opinions on best tie rod upgrade for the dough - JeepForum.com
post #1 of 15 Old 04-16-2007, 04:39 PM Thread Starter
soxlover
soxlover's Avatar
Yes, I finally bent my stock tie rod and now I am wondering what are your best opinions on what to do. I have an 05 LJ, 3" lift, 33's.
soxlover is offline
post #2 of 15 Old 04-16-2007, 04:43 PM
[ITA]Tsunami
Italian Wheeler in Mexico
[ITA]Tsunami's Avatar
Currie, you'll love it
Originally Posted by mdm
However it is a strange twist in the cosmic thread that will not allow the driver of a Jeep that has experienced air bag deployment off-road to consume beef for 48 hours after the event. You can consume chicken, pork, turkey, or emu.
[ITA]Tsunami is offline
post #3 of 15 Old 04-16-2007, 04:45 PM
greenmachine99
greenmachine99's Avatar
I have the currie setup laying in my garage waiting to be put on. I cant say much for feedback now, but if its as good as it looks, i'll be very satisfied. Everyone that runs one seems to love it.
greenmachine99 is offline
post #4 of 15 Old 04-16-2007, 04:51 PM Thread Starter
soxlover
soxlover's Avatar
does anyone have any info on a zj upgrade?
soxlover is offline
post #5 of 15 Old 04-16-2007, 05:22 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Uh.... did you not look 5 threads down before you posted this thread?
http://jeepforum.com/forum/showthread.php?t=402861
Get the Rusty's if you want the best bang for the buck. $99 shipped with both TREs.
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #6 of 15 Old 04-16-2007, 05:32 PM
NavinRJohnson
I don't see anyone in that thread that has even seen the Rusty's tie rod, much less run one. How can you say it is the best bang for the buck? Cheapest, I suppose.
The Currie stuff is mighty sweet. Check out the alumiflex also tie rod and the RE version as well.
The D35: 60% of the time, it breaks every time.
'06 LJ (specs in profile, 35's, ARBs, rocket boosters, stealth technology, etc.)
NavinRJohnson is offline
post #7 of 15 Old 04-16-2007, 05:35 PM
XtremeJeep
www.bigdaddyoffroad.com
Huge Tie Rod
2004 TJ | 5'' on 35x12.5's | Currie HD Steering| Smittybilt tire carrier | 4.56's |
1988 XJ | 6'' on 33x12.5's | Locked and Loaded |
Originally Posted by bobbert350
you have to stop thinking of miles per gallon its fun per gallon....and in my jeep my fpg is too much to count
XtremeJeep is offline
post #8 of 15 Old 04-16-2007, 06:51 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
.... Sorry Jerry, I'll play nice.
Threads are the same exact topic. No reason for this one to be here.
Andy, KD8EIA
Grewe02 is offline
post #9 of 15 Old 04-16-2007, 08:02 PM
Tumble
Originally Posted by XtremeJeep
Ditto on the Big Daddy. It's beef.
Tumble is offline
post #10 of 15 Old 04-16-2007, 08:09 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
i have the big daddy one works for me
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #11 of 15 Old 04-17-2007, 11:03 AM Thread Starter
soxlover
soxlover's Avatar
With 3" lift do I really need to replace the whole steering system? I've understand that replacing the tierod only will move the weakpoint to the draglink. Will that be an issue later. BTW I don't do serious rockcrawling, mostly trails.
soxlover is offline
post #12 of 15 Old 04-17-2007, 11:08 AM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
I went with the Currie full replacement kit. I also plan to get a (slightly beefier) ZJ tie-rod at some point to replace my bent stocker, and keep that full setup as a trail spare.
I'll be Savvy someday!
neZZr is offline
post #13 of 15 Old 04-17-2007, 12:00 PM
chefdab
I looked at the Rusty's tie rod and the only problem I saw with it was that it is tapered at the ends where the TRE's mount. So you might run the risk of breaking it at the taper. I have the Off-road Only U-turn steering and think it's fine. That being said, I broke my stock tie rod at the end joint on my first off-road excursion. That's why I stayed away from the Rusty's. Don't want that to happen again.
David
2005 LJ w/ RE 5.5 LA riding on 35"MT/Rs
"Roads, where we're going we don't need roads."
... at what point has "NEED" ever come into play when it comes to Jeep upgrades
Originally Posted by ranmannm View Post
I'm a idiot so be genital.
chefdab is offline
post #14 of 15 Old 04-17-2007, 12:01 PM
mudmonkey2400
mudmonkey2400's Avatar
Rock Krawler, if you're looking for a full replacement:
http://www.jeepforum.com/reviews/sho...hp?product=331
2000 TJ : RK 5.5" X-Factor Long Arm, 1.25"BL/MML, RE Monotubes, RK HD Steering, Warn M8000, Lock-Right D30, Detroit D44 w/4.88's, 35x12.50R15 Pitbull Rocker Radials
1990 MJ : 2.5L, 5spd, 2wd, short bed and bone stock.
mudmonkey2400 is offline
post #15 of 15 Old 04-17-2007, 12:29 PM
XtremeJeep
Damn... THATS BEEF
Need TJ Steering upgrade opinions dman22 TJ Wrangler Technical Forum 66 08-08-2016 01:27 PM
Offroadtoystore & 33 Engineering is Kaput!-and so is my dough kaybone Wrangler General Discussion 108 05-04-2010 12:08 AM
BL and TT staged upgrade opinions Yellow TJ TJ Wrangler Technical Forum 4 07-02-2009 04:12 PM
Rusty's Long Arm Upgrade.. Any Opinions? mrlacy2 TJ Wrangler Technical Forum 17 05-29-2009 09:13 PM
Tire/Rim upgrade opinions swoodnj TJ Wrangler Technical Forum 11 05-06-2004 08:28 PM
