ORI Struts - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > ORI Struts
Ruffstuff Axle Simple Swap Kit!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!
Unread 12-09-2009, 01:17 PM   #1
Imped
Imped's Avatar
ORI Struts
Maybe I'm a dork, but I just discovered these--http://www.oristruts.com/index.html
Lightweight, easily packaged, very small, no sway bar needed. The only con--$$$$$
Where I discovered them: Ori ???? - Pirate4x4.Com Bulletin Board
Anyone in here used them or seen them in use?
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 12-09-2009, 01:21 PM   #2
MisterO
those look cool.
whats the difference between that and coilovers?? and why do they eliminate a swaybar??
excuse my lack of knowledge in this area, im just tryin to understand.
MisterO is offline   Reply With Quote Quick reply to this message
Unread 12-09-2009, 01:25 PM   #3
Imped
Imped's Avatar
ORI DP3 Strut - Pirate4x4.Com Bulletin Board
Read for yourself--another huge advantage, and it may be the larges--NO UNLOADING. These are awesome.
From ORI:
Features
Patented differential pressure hill sensing technology exclusive only to the ORI DP3 Strut.
Standard color is black with chrome. Other colors available by special order.
8” to 20”
ORI Struts can replace heavy, expensive components such as springs, shocks, bypass cylinders, shock oil coolers, bump stops and limit straps. All these features included in one lightweight ORI Strut!
Dual-pressure piston eliminates piston shaft unloading, or push-off
Struts can be tuned for stiffness settings from loose articulation to sports car-like stability by decreasing or increasing charge pressures described above.
Adjust ride height by simply changing charge pressure.
Support from featherweight to over 1300 pounds per strut
Internal hydraulic bump and limit stops
Bypass cylinder is integral (built-in), not strapped on with external plumbing
7-Position externally-adjustable velocity-sensitive hydraulic rebound damping
3-Stage externally-adjustable hydraulic compression damping
1 ¾” hard chrome hollow piston shaft and 2” hard chrome cylinder
2” Stainless steel piston
5000 psi high pressure urethane dynamic seals
Bright anodize aluminum outer surfaces
Teflon-lined spherical bearings at both upper and lower mounts
Lower mount is ultra high strength heat treated aluminum
OlllllllO
Float Test Build
IndyORV
Unread 12-09-2009, 01:34 PM   #4
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
o0o sexy. looks pricey
my favorite techie shocks are the "smart" rheological shocks that use magnetic fluid which changes flow and stiffness properties based on electromagnetic field.
Magnetorheological fluid - Wikipedia, the free encyclopedia
Smart fluids - Physicists Apply Magnetic Fluids to Shock Absorbers
YouTube Video: YouTube - MR (magneto-rheological) Fluid - Pacific Science Center
Imagine the possibilities when combined with a computer chip to control millisecond switching of fluid stiffness.
Review: 2009 Cadillac CTS-V offers supercar performance, everyday drivability — Autoblog
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 12-09-2009, 01:42 PM   #5
Imped
Imped's Avatar
Pretty cool ^^. These ORI's are so freakin sweet and simple and judging by what everyone says, THEY WORK. And at about $600 a corner, it's not THAT expensive considering you don't need a spring, a shock/CO, limit straps, bump stops, or sway bars.
OlllllllO
Float Test Build
IndyORV
Unread 12-09-2009, 01:52 PM   #6
spyder6
Got that Toyota chit
spyder6's Avatar
2010
then consider the new Balistic airshock/coilover hybrid and 300 a corner
im a big fan of making it perform best on the street and better offroad but im kinda leary about using a strut.
My builds: Bruiser and The Grey
|Forge Overland| or follow us on Facebook
spyder6 is offline   Reply With Quote Quick reply to this message
Unread 12-09-2009, 01:53 PM   #7
Dogman
Amazing...
Dogman is offline   Reply With Quote Quick reply to this message
Unread 12-09-2009, 02:43 PM   #8
Imped
Imped's Avatar
Those are nice, but they're still CO's. If I'm going to be spending a lot of money (defined as more than $100/shock), I'll go with the simple, functional package that ORI offers.
Originally Posted by Dogman View Post
Amazing...
Yeah.......
OlllllllO
Float Test Build
IndyORV
Unread 12-09-2009, 03:00 PM   #9
spyder6
spyder6's Avatar
2010
so is it basically just a nitrogen air shock that has resistance at both ends? because i know struts usually require a spring - that doesnt seem to be the case with these
Unread 12-09-2009, 03:07 PM   #10
spyder6
spyder6's Avatar
2010
i read into it a little more, it has 2 sets of springs on the inside soft springs and hard springs and it will SWITCH between the two as it senses camber at what not.
amazing
i'll take 4
Unread 12-09-2009, 03:09 PM   #11
Imped
Imped's Avatar
Haha, yeah. They are REALLY cool and I have yet to find anything but amazing reviews. No failures, super durable and they just flat out work really well. And imagine not having to set up spring and shock mounts, limit straps and bump stops......sweet.
OlllllllO
Float Test Build
IndyORV
Unread 12-09-2009, 03:49 PM   #12
-sean-
I have been researching these since KOH last year... I'm in. And I am finding over on Pirate that the cost is actually pretty reasonable (depending who you buy from) considering what you get.
L-TJ
L-TJ Dos... Nope
-sean- is offline   Reply With Quote Quick reply to this message
Unread 12-09-2009, 03:52 PM   #13
DBLJ
DBLJ's Avatar
How are these for on road? Same as a CO?
Buy my transmission cooler. Derale TJ cooler.
http://www.jeepforum.com/forum/f126/...0561-a-2936825
DBLJ is offline   Reply With Quote Quick reply to this message
Unread 12-09-2009, 04:02 PM   #14
mcg311TJ
From what I'm reading, a whole lot better... they are calling this a strut And struts work well on the street.
mcg311TJ is offline   Reply With Quote Quick reply to this message
Unread 12-09-2009, 04:04 PM   #15
Imped
Imped's Avatar
After reading, it looks like they dampen extremely well while also giving you a very tight ride on the road. Off the road, they are just nuts.
OlllllllO
Float Test Build
IndyORV
