Opening full door causes it to lock halfway. help? - JeepForum.com
post #1 of 9 Old 10-14-2012, 07:33 PM Thread Starter
wheels52095
I'm having a problem with the passenger door on my LJ. When I open the door from the outside, locks itself half way. When I close it again, it locks fully, after which I have to use the key to unlock the door to open it. I took the door panel off to see the mechanism, but I am not sure what is wrong or how to fix it.
Pictures:
Unlocked Position:
"Halfway Locked":
Fully Locked:
Interior Lock switch when "halfway locked":
I am at a loss, and have no idea what to do. I haven't had much time to work on it, but once I figure out what's wrong, I'll devote more time to it.
Please help me!
wheels52095 is offline
post #2 of 9 Old 10-14-2012, 08:12 PM
Miller97
this is just happening to me also, kinda embarassing how you have to roll down the window and use the key when inside the jeep to get out of it haha
2003 Silver TJ Sport, BF Goodrich 30" A/T KO's. RIP 11/2013.|| '03 Gold Wrangler X. Project "Golden Eagle"
Miller97 is offline
post #3 of 9 Old 10-14-2012, 08:54 PM Thread Starter
wheels52095
If I push and hold the switch into the unlock position and pull the latch inside it works, so you don't have to use the key from the inside. Have you tried to fix it at all, or have any idea how to?
post #4 of 9 Old 10-15-2012, 07:21 AM
MAMMOTH
Wooly Member
MAMMOTH's Avatar
I had this and it turned out to be a piece of plastic that had broken off and lodged itself into the latch area of the door.
Take the door off, turn it upside down and shake.
You should hear it fall out and hopefully when turned back over into the bottom of the door.
2004 TJ Rubicon - 3" lift, 1" BL, Brown Dog MML with Super brackets, 33's, Warn Winch, VanCo BBK - (Thanks MisfitSeven), IronRock tierod, Ten Factory shafts.
Future upgrades - Too many to list
1999 XJ - DD with 228k
2007 JK Unlimited - The wife's ride.
MAMMOTH is offline
post #5 of 9 Old 10-15-2012, 07:36 AM
Bobs85Reny
I had this problem as well. 2 things I did to fix it. 1. those plastic purple clips wear out and it allows play in metal rod causing it to bind instead of opening. I bought some plastic washers and added them to eliminate the play. 2. After i replaced the plastic washers there was still some occasional binding. If you take notice you will see the angle is off and it is pushing outward instead of upward causing it to bind. So I put a slight bend in the bar until it angled properly to the latch. Been over 6 months now and have had no problems. Hope this helps.
Told my girl I just had to forget her, Rather buy me a new cartburettor,
So she made tracks sayin' ths is the end now, Cars don't talk back they're just four wheeled friends now
"Queen"
Bobs85Reny is online now
post #6 of 9 Old 10-15-2012, 08:15 AM Thread Starter
wheels52095
Ok. That's what I thought was happening. So I should bend the rod going toward the key lock? And could you give me more information on the washers?
post #7 of 9 Old 10-15-2012, 09:09 AM
Bobs85Reny
When i get home tonight i will take a look and see if i still have the bag that the washers came in to give you the size i used. They were the white plastic crown brand from home depot. The hole was just big enough to snap on over the end of the plastic nipple but move freely. I think i used 2 or 3 to get rid of the slop.
As far as bending the bar it was the smaller bar thats causing the problem. I think looking straight at the inside door it needed to go a little to the right. Bend it a little bit and test fit it without the plastic clips. You will know right away if you are going in the wrong direction it will just bind more. It was a very minor bend to get it to work freely. The problem is most of the latch parts that wear are plastic so it gives to much play in the rod and the rod binds. By bending it a little you are compensating for the slack.
"Queen"
post #8 of 9 Old 10-15-2012, 09:38 AM Thread Starter
wheels52095
Ok thank you. If I need help again, I'll either reply here or PM you. Thanks again!
post #9 of 9 Old 10-15-2012, 09:42 AM
2006_Sport
When i lock mine i have to punch the door in order to get it to unlock
Sent via RPG
2006_Sport is offline
door , latch , lj , lock , locked
