ORO Swayloc Install - Check my Links and Arms - JeepForum.com
post #1 of 8 Old 12-06-2008, 01:46 PM Thread Starter
SuperWade2
More Money than Brains
SuperWade2's Avatar
Just wanted to have people who know what's up with the SWAYLOC install take a quick peek to see if it looks like my Arms are at an OK angle and links more or less appropriately sized and set.
Thanks in advance...
Wade
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #2 of 8 Old 12-06-2008, 03:19 PM
cincytj
cincytj's Avatar
pretty sure the arms are supposed to be parallel to the ground. Im not sure what effect it will have being a little higher but it looks like you dont have any adjust ment left to bring them down. did you buy the right kit for your lift height? maybe call ORO and ask if its an issue
03 Patriot Blue Sport
Rubi d44 both ends, Crane Diff Covers, Rock trac t-case
Tom Woods CV DS, Alloy USA rear axles (waiting for install) ARB front bumper, Rock-it-Man Rockers
knoblock rear bumper, OBA in process,
bestop tire carrier, 35-12.5-16 trXus MT's on MOABs with 1.25 spidertrax
Currie HD steering
Nth Degree 6" LA kit. Garvin Wilderness Rack w/hi-lift mnt
HEMI & 5spd Auto
cincytj is offline
post #3 of 8 Old 12-06-2008, 03:24 PM
rubidriver
I have no idea what ORO suggest, but your suppost to have it at a 10 degree incline on the sway bar to make it perform similar to stock. The less degree incline you have the worse it handles.
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
post #4 of 8 Old 12-06-2008, 03:35 PM Thread Starter
SuperWade2
SuperWade2's Avatar
They provide adjustable links now...there is a 4.5", 3.5" and 2.5" inch (I think) set of links... I used the 4.5" and 3.5", but could swap the 2.5" in... the instructions do mention 10-15 degrees of incline, but I don't have an angle finder, so I guessed, and tried to make the links on either side the same.
Not quite perfectly Verticle, either, which probably means my Axle isn't quite centered (which I suspect for other reasons).
SW2
2017 WK2 Overland
post #5 of 8 Old 12-06-2008, 03:42 PM
cincytj
cincytj's Avatar
I looked at my instruction picture and they were parallel as far as I could tell. I will read it and see what they suggest, it has been a while since I put mine on
Currie HD steering
HEMI & 5spd Auto
cincytj is offline
post #6 of 8 Old 12-06-2008, 03:49 PM
cincytj
cincytj's Avatar
the instructions dont mention angle, but the pictures show them parallel to the ground. the only mention of position is to make sure when the tire is stuffed and you turn the wheel the tire cant grab an arm and bend it, not sure if the higher position is more likely to grab or the lower position so I guess you need to watch it until you know for sure you are clear when stuffed
Currie HD steering
HEMI & 5spd Auto
cincytj is offline
post #7 of 8 Old 12-06-2008, 09:55 PM Thread Starter
SuperWade2
SuperWade2's Avatar
I was going off the info from this thread...was hoping that more people that have installed (or designed ) the Swayloc would chime in..
"I called Off Road Only (ORO, manufacture of Swayloc) and asked them, they said the operating angle should be between 10-15 degrees above horizontal, a little higher but pretty close to what the FSM says for the factory bar."
http://www.jeepforum.com/forum/showt...hlight=swayloc
2017 WK2 Overland
post #8 of 8 Old 12-06-2008, 09:58 PM
BillR
BillR's Avatar
They look like mine, about even with the frame.
That'll work good.
'11 JK Unlimited Sport S, stock for now...
'08 JK X, OEM rear locker and swaybar disco!
BillR is offline
Swayloc dual rate swaybar - install and review Crashnburn80 TJ Wrangler Technical Forum 20 01-13-2013 07:41 PM
How to check for bad control arms? Hellbound13 JK Wrangler Technical Forum 2 12-26-2008 10:18 PM
Issues with ORO SwayLoc install kinder TJ Wrangler Technical Forum 14 11-13-2007 04:58 PM
Check your upper swaybar links for tightness kubwa_jim JK Wrangler Technical Forum 0 08-04-2007 07:00 PM
Help with some links-gear install-TJ changes by year-ect ISurvivedNMU TJ Wrangler Technical Forum 2 12-23-2006 03:31 PM
