Outboarding rear shocks AND upper spring bucket relocation - Page 11 - JeepForum.com
post #151 of 607 Old 02-14-2010, 09:16 AM
jgorm
jgorm's Avatar
Nice job! I've been itching to cut up my jeep. Just gotta finish up my other "open" projects.
jgorm is offline
post #152 of 607 Old 02-14-2010, 09:24 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Careful there, you wouldn't want anyone knowing you actually used an idea from someone as arrogant as I am.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #153 of 607 Old 02-14-2010, 09:31 AM
jgorm
jgorm's Avatar
haha, you know i love you blaine! But don't get your hopes up because my idea has very little in common. Basically we will both cut into the frame, but other than that there is nothing similar. But hey, what else would i expect from a guy like you.
jgorm is offline
post #154 of 607 Old 02-14-2010, 10:53 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
And I expect nothing less from you.
I am Savvy
post #155 of 607 Old 02-14-2010, 11:34 AM
Reelm n Rubi
Fish fear me
Reelm n Rubi's Avatar
Very nice! This is a future mod for me for sure. I'm surprised I haven't tore my shock mounts off yet. Thanks for fantastic thread.
2003 Lt. Khaki Rubicon automatic
Supercharged 4.7 stroker w/ Hesco aluminum head
70mm F&B throttle body
Kieth Black forged 944 pistons
Comp Cams custom ground camshaft
505 Performance PCM
Split Second Engineering fuel/timing management
Tom Woods CV driveshaft
50 lb/hr Trick Flow injectors
4" Full Traction LA with Bilstein 7100's
JKS 1" MM,BL. TeraFlex engine and steering armor
4.88's w/ 35 " Toyo Open Country m/t's
Moser Chromoly axle shafts front, Superior D44 rear
Warn 9.5ti on a M.O.R.E hi clearance bumper
Reid racing knuckles, Warn premium hubs
PIAA 525's, and 510's
XBOX Gamertag- ISHAGDyurGURL
For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30
Reelm n Rubi is offline
post #156 of 607 Old 02-14-2010, 05:02 PM
mudb8
want it rite or rite now?
mudb8's Avatar
mudb8 also did a nice write up on this:
http://www.jeepforum.com/forum/f9/lo...antage-852221/
I much prefer the shocks to be fully outboard but some just don't like the idea of cutting into the frame.
I've also got another bracket now for the upper mounts which elimiates the Bar Pin, without losing uptravel from a "BPE" however, you need a body lift to use them. in the end, the lower mounts are protected by and reinforce the LCA mount and the upper shock mount is raised about 1.25" and slightly inboard to keep the larger diameter shocks from rubbing the frame at full compression.. Which is something I ran into from outboarding lower mounts to far.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #157 of 607 Old 02-17-2010, 07:38 AM
crusher242
What measurments were used to tilt the top of the tower outward and the bottom inward? EX: 1"on top, 1/2" on the bottom.
Hold onto something... Quick!!!
crusher242 is offline
post #158 of 607 Old 02-17-2010, 08:11 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I just did a set of 12" Fox shocks and it was around 1/2" on the bottom and 3/4" for the top.
I am Savvy
post #159 of 607 Old 02-17-2010, 09:03 AM
crusher242
Is there a standard for this or preferance?
post #160 of 607 Old 02-17-2010, 09:23 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Go back and read what Joe had to say again. You have to cycle the axle many times to get your clearances. When one side is stuffed and the other drooped, the shocks are at their closest and furthest points from hitting the lower part of the shock mount.
You want the top of the mount tilted outwards enough to stop contact with the frame but inwards enough that the tire doesn't hit the shock. YOU have to figure that out by how the axle moves.
I am Savvy
post #161 of 607 Old 02-17-2010, 09:29 AM
crusher242
OK thanks. I think I get what your saying.
post #162 of 607 Old 02-17-2010, 03:40 PM Thread Starter
Humboldt
Humboldt's Avatar
I thought I had a pretty good idea of how a rear axle moved from messing with it over the years, but until you pull the springs, sway bar, shocks and tires and really start jacking stuff around you wont truely understand. (At least for me. My crayons on construction paper only got me so far )
After you do that for a bit, the measurements and spacing are self explanatory.
Humboldt is offline
post #163 of 607 Old 02-24-2010, 10:56 AM
Deacon
Shining Adonis
Deacon's Avatar
Thanks so much for this thread!
I notice on the first page that you went with the Currie bump stops. I have whatever TeraFlex bump stop extensions came with my 3" complete lift of theirs. It doesn't look like those bump stops are "extended" in that way. Is that because with the new outboarded setup you no longer need extensions? If so, is that because the shocks won't be your limiting factor or because you're running the MetalCloak rear corners/flares and thus don't have to worry about rubbing flares?
Deacon is offline
post #164 of 607 Old 03-02-2010, 04:03 PM Thread Starter
Humboldt
Humboldt's Avatar
Sorry for the delay, I was at sea for a couple weeks.
The Currie bump stops are the right size for 4" lift springs. It just splits the extension between the top and bottom as well as capture the coil spring.
The metal cloak fenders do not offer much more real clearance over stock, the flair is just not in the way.
The bump stops limit my up travel, not the shocks. You still need proper sized bumpstops with outboarded shocks.
Humboldt is offline
post #165 of 607 Old 03-02-2010, 05:42 PM
Deacon
Shining Adonis
Deacon's Avatar
When you say it captures the coil springs, are you saying it retains the springs on their buckets top and bottom so they don't unseat and rattle around loosely under extreme flex?
Having not seen it in action, I'm not sure what else that could mean. Thanks for the clarification
Deacon is offline
SUA YJs- Outboarding rear shocks….Worth it? supersteez YJ Wrangler Technical Forum 32 02-08-2011 08:18 PM
Stock rear spring mount relocation? Mute9937 TJ Wrangler Technical Forum 4 12-28-2009 04:19 PM
Do I need to change this?...FAST? (Rear tire close to upper coil bucket) SWATmedic TJ Wrangler Technical Forum 35 04-23-2009 09:30 AM
rear upper shock relocation brackets? willyb8 YJ Wrangler Technical Forum 2 03-02-2009 02:41 PM
Outboarding rear shocks TSEJEEPERS YJ Wrangler Technical Forum 8 02-02-2009 03:34 PM
