Outboarding rear shocks AND upper spring bucket relocation
| Spartan Lockers FREE SHIPPING Excellent Prices | DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ |
#1 | |
This will be a long thread. With lots of pictures.
I have wanted to outboard my rear shocks for quite some time. So I did what most people I know that wheel do; go visit Blaine. I picked his brain and asked him a ton of questions, read Stu's write up and searched for a solid week on various boards. Eventually, I had a plan and the parts collected including a Currie bump stop kit. (Thanks to Gerald from Savvy, Smokin deal ![]() Just as in Stu's write up, I started by placing jack stands under the frame to keep the frame at ride height. Here's what lead to the whole project: 3 1/2" of up travel in the rear frankly doesn't cut it in the desert. I lived on my bump stops in the whoops. I'm aiming for 5" of up travel. ![]() I pulled the springs and installed the Currie bump stops. All I can say about the kit is "quality". They're sweet. A tip Blaine gave me is to fill the upper bump with washers so you are not compressing the upper edge of the cup and have something to tighten against. 3 washers and I was good to go. ![]() Once the bump stop kit was installed (yes I know they are not centered, I left them loose for mock-up), I jacked up the rear end to start taking measurements for my outboard shocks.... ![]() maybe not We have a problem Houston.Here's the problem, I run RE super flex 2 fixed length lowers. They're long. They caused some headaches in the front but it was easily fixed by bending the Currie drag link out a bit more and using wider lower bump stops. Not the case out back since the offset is compounded by the pinion adjustment required by my Double Cardan drive shaft. I love the length of the arms, so even when I go custom arms, I want the axle to be in the same place. Gotta do SOMETHING. So I start scratching my head, grab a cold coke, and do what most people I know do; Call Blaine ![]() At this point, I have to throw this out there. If you have never talked to Blaine you're missing out. He talks about jeep mods like you would tell someone how to butter toast He's just so good at what he does, the average skilled guy (or below average like me :P) is left saying "No way I can do that." Luckily for me, he allows time for me to get my crayons out so I can follow along. After a great chat with Blaine I'm left with two choices; Get adjustable lowers OR cut off the upper spring buckets and move them a bit back and level them. Did I mention I like the length of my lowers? ![]() Getting to the back welds was quite fun even with the tank removed. I ended up using a dremel with a cutoff wheel. The outside was easy with a grinder. Still gotta do some trimming around the track bar mount and flip the track bar bolt around, but you get the idea. ![]() From the looks of it, I will be able to get the coil mount raised up 1 1/2" while its rotated back. Hope so, otherwise I'll be in the market for some shorter springs. This is a prime example of the Jeep Cascade Effect. Set out to change 2 things, and you end up changing 100 little things. Good thing I like my garage ![]()
#2 |
did you have to get longer shocks to do the outboarding
#3 |
#4 |
I will be outboarding and triangulating my rear soon. I was told that 13" Long travel shocks is what I'll need. does that sound right?
#5 | |
Im really just doing this as a temp fix before going to a custom suspension with coil overs. Just dont have time for all that before my next deployment, and really want to get some more trails in before I go. I made this thread because these are pretty common mods people do and they kinda go hand in hand. Figured Id throw some pictures and notes since I didnt find a whole lot searching. |
#6 |
Subscribed. I am looking forward to seeing how this turns out.
"Only two things are infinite, the universe and human stupidity; and I'm not sure about the former." - Albert Einstein http://www.venemousduckracing.com |
#7 |
Thanks Humboldt, I will be tuned into this project closely. If my garage was warmer, I would be wrenching in real time with you..
#8 |
Great write-up so far! Subscribed & Crawled
My build thread: http://www.jeepforum.com/forum/f9/rubiconrazorbac-build-thread-792423/ |
#9 |
Brake Wizard
Great job Joe! I'm liking it so far and I thoroughly enjoy your reluctance to dive into something I well know you're capable of until a little kick in the butt sends you on the way.
![]() Make sure that you mock up the perches and make sure the bumps work before you weld them up. Like I said on the phone, trimming the back of the one around the trackbar mount won't be an issue. The only other thing I would caution others on is to be careful and watch the depth of your cut on the welds. The frame is pretty thin comparatively and you don't want deep gouges in it from the cut-off discs.
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#10 |
Do it right or not at all
![]() Join Date: Jan 2003
This is going to be one our better threads, nice!
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#11 |
Why did you go with the ford mounts? I think remember that Blaine recommended another source previously; I think it was the TNT customs kit which I have ready to install. I also have the Ford mounts which I bought before changing my mind.
http://www.tntcustoms.com/page.asp?pageid=152 Cheers, Mike |
#12 | |
Brake Wizard
#13 |
Cutting the frame to weld in the new towers, how does that affect the structural integrity? I doubt it would cause issues for the main suspension since it is behind that area. Would it cause issues for towing? What about getting hit from the rear?
2004 Jeep Wrangler Unlimited, Automatic RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers - Power Door Locks with Keyless Entry Build Project Thread Rocker Guard Comparison Chart - Final Differential Gear Ratios - Oxygen Sensor FAQ |
#14 |
intentionally left blank
Thanks for starting this thread. I wish I would have done this when I did the axle swap. I'll be watching to see how it goes, and then doing this in the very near future.
#15 |
I can say that two local custom 4X4 shops would not do the job for me. So there are some knowledgable people who have their doubts. That said, I have not heard of anyone having problems on the forums. I wonder how Stu's set-up is holding up...
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
