Opinions on track bar: Savvy vs metal cloak - Page 7 - JeepForum.com
post #91 of 574 Old 05-24-2013, 10:02 AM
J03_TJ
Originally Posted by biffgnar
With what I believe to be the newer Currie rear bar (and 4" lift and Savvy UA) the closest point of contact is near the middle of the bar. Rubbed ever so slightly on the edge of the middle GTS mounting nut before I adjusted things. It is close out on the corner of the front driver's corner of the GTS and if I put the trackbar mounting bolt through from the front it will hit, but if put through from the back the head clears. Note though that my axle mounting bracket there is a little different than most.
Thanks for that info. Yeah I think that close to rubbing spot in your GTS is where I have a definite rub. My axle bracket is a little different to. I also push the bolt in from the rear, I have no clearance problems with the trackbar bolt, just one of the GTS bolts and its nut, and yep it is somewhere mid span on the trackbar.
J03_TJ is offline
post #92 of 574 Old 05-24-2013, 10:09 AM
J03_TJ
Originally Posted by matsonian
I am working to get pics of our rear track bar clearance as well.
That would be great, specially if you can get a pic with it stuffed showing the area around the gas tank skid mounting flange and the trackbar. I take it the rear bar has a Heim on one end? I'm not as concerned about the heim wearing like Gerald at Savvy mentioned above, I only have one Heim joint on my jeep and it lasted 8 years before it started squeaking, never noticed any slop in it. Sorry if its been covered, but what size bolts are required for the rear bar?
J03_TJ is offline
post #93 of 574 Old 05-24-2013, 10:11 AM
freeskier93
It has been covered a couple times now. Their rear track bar re uses stock bolts.
freeskier93 is offline
post #94 of 574 Old 05-24-2013, 10:14 AM
J03_TJ
Oops, okay.
J03_TJ is offline
post #95 of 574 Old 05-24-2013, 10:20 AM
xxthomasxx
This track bar is looking very promising as I am trying to decide between this one and the JKS OGS126. I would like to see some reviews from users that might have this installed already.
xxthomasxx is offline
post #96 of 574 Old 05-24-2013, 10:25 AM
elclipo
Looks like I just found my track bar.
elclipo is offline
post #97 of 574 Old 05-24-2013, 10:45 AM
TheRealZ
Junior Member
Ask Matson how much he charges for a new "spare" heim joint. They are dirt cheap........I'll be picking up a pair of spares with my order.
TheRealZ is offline
post #98 of 574 Old 05-24-2013, 11:08 AM
JeepZJlover
If one was running the Arb edition kit with 33s would it need bumpstops? I fully intend on buying this kit when funds allow
1993 Cherokee 4dr SE green, 4.0, Auto, HP30, 8.25, 3" lift 31" Goodyear Duratracs, Custom made front recovery bumper, Kenwood radio, 12" alpine type e subwoofer,alpine amplifier, Smittybilt xrc8 winch, tuff stuff portable winch receiver custom modified. 2002 Jeep Wrangler Sport 4.0, 5 speed, Dana 30 front, Dana 44 trac loc rear, Stock
JeepZJlover is offline
post #99 of 574 Old 05-24-2013, 02:24 PM
elclipo
This is not a bad idea
elclipo is offline
post #100 of 574 Old 05-24-2013, 02:59 PM
J03_TJ
So on the subject of Heim joints, are they all created equal??? I am guessing not, but don't know. The one that is on my Jeep is the front Rubicon Express trackbar, which I stated had lasted 8 years or so before it stared squeaking. If I recall the RE heim had a plastic race that looked to be embedded in the heim joint. Do all Heims utilize a plastic race or are some metal on metal?? Wondering if the one from MC would be last as long on a trackbar as the one I have in my RE bar.
J03_TJ is offline
post #101 of 574 Old 05-24-2013, 03:30 PM
TheRealZ
Junior Member
The heims used in the MC trackbar seem to be a common size.....so Im sure quality isn't going to be an issue.
TheRealZ is offline
post #102 of 574 Old 05-25-2013, 06:27 PM
Ljcrawler05
So no memorial day weekend sale apparently...
Ljcrawler05 is offline
post #103 of 574 Old 05-27-2013, 08:36 AM
Gary2
On the MC front track bar , Does any one know the distance from the mounting surface of the heim where it meets the track bar mount to the center of the ball ( pivot point ) on the heim . I want to determine if it is any less than what I have on my JKS 126 bar with the 5/8" bolt JJ installed. It may be a better match to the pivot point on the drag link end at the pitman which would make the track bar and DL more evenly matched making the draglink and track bar closer to being parallel than a bar with a JJ on the frame mounted end .
Gary2 is offline
post #104 of 574 Old 05-27-2013, 09:00 AM
aparke4
yeah free shipping! freedom2013 via facebook
aparke4 is offline
post #105 of 574 Old 05-27-2013, 09:25 AM
Imped
Imped's Avatar
Most definitely not.
OlllllllO
IndyORV
Imped is offline
