Opinions on track bar: Savvy vs metal cloak - Page 5 - JeepForum.com
post #61 of 574 Old 05-23-2013, 03:14 PM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
If you like slop in your track bar, get the TB with the hiems as they all develop slop after a short time and need to be replaced. Not the the JJ don't develop it, they do but at least you can maintain them and grease them to reduce the wear.
Do it once or do it many times it is up to you. Save a $1 now and pay $3 latter plus the hassle of taking it apart to maintain.
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #62 of 574 Old 05-23-2013, 03:55 PM
matsonian
MetalCloak'd
matsonian's Avatar
1977 CJ7
Originally Posted by chmo View Post
"undirectional" is a bit uncommon ... but thats not what I wrote.
unidirectional is "in one direction" ... in contrast to bidirectional.
LOL! Here I was trying to be flippant and my fat fingers got in the way on the keyboard... meant to type unidirectional. FAIL.
It's Your Jeep, Only Better. |
For quotes or customer service
Lots and Lots of Videos:
matsonian is offline
post #63 of 574 Old 05-23-2013, 05:13 PM
matsonian
MetalCloak'd
matsonian's Avatar
1977 CJ7
Originally Posted by TheRealZ View Post
On the front trackbar... are you willing to back that up by garenteeing a full refund(including shipping) if thats not the case including a return shipping label?
I will never ship anything with the presumption that it will be returned... in other words no return label included in the package. However, and you can check else where on this very forum, we believe customer service is tantamount to good business and we will happily take back any product that any customer is not 100% happy with.
To date to my knowledge there is no bolt on aftermarket trackbar that requires NO EXTRA ADDED bumpstopping in the front of the TJ.
Thats a hell of a claim to make...........
Here are a couple pics of our TJ Solid Chromoly Front Track Bar on a TJ at full stuff with no coils, no shocks, no bump stops and the rubber in the jounce removed.
The fitment is tight, but it clears.
This particular rig can use a little more tuning on the control arms, you can see from this pic that the jounce is not centered on the bump pad. If it the control arms were adjusted so that they were centered, we'd have more clearance in the front.
BTW, thank you for the challenge. Without that, I wouldn't have taken the time to tear down the rig for these pics.
post #64 of 574 Old 05-23-2013, 05:30 PM
TheRealZ
Junior Member
Wow.....could this be the first front aftermarket tb that fully clears the axle and drag link?
Matson.....this is with a d30 stock drag link and tie rod correct? Full details on steering linkage and axle please. I assume your 100% confident that with the jounces fully centered on the axle the clearance will still be fine? Anyone see why it would have issues with the zj tierod upgrade?
TheRealZ is offline
post #65 of 574 Old 05-23-2013, 05:36 PM
TheRealZ
Junior Member
Also and very important question....how much lift was that tb set for? The taller the lift the closer the diff cover will be to the frame side single sheer mount when fully stuffed.....
TheRealZ is offline
post #66 of 574 Old 05-23-2013, 05:53 PM
matsonian
MetalCloak'd
matsonian's Avatar
1977 CJ7
Yes, this is a '99 TJ Sport with a D30 and completely stock steering linkage.
post #67 of 574 Old 05-23-2013, 06:04 PM
matsonian
MetalCloak'd
matsonian's Avatar
1977 CJ7
I am not sure that matters here. The adjustability of the track bar is at the frame end, therefore the location of the diff-clearing bend in the track bar does not vary in relation to the axle.
post #68 of 574 Old 05-23-2013, 06:11 PM
chmo
cool!
so ... the extended bump stops (3"?) in the front with your game changer kit are needed for exactly what?
In the other thread http://www.jeepforum.com/forum/f9/pr...coils-1525925/ we seem to come to the conclusion that the MC 3.5" coils would not need protection (through bump stop extensions) against coil bind with stock bump stop dimensions.
(The coil spring would fit compressed in the remaining 7.5" height at full bump)
For the 12" travel 6paks? with a compressed length of 13"? What a pity!
One more reason to finally come out with the right stem and bar pin shock ends instead of that mounting hardware, guys!
Or lets say the mounting hardware should position the shocks at approximately in the middle of their stroke at ride height with your MC 3.5" coil springs ...
Your current mounting hardware is adding to much length ... (?) ... it should not add more than 1.5"-2" to the compressed shock length, then it would be ideal!
"The more I know, the more I realize how much I don't know"
chmo is offline
post #69 of 574 Old 05-23-2013, 06:40 PM
TheRealZ
Junior Member
cool!
I still believe that jeepineer made a mistake on front coil compressed measurement sine the front coil has 13 plus winds and not 11 as he stated.....plus the rear springs compressed length was never addressed by him.....i know those will need major bumpstopping since the coil bucket in rear is so darn shallow....
I also agree on the 6pak shocks.....need to address the hardware big time.....
TheRealZ is offline
post #70 of 574 Old 05-23-2013, 07:01 PM
matsonian
MetalCloak'd
matsonian's Avatar
1977 CJ7
The Bar Pin Eliminator adds about a 1/4" compared to the stock bar pin and the upper mounting bracket adds about 1.5". Our collapsed measurement of the 12" 6Pak is 13" from eye to eye. Very little is being added to that with the mounting hardware.
In the above pics, with the TJ fully stuffed (without the rubber jounce in place) the distance between the bar pin and the upper shock mount location in the shock tower is 13 3/8". With the stock rubber jounce in, there would be plenty of room for the 6Pak to fully stuff in the front.
The primary reason, IMHO, for anyone to use bump stops is Tire Size. In our kits we provide an adjustable bump stop system. Allowing customers to put everything from ZERO bump stop to 4" of bump stop, depending on their personal need. Our only prescription for bump stop is Tire-Size and fender recommendations. Running 33's with our fenders, no bump stop ever needed... running 37's and stock fenders, you had better bump stop it out.
A point of note, we used heims for a number of reasons, one of which is the simplicity of changing the mounting hardware. We designed it to have variable mounting options.
For now we are using heims, at some point that may change.
post #71 of 574 Old 05-23-2013, 07:23 PM
freeskier93
Could one theoretically replace the heim with a JJ? I'm very intrigued. I'm waiting patiently for your memorial sale so I can buy a full set of arms. At 160$ for the front TB, and the pictures you posted regarding clearance, I'm very tempted to add it to my order.
freeskier93 is offline
post #72 of 574 Old 05-23-2013, 07:44 PM
TheRealZ
Junior Member
Few more questions concerning your track bars.
A review of the REAR trackbar stated:
The bushing at the axle end is odd. The stock bolt is way to small leaving a lot of play between the bolt and the bushing. Of course it doesn't come with bolts like the rest of the Metalcloak products that are "bolt on" and you actually have to drill out. Also there isn't even an American made bolt that fits snug. The closes bolt is metric and it STILL has play. Not to flame the product to bad, it still has a strong feel, but there is a lot of talk over such an average product.
Any comment on this? If I order one I really hope I wouldn't need to find a bolt that doesn't quote fit? Maybe you can clarify on this feedback comment recieved on your rear trackbar setup.
Also......I assume the rear trackbar works at full stuff as well. Does it need any type of TB relocation bracket? Or?
Also, does the front TB frameside mount need to be drilled out? I really can't find much on install on either of the TB's.......
TheRealZ is offline
post #73 of 574 Old 05-23-2013, 07:47 PM
matsonian
MetalCloak'd
matsonian's Avatar
1977 CJ7
My statement above was in regards to the 6Paks, which, even if you had a JJ small enough, would not work because you don't want to give the 6Paks that much rotational capability.
If you are referring to the Track Bar, however, theoretically, if you had a JJ with the right size shaft and thread, you could (our heim is 0.75-16 X .875). Important to note is the size of the JJ body vs. the heim and the clearance the heim provides in the above pics (notice how close it is to the mount).
post #74 of 574 Old 05-23-2013, 08:02 PM
26679cj5
I've never seen such a great company get attacked so viciously as Metal cloak does. Not really sure why it happens, but I've seen it on a few different forums, and the metal cloak guys always have the most top-notch professionalism about it
BTW, is metal cloak running a memorial day special? I haven't seen any word of one and I'm ready to order some suspension components for a custom build.
26679cj5 is offline
post #75 of 574 Old 05-23-2013, 08:12 PM
matsonian
MetalCloak'd
matsonian's Avatar
1977 CJ7
LOL! This proves that we take no effort to edit any reviews on our site. This particular customer, if memory serves, installed the rear track bar backwards.
Now, the fault for that is ultimately mine because the instructions were not clear enough, and I finalize all instructions.
Yes, it does clear. The only clearance issues seem to be the typical exhaust/track bar relationship. No relocation bracket is currently needed and stock hardware is used to mount it.
Also, does the front TB frame side mount need to be drilled out? I really can't find much on install on either of the TB's.......
We drill out the axle side mount to 1/2" and the frame side mount to 5/8". My apologies on the instructions, I decided to pull them for updating.
