OPDA failure on 2002 - JeepForum.com
post #1 of 7 Old 03-29-2012, 07:22 PM Thread Starter
Brian86992
A few weeks ago my 02's 4.0 dropped three piston skirts and I recently had it replaced with a 4.0 from an 06. Being a 2006 engine I would normally be concerned about the OPDA failure however the engine was nearly brand new and I would be swapping in the OPDA from my 2002 instead.
OPDA in 2002 block
2006's OPDA that was not used
Well... much to my surprise when the OPDA/CPA was pulled from my 02 we found very abnormal wear on it.
Obviously I bought a new one to put in the 2006 block I thought I just might bring this to the attention of other TJ owners and would like to hear if this is how the other OPDA failures looked.
Protect the Constitution
4 linked DD on coilovers
Brian86992 is offline
post #2 of 7 Old 03-29-2012, 07:59 PM
ops5
ops5's Avatar
I would post this up in the main opda thread
http://www.jeepforum.com/forum/f9/20...ilure-1144202/
ops5 is offline
post #3 of 7 Old 03-29-2012, 08:09 PM Thread Starter
Brian86992
I posted a link to this thread over there. I wanted to create a separate thread because of the abnormality of the situation and didn't want this posting to get lost among hundreds of others.
post #4 of 7 Old 03-29-2012, 08:39 PM
marka2k
2006 WK
Dumb question but could the OPDA failure be attributed to dropping the three piston skirts?
I am asking because I do not actually know but am curious.
Thank you
marka2k is offline
post #5 of 7 Old 03-29-2012, 08:45 PM Thread Starter
Brian86992
Thank you
To be honest I'm not quite sure. I know that I drove for several thousand miles with a tick that I thought was a sticky lifter and turned out to be a piston skirt. The problem that prompted getting a new engine was a second, or third and more severe piston skirt being dropped resulting in a very noticeable knock.
Here's the tricky part with cause and effect... I don't know if the pistons broke and the shavings wore down the OPDA or the OPDA wore down, causing the pistons to break. I'm still not 100% sure of the cause of my broken pistons but I know that overheating, a cracked head that dumped coolant into the engine and moving to Indiana (exposing the engine to freezing temperatures for the first time) could all play a role.
post #6 of 7 Old 04-05-2012, 06:22 PM
willydigger
Awesome info. Thanks for the link on the main thread. I will add a link to the first page for easy reference. Very odd.
willydigger is offline
post #7 of 7 Old 04-05-2012, 06:28 PM
willydigger
Did it spin freely? Would you be willing to dissect it and take photos? How many miles were on the CPS?
Checking OPDA gear wear without removing OPDA BioTex TJ Wrangler Technical Forum 3 03-26-2012 10:13 AM
Opda help \\WK// TJ Wrangler Technical Forum 10 02-07-2012 01:16 PM
Opda Bigbob TJ Wrangler Technical Forum 16 11-26-2011 05:00 PM
Opda toyfarm TJ Wrangler Technical Forum 4 08-16-2011 08:03 PM
Opda, need help AliGndahouse TJ Wrangler Technical Forum 4 06-08-2011 11:37 AM
