Out of spec thrust angle question and diagnosis - JeepForum.com
post #1 of 3 Old 08-08-2010, 02:19 PM Thread Starter
01TJfuntime
So my thrust angle is a positive .43 degrees. By my techs calculation thats a fifth of a degree over spec...subsequently it needs to be fixed. I have a 2" coil lift which is more like 2.75" in the rear. Stock control arms and track bar. I posted a thread on this last week so forgive me if its redundant but the axle sticks out of the passenger side about half an inch further than the drivers side. Would an adjustable track bar, or a relocation bracket help me out?
Thanks.
01TJfuntime is offline
post #2 of 3 Old 08-08-2010, 03:16 PM
BlueFlame
BlueFlame's Avatar
Personally, I would forget about it. Not worth chasing.
But, if you're looking for an excuse to upgrade, then some adjustable control arms and track bars will fix you up.
BlueFlame is offline
post #3 of 3 Old 08-08-2010, 03:37 PM
crgrissom
Master of Reality
crgrissom's Avatar
Thanks.
Since there is nothing adjustable in the rear, not much you can do unless you upgrade some parts.
Maybe the stock track bar being at a higher angle and arcing your axle to the passenger side is pulling you out of spec, so an adjustable track bar or simply a relocation bracket would probably help.
Did you loosen the control arm bolts and re-torque them with the Jeep on the ground? If not you might try that, because they would be binding a bit, which along with the uneven pull of the trackbar may be enough to get it that much out-of-kilter.
Chuck
Chuck Grissom
Opportunity is missed by most people because it is dressed in overalls and looks like work.
- Thomas A. Edison
crgrissom is offline
thrust angle , track bar , trac bar , relocation bracket , tj , wrangler , axle , center
Dana 35 Thrust washer spec? HoustonTJ TJ Wrangler Technical Forum 0 02-17-2010 09:14 AM
Thrust Angle Trouble!!! 4LiterFury2010 TJ Wrangler Technical Forum 13 12-31-2009 07:48 PM
Thrust Angle & Alignment Question Chris @ GATR TJ Wrangler Technical Forum 79 03-15-2007 10:04 PM
Thrust Angle?? smkuczka TJ Wrangler Technical Forum 5 01-27-2007 05:12 PM
LCA's and thrust angle Polaris TJ Wrangler Technical Forum 3 03-20-2006 12:47 AM
