OPDA/Camshaft Synchronizer shaft problem (TSB E05R) consolidated REGISTRY please sign - Page 4 - JeepForum.com
post #46 of 98 Old 02-08-2011, 12:48 PM
Skydiver1
I picked up a new "distributor" with a different kind of pick up. It is a stamped sheet metal that has a roughly 180 degree "blade" that gives the signal instead of a tone wheel. The gear looks and measures the same but I will blue it when I install it with a new stock grind federal mogul cam. I am curious to know what oils to use to break in this new set up and what is best to run in it forever after. Valvoline has VR1 10W-30 with ZDDP in it, but you can get a 4oz bottle of ZDDPlus to add to any oil (synthetic). STP has an oil treatment with ZDDP, but it is half a quart and thick as honey so I don't like that. I am sure I can just stick the new gear onto the shaft and run it since the cam shaft is not as bad as the OPDG, but then I am just delaying the inevitable.
Skydiver1 is offline
post #47 of 98 Old 02-08-2011, 01:49 PM
Heath
2014 JK Wrangler
If you are installing a new cam you will also need to install new lifters.
Heath is offline
post #48 of 98 Old 02-20-2011, 06:26 PM
uf20wop
1. 2006, Wrangler Sport, 50K miles, build date is early 06
2. Nothing major yet, buy definite wear on the gear.
3. Gonna try to wait it out and get a new OPDA when they come available and most likely fogmod it.
4. Cost of OPDA
5. No, out of warranty
uf20wop is offline
post #49 of 98 Old 03-01-2011, 03:11 PM
njseifrick
1. Year, model, mileage, and build date of your Jeep
*2006, LJ Rubicon, 18000, build date 3/2006
2. Brief description of the problem and any collateral damage. Please include pictures if available.
*Engine stopped running, towed to nearby dealer
3. Actions taken to fix the problem
*Diagnosed issue and replaced OPDA, oil pump, cam shaft, all tappets & all fluids.
4. Approximate cost of repair
* would not say . . .
5. Did Chrysler pay for or reimburse any of the repairs?
* repaired under extended warranty (less $100)
6. If Chrysler did pay, what steps were taken to make them pay
* nothing needed, still under warranty
7. Has the problem returned?
* not since repaired a year ago.
* update, 2/2013, 37500 miles, still ok, under service contract but still carry spare
* update, 6/1/2013 38,000 miles. Pulled to check-looks good so far. Image in main post. Just replaced with Dorman unit. Still carry a spare!
njseifrick is offline
post #50 of 98 Old 05-01-2011, 07:28 PM
GTGTrucks
2005, LJ Rubicon, 49653 Mile, build date March, 2005
Inspected after reading of problem of OPDA on this form and found scoring, heat damage, and gear wear
Cleaned and greased untill I could find a good solution.
Non yet, still investigating
GTGTrucks is offline
post #51 of 98 Old 07-05-2011, 07:38 AM
Onetype
1. 2005 LJ Rubicon 88,xxx Jan. 05
2. p0344 code the day I bought it while driving home. Pulled OPDA (Rev - E), worn more than it should be for such low mileage.
3. Ordered new OPDA to Fogmod
4. $120 (although it's just going to go bad again)
5. Haha!
7. It probably will, and then out will come the motor for 5.3
Onetype is offline
post #52 of 98 Old 07-05-2011, 08:32 AM
unlimitedlj
Man I a little worried about mine being more worn than normal. I have a 2005 but, the door jam says it was built in October of 2004 and the engine I think was assembled around June I think. Its crazy though because I have the same set up the 2005/2006's have but, have technically a 2004 Jeep. 85k nothing weird yet knocking on the biggest piece of wood I can find. I don't want to pull it just because I have heard of the sync being a little off no matter how you mark it. I heard the safest way is to sync it back with the DRB but, thats an easy 100 dollars. I have been using the VR1 10w-30 for the last year to help keep wear to a minumin. Does it usually start to make a squel noise or something?
unlimitedlj is offline
post #53 of 98 Old 07-05-2011, 08:38 AM
willydigger
The computer will self correct. I've had mine out half a dozen times with NO problems. I've swapped mine with a new one with only a sharpie and NO problems. My advice is pull it and check it.
It might not squeal or give any advanced notice. I don't recall for certain that in the cases of failure there was advanced notice. Mine squealed (thankfully), but if I were you I wouldn't wait for a squeal that may never come.
willydigger is offline
post #54 of 98 Old 07-05-2011, 01:57 PM
popeyesides
popeyesides's Avatar
2006 lj Rubicon. built November 2005. 12,500 miles
Worn drive gear after inspection
Took it to dealer and they replaced gear under $100 deductible.
$100 deductible Chrysler good guy warranty. Have dealer invoice.
No, I found out later I could of done my self for way cheaper, Chrysler made money off of me.
n/a
Have not checked it, did buy new OPDA just in case.
popeyesides is offline
post #55 of 98 Old 09-18-2011, 09:53 PM
tcmault
Let's keep this thread alive. I have not yanked mine yet and I am at 57k. Once I do I will return with my observations.
2006 AEV Unlimited Rubicon. Silver. 6-speed. 255/85R16. OME ZJ/LJ. Nth TT. Alloy Shafts.
tcmault is offline
post #56 of 98 Old 09-20-2011, 01:30 PM
Onetype
I've had my new new fogmodded opda in for less than 1,500 miles and i'm already having issues again. I'm right at 90k miles on my 05 LJ Rubi.
My guess : Cam gear was too far gone. I'm going to pull the opda out this weekend and inspect it.
I'm planning on trashing the motor next summer for an ls1 swap. I've been a happy owner of many Cherokee's, and I've never had the kind of issues this LJ has.
Onetype is offline
post #57 of 98 Old 09-20-2011, 02:11 PM
willydigger
Are you certain the OPDA was installed exactly the way it came out? Could it be off just a hair?
post #58 of 98 Old 09-20-2011, 06:53 PM
flying_bosun
2006 Wrangler Unlimited Rubicon, 60K mi. built June '06 (among the last to roll out of Toledo)
Laughing Monkey a couple of mornings, not diagnosed as OPDA for 100+ miles, engine shut down at 65mph, failed OPDA and damaged cam.
Shaft at upper bushing
Upper bushing and seal
OPDA shaft gear
Cam gear
Cam lobe (all lobes were similar and I have no way of knowing the relationship between their condition and the OPDA)
Replaced OPDA, then again 2k mi later when I replaced cam, lifters, etc.
Approximately $3500
They promised to cover 75% "as good will," then decided not to include either OPDA, the first dealer visit (where I went to have them inspect the cam gear and recommend to Chrysler that they should cover it) or any of the 18qts of VR1, bottle of break-in additive and 3 oil filters required for proper cam break-in. They shorted me about $700, as I recall. Glad they helped, but they didn't do exactly what they said they would do.
Contacted service writer at known customer service oriented dealer, explained entire OPDA thing to him, and asked if he would inspect it and help persuade Chrysler into helping. Paid for first OPDA "replacement" (I'd already replaced it, but they needed a service ticket in order to inspect and make a recommendation to corporate). Based on dealer inspection and service writer influence, they agreed to reimburse me 75% of the total cost (which, again, they did not)
Not yet (knock on wood)
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #59 of 98 Old 09-20-2011, 07:14 PM
Jeffro06
Jeffro06's Avatar
2006 Wrangler Rubicon, 31K mi.
Laughing Monkey a couple of mornings, hopped on JF right away, looking for the cause. Only put a few miles on it before doing the oil switch.
Complained to Jeep, got a new cam, complained to jeep somemore, got a new OPDA installed today @ 33089 miles.
$377.00 for OPDA
$43.50 for the install
$26.39 in taxes
Total cost to me: $445. 89 (Before refund from Jeep)
Covered the cost of the cam gear and got just about half my money back (IIRC) for the OPDA/install.
It all started with me contacting Jeep via the link on their web page, then it was several phone calls and e-mails with two different customer service reps.
Not yet.
Jeffro06 is offline
post #60 of 98 Old 09-21-2011, 08:34 PM
njseifrick
*2006, LJ Rubicon, 24,000, build date 3/2006
Decided to purchase a Chrysler extended warranty (5yr) to cover future costs of this opda failure. Have almost recovered the cost of the service contract with two axle u-joints and a front drive shaft. This Wrangler is the most unreliable vehicle I have owned in 50 years.
Camshaft Synchronizer issues....I think. jg928s4 TJ Wrangler Technical Forum 4 07-25-2010 09:18 PM
Clifford Performance camshaft for my 2.5L or just a regular camshaft? r_unda YJ Wrangler Technical Forum 12 04-20-2010 06:30 AM
Camshaft problem Cheater5 TJ Wrangler Technical Forum 8 01-31-2008 06:50 AM
Camshaft Position Sensor PROBLEM ??? gtospeeding TJ Wrangler Technical Forum 10 08-14-2007 01:58 PM
