ordering lift what else to get - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > ordering lift what else to get
New! JK/U skid plate system.We now have Uniballs!The Original 3/8" Ruffstuff Diff Cover!
Unread 05-21-2015, 03:35 AM   #1
Morgan12
I've decided to order a 2" BDS lift with the 5500 steering stabilizer after reading on here its probably the best bet for the money . I wanna do it right so I called up a few shops and got different answers. I don't wanna be waiting on parts either so looked here and saw a few different answers as well. Its going on a 98 tj I've been told I should/ should not get the rear sway bar relocation bracket and adjustable BDS cam bolts by a few different shops. Of course there goal is to sell me stuff. Also will qd sway bar links really work that good with only a 2" lift I'll be running 32 and 31 inch tires. As far as an mml goes should I spend money on one or wait and just use a few washers. Finally I saw some people on the boards said to go with extended bumper stops what's thoughts on that. The mechanical install side of its no big deal to me I just wanna make sure I order everything I need and get it right the first time. Thanks
Morgan12 is offline   Reply With Quote Quick reply to this message
Unread 05-21-2015, 08:33 AM   #2
biffgnar
biffgnar's Avatar
Don't recall what all that kit includes but with 2" of lift you shouldn't have to do a lot. Yes, on the margin cam bolts might help, although with a 98 you might have them OEM. Check. Caster not going to be thrown off that much anyway. Bumpstop extensions, in particular in the rear, probably are necessary if not included in the kit. Disconnects for the front really depends on you and how you'll use the jeep. Not required at all, but probably some benefit offroad. Reference to rear sway bar relocation bracket doesn't make sense. Do you mean track bar? At 2" of lift you probably are fine, but that's a simple fix if you do end up needing it. You are unlikely to get vibes with only 2" of lift so hold off on the MML. If you are one of the unlucky few who do it should only take a couple washers to space down the TC skid and then you can decide what your permanent solution is.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 05-21-2015, 06:34 PM   #3
joe_jeep
All the advice above is solid.
Bds is a good kit.
Enjoy!
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline   Reply With Quote Quick reply to this message
