Quantcast Opinions on this Pro Comp Rear Bumper...... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Opinions on this Pro Comp Rear Bumper......
Old 10-12-2007, 04:52 PM   #1
19OlllllllO41
Jeep Addict
19OlllllllO41's Avatar
http://www.4wd.com/productdetails.aspx?jeep-sid=237&plID=0&partID=9768
Does anyone have any testimonials/opinions/experience of/with this bumper? It seems way to cheap to even be decent and strong. I have been looking a long time for a good price on a rear bumper with a receiver( i know this one is not "integrated" into the bumper like most others are) and d-ring tabs (have been looking for 1 inch thick ones to match my kilby front bumpers). Any info or pics of this bumper mounted on you jeep would help. I have not been a fan of pro comp in the past, but maybe someone could help sway my decision......... Oh and I DID search and found very little useful, up to date information. Im looking for solid reviews, not just hearsay!
'93 YJ (Under Construction)
Previous Jeeps:
'83 CJ7
'92 YJ
'00 XJ
'99 TJ
'05 TJ Rubicon
19OlllllllO41 is offline   Reply With Quote
Old 10-12-2007, 11:07 PM   #2
jeepteejay
This is the best I've got.
It's a nice bumper. I was highly impressed for it's cost.
It's 1/4" thick steel.
The mounting works fine, but it doesn't tie-in to the frame (Like quite a few bumpers out there).
If you were to use the receiver to tow (though it's not rated for towing), I would definately get some frame tie-ins from Rokmen (that's what I have, and they're excellent), Poison Spyder, Rockhard, etc.
Actually, I'd get them anyways, even for recovery purposes.
If you get it I think you'll be happy. It looks real good and fellow Jeepers always comment on it...and are amazed when I tell them what it cost.
It actually comes with 2 shackles, but they weren't stamped with a SWL, so I'd ditch them, and get some ones that are rated and of good quality.
jeepteejay is offline   Reply With Quote
Old 10-13-2007, 01:16 AM   #3
EG00TJ
1992 XJ Cherokee
thats a good looken bumper for that price !
1996 XJ (Jeep #4)
4.5" lift kit , drop brackets , adj control arms , 32x11.50x15
EG00TJ is offline   Reply With Quote
Old 10-13-2007, 01:37 AM   #4
TJAB
Love the way that bumper looks. But I need one with a tire carrier for 33s and a receiver that I can tow with.
TJAB is offline   Reply With Quote
Old 10-13-2007, 07:46 AM   #5
jeepteejay
I'm gonna be building a tire carrier for mine.
I've got all the gear, but haven't even started yet. Should be interesting.
I tow with mine, but it's not rated for it.
Old 10-13-2007, 09:17 AM   #6
BaddAndy
[QUOTE (borrowed)
If you were to use the receiver to tow I would definately get some frame tie-ins. I'd get them anyways, even for recovery purposes.
It actually comes with 2 shackles.[/QUOTE]
I have it too, but mine has a tongue weight and trailer weight rating placard riveted on the top of the hitch mount
BaddAndy is offline   Reply With Quote
Old 10-13-2007, 09:42 AM   #7
phittie1100
I had one on my YJ for 2 years. Other than one minor blemish (pea-sized, right at the D-Ring bracket weld), the finish still looked good, no rust (2 Michigan winters). I towed my boat with it several times - 1040 pounds and used it a number of times for winch pull and/or strap yank, and mounted my loaded hitch basket on it several times. Never had any complaints. Tied into the frame good and solid - 8 bolts w/backing plates through the rear cross member, 2 1/2" bolts up into the rear frame. Solid as a rock.
Paul - 2004 Wrangler Unlimited
VP - GLFWDA
KD8PAV
phittie1100 is offline   Reply With Quote
Old 10-13-2007, 12:19 PM   #8
beryl
smittybilt makes that exact bumper with the tire carrier
06x-6speed...hard/soft top, BPE's, 2" coils, 1" PA BL, 32 bfg mt's, 15x8 MT alloys, big daddy rocker guards, flowmaster, RE gen II discos, rear bumper and tire carrier, 10" MTX sub with 800watt kenwood amp, mossy oak mats, sony stereo
beryl is offline   Reply With Quote
Old 10-14-2007, 11:33 AM   #9
19OlllllllO41
Jeep Addict
Thanks for all of the information, I think I may just have to order one! Cant really go wrong for that price if it is really as nice as you guys all say it is! Thanks!
Previous Jeeps:
'83 CJ7
'92 YJ
'00 XJ
'99 TJ
'05 TJ Rubicon
Old 10-25-2007, 06:27 AM   #10
Blaster
I just ordered a pair of procomp bumpers front and rear $298.99 after shipping.
for that price I had to give it a try all I had were stock. Ill let you know how it comes out.
Blaster is offline   Reply With Quote
Old 10-25-2007, 06:51 AM   #11
chutta
One said it bolts to the frame, others said not. How can a bumper not be bolted to the frame back there?
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline   Reply With Quote
Old 10-25-2007, 07:52 AM   #12
jeep06
Wow
That is a great looking bumper and I just checked out the price. Wish I wouldn't have just ordered some bumper caps for my stocker,,might have to send them back........
Flame Red 2005 Rubicon Unlimited, 4.0L, 6sp, dual tops, Valvoline VR-1 10w30 engine oil/M0-090 Mopar filter, Amsoil Synchromesh 5W30 trans. oil, IPF 920hc head light conversion with PIAA Xtreme White plus bulbs, PIAA Xtreme White Plus H-3 fogs, Armadillo front/rear bumper caps and Olympic grille guard. Amsoil SevereGear 75W140.
jeep06 is offline   Reply With Quote
Old 10-25-2007, 08:44 AM   #13
Toolshed
I believe they mean that it's not ""really" bolted to the frame like a Hidden Hitch or something is bolted to the frame with 4 or 5 big bolts per side. The bumper is, however, attached to the crossmember, which is attached to the frame, and as stated, only two bolts actually attach the bumper directly to the frame. That's the way my HighRock bumber is anyway.
Toolshed is offline   Reply With Quote
Old 10-25-2007, 10:55 AM   #14
ChiliPalmer
Bacon Ends & Pieces
ChiliPalmer's Avatar
You could look into the Bestop High Rock rear bumper and then buy their tire carrier seperately...
EDIT: Actually you'd be money ahead by buying the Pro Comp bumper and the Bestop tire carrier...
If you want to help the sport of offroading visit the EnviroBeat Forum!
Blue Ribbon Coalition | Idaho State 4x4 Association | UFWDA | NAXJA | The KAT Team!
ChiliPalmer is offline   Reply With Quote
Old 10-25-2007, 12:39 PM   #15
jeep06
falling prices??
Must be they lowered their price since you added the link above. I just checked and they are only $111 plus shipping. Man the front is only $79.....that's pretty cheap protection.
http://www.4wd.com/productdetails.aspx?jeep-sid=237&plID=0&partID=9765
Glock Forum
