB - Bilstein 5100s - 35" BFG KM2s - Doug Thorley Header - Warn M8000 - Nates 4x4 Front & Rear Bumpers - JeepMedic Engine Skid - Shrockwork Rockers - OR-Fab Sport Cage - Ford 8.8 - 4.10s - TNT Customs 4.5" Tube Fenders in Front and Rear - Viking Soft Top - many other mods
WEST VIRGINIA UNIVERSITY
Every normal man must be tempted, at times, to spit on his hands, hoist the black flag, and begin slitting throats. - H. L. Mencken
mountaineerjp is offline
SUA YJs- Outboarding rear shocks….Worth it? supersteez YJ Wrangler Technical Forum 32 02-08-2011 08:18 PM
Stock rear spring mount relocation? Mute9937 TJ Wrangler Technical Forum 4 12-28-2009 04:19 PM
Do I need to change this?...FAST? (Rear tire close to upper coil bucket) SWATmedic TJ Wrangler Technical Forum 35 04-23-2009 09:30 AM
rear upper shock relocation brackets? willyb8 YJ Wrangler Technical Forum 2 03-02-2009 02:41 PM
Outboarding rear shocks TSEJEEPERS YJ Wrangler Technical Forum 8 02-02-2009 03:34 PM
