Out Of Balance - JeepForum.com
post #1 of 7 Old 07-10-2006, 01:48 PM Thread Starter
mdot
Out Of Balance
What could cause the feeling of out of balance tires, if not the tires themselves?
I was in an accident a month or so back, and had to have my front axel and housing replaced. When I got it back, I noticed a vibration in the front of the jeep. Not only in the steering wheel, but in the whole front end, and really only at speeds above 60 mph.
The repair shop re-balanced my wheels, but the vibration is still there.
I'm bringing it back to the shop, but would like to go in with some ideas for them to check.
What else could be out of balance?
I have no lift, and have not replaced the stock 30" tires yet.
mdot is offline
post #2 of 7 Old 07-10-2006, 01:50 PM
river rat
Forum porn star...I guess
river rat's Avatar
Busted belt, u-joint, trackbar not properly torqued, slightly tweaked driveshaft.
97 TJ. Full width D60 w/Detroit, Alloys and 5.89 gears. Full width D44 spooled, 60 outers, Warn lockouts. 6" Rock Krawler Gen II LA. 11 gallon cell behind the rear seat. 37" Maxxis Trepador competitions on 17" Stazworks double internals, blazay, blazay.....
river rat is offline
post #3 of 7 Old 07-10-2006, 01:58 PM
mdm
Farm Wheeler
Bent wheel.
mdm is offline
post #4 of 7 Old 07-10-2006, 02:23 PM
05tjx
it took the tire shop 2 times to balance my tires still couldnt get it so i went to truck off road shop and had them do it and they fixed it
05 tj x, 4in procomp stage 2, aem intake, tbs, jet chip, 3312.50 15 on 15x10 weld supersingles, quick discos, 4.56s, detroit truetrac in the front and super 35 kit with a detroit in the rear,and other stuff
05tjx is offline
post #5 of 7 Old 07-10-2006, 03:27 PM Thread Starter
mdot
Busted belt? as in one of teh steel belts in the radial tires? Interesting. How sould that be found?
The track bar sounds promising. I had a weird steering wheel wobble after a pothole one day. Couldn't reproduce it though, so just thought it was an anomoly. But that could have been it.
Thanks for the ideas guys.
mdot is offline
post #6 of 7 Old 07-10-2006, 03:39 PM
redvett94
Go to a dealer that has a Hunter GSP9700 its a load force balancer and will find anything from a bad rim to a bad tire or most likely bad balance.
Go here and type in your zip.
http://www.gsp9700.com/pub/search/findgsp9700.cfm
2000 Sport.
redvett94 is offline
post #7 of 7 Old 07-10-2006, 04:20 PM
JESSETHELJ
JESSETHELJ's Avatar
Alignment may be, I had a wicked shake between 50-60 did an alignment form http://www.4x4xplor.com/alignment.html
Im glad I didnt pay some one.
JESSETHELJ is offline
Driveshaft - to balance or not to balance??? brtt485 YJ Wrangler Technical Forum 7 09-08-2009 05:32 PM
tire balance asbury YJ Wrangler Technical Forum 9 02-28-2009 09:51 AM
Could Tires out of balance cause this?? ArchAngel78 TJ Wrangler Technical Forum 20 09-14-2006 06:08 PM
Balance MCanavan TJ Wrangler Technical Forum 22 05-21-2006 10:55 PM
Out of Balance EricS TJ Wrangler Technical Forum 10 09-25-2003 06:01 PM
