-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   OPDA/Camshaft Synchronizer shaft problem (TSB E05R) consolidated REGISTRY please sign (http://www.jeepforum.com/forum/f9/opda-camshaft-synchronizer-shaft-problem-tsb-e05r-consolidated-registry-please-sign-1084723/)
schultzie 08-07-2010 04:46 PM
In an effort to assist me and others in battling Chrysler with the 4.0 ’04-’06 Oil Pump Drive Assembly (OPDA)/Camshaft Synchronizer shaft problem (TSB E05R), I propose that we start a “just the facts” registry. The thread to discuss the problems is http://www.jeepforum.com/forum/f9/ch...d-read-963235/
In this thread I’d like to limit it to:
1. Year, model, mileage, and build date of your Jeep
2. Brief description of the problem and any collateral damage. Please include pictures if available.
3. Actions taken to fix the problem
4. Approximate cost of repair
5. Did Chrysler pay for or reimburse any of the repairs?
6. If Chrysler did pay, what steps were taken to make them pay
7. Has the problem returned?
I’ll kick things off by claiming the #1 spot for defective Jeeps:
1. 2006 LJ, 61,000 miles, build date is late in the ’06 run.
2. OPDA gear abnormally worn at 61k:
http://a.imageshack.us/img832/2117/cp1sm.jpg
OPDA cam gear also abnormally worn:
http://a.imageshack.us/img199/3681/camgsm2.jpg
cam shot:
http://a.imageshack.us/img245/1117/lobesm.jpg
and a catastrophic lifter failure:
http://a.imageshack.us/img713/6736/liftersm.jpg
3. To be determined – The LJ is in pieces at an independent shop
4. To be determined – easily in excess of $1,000 plus car rental
5. To be determined
6. N/A
7. N/A
Savage1969 08-08-2010 07:27 PM
  • 2006 TJ, 20,600 miles, build date 12/05, engine date stamp 512MX07
  • Excessive and abnormal wear of the OPDA gear and camshaft gear, eminent failure is certain.
  • TBD, problem just discovered today
  • TBD, will update as necessary
http://i33.tinypic.com/35ldi60.jpg
http://i33.tinypic.com/efnl2q.jpg
http://i33.tinypic.com/1znpmxl.jpg
http://i37.tinypic.com/b4ga5l.jpg
jdhutch 08-09-2010 09:09 AM
2006 lj rubicon. built november 2005. 42k miles
worn distributor gear (uneven with striations). scored shaft. slight wear on oil pump drive tang edges.
installed crown automotive distributor gear @42k miles
$35 + sweat & frustration (the new gear fit tight and drilling out for the pin was a bear with a hand drill)
didn't try since it didn't seem worth the extra aggravation
n/a
n/a
Volusiaguy 08-09-2010 10:22 AM
2006 TJ X. built December 2005. 22k miles
installed crown automotive distributor gear, polished the shaft, and installed a 45 degree zerk fitting at the factory grease point @22k miles
$75 (32 for gear kit from Chrysler, 40 for machine shop, + sweat & frustration of running around for a week's vacation taking care of this.
Nope..out of warranty and they stopped returning my calls with no follow-up.
n/a
Not yet. Seemed to be a decent fix, but I traded in the Jeep yesterday for a Nissan Titan 4x4. This was my 5th Jeep, but I will probably not be purchasing any more.
DstroyrOfWrldz 08-10-2010 01:29 PM
2005 Unlimited, 54k miles, Assembled April 2005. Motor built March 2005, OPDA built March 2005.
Visual indicators of accelerated gear wear. No drivability symptoms or other damage.
http://i108.photobucket.com/albums/n...p/IMG_0812.jpg
http://i108.photobucket.com/albums/n...p/IMG_0811.jpg
TBD
TBD
TBD
TBD
TBD
chutta 08-12-2010 08:44 AM
'05 at 68k. Removed to inspect, promptly messed up timing. Took it back for alignment. Dealer ordering gear(striations), claiming cam gear to be good. On top of the 35, I think I'm riding a time bomb that will need frequent inspection
roadkill 08-12-2010 09:13 AM
06 LJ, 21,000 miles. had the laughing monkey noise. took it to dealer under warranty they diagnosed as a belt noise and replaced belt. I ordered OPDA on my own and replaced it. upper bushing was shot as well as striations in gear. Chrysler reimbursed me for the part upon calling and sending in receipts. leery about how long new part will last.
FlynG 08-12-2010 09:23 AM
How long did it take to get the OPDA in?
I was under the impression these had a long back-order going...
Flyn G
roadkill 08-12-2010 09:37 AM
took about two weeks (ordered online) but this was last October and I assume before the big national backorder
FlynG 08-12-2010 09:58 AM
OIC, thanks.
Flyn G
psouza1943 08-12-2010 10:21 AM
Opda
As of yesterday, at 10:00 AM, there were 8 units in the LA warehouse.
crusty1007 08-12-2010 10:59 AM
1. Year, model, mileage, and build date of your Jeep;
2004 Rubi BD: 04/04
First engine @ 37K (lasted 37K)
2nd @ 68K (lasted 31K miles)
3rd currently has approx. 37K
Current mileage on whole vehicle, 105K
I have not been able to verify this via hands on but techs have told us that it is cam failure. I have been told that each time the gear went bad that also a cam lobe was wiped out & the lifter worn off.
I don't see how one has anything to do with the other, unless the pump is having an issue causing it to lose oil pressure?
3. Actions taken to fix the problem:
R&R complete long block, replace cats.
Warrantied for $100.00 each time & many phone calls to DC.
Parts but not fuel for towing.
6. If Chrysler did pay, what steps were taken to make them pay;
Yes 3 times, its now out of warranty & is starting to come apart again.
I guess this time, I'll figure out what the cause is.
RockyMnt1 08-12-2010 12:42 PM
I hope that this helps someone.
I orderd my Oil pump/drive assembly (P/N 53010624-AC) on 8/5/10, just to have a spare around. It arrived today, so it seems that the backorders are being worked. Cost was $198.67, but, hey, that included a $5.99 gasket!!
No help for me (out of warranty). I asked the parts guy to let his management know that this issue is costing Jeep customers.
anymanusa 08-12-2010 01:48 PM
2005 TJ rubicon. 86k miles
installed 4wd automotive distributor gear @86k miles
told me to go **** myself.
n/a
n/a
fixed for my scenario.
takao 08-13-2010 01:51 PM
2006 TJ rubicon. 39k miles
Just noticed packed in grease for now, awaiting ideas.
dna
dna
dna
n/a
sorry cheap cell phone camera... any body has ideas this my DD Help....
BTW it's not worn due to lack of lubrication and it was soaking in oil and it has been parked overnight before removal..
http://i243.photobucket.com/albums/f...3/SSPX0898.jpg
The time now is 01:36 AM.
