only one headlight - JeepForum.com
post #1 of 14 Old 04-13-2006, 01:49 PM Thread Starter
UNCLEBRO
only one headlight
just one of my headlights work when turned on, but they both work with high beam.
fuse maybe?
if so, where is the fuse located for that?
i can't seem to find it.
thanks very much for any help.
steven
UNCLEBRO is offline
post #2 of 14 Old 04-13-2006, 01:50 PM
jb1dsl
Just the low beam has blown, you will need to replace the light
Back in a Jeep again. Sorry I left for a bit.
jb1dsl is offline
post #3 of 14 Old 04-13-2006, 01:50 PM
stathunter
sounds like bulb
stathunter is offline
post #4 of 14 Old 04-13-2006, 02:14 PM
Muddy Tj Zack
Low beam and High beams are 2 seperate filiments inside the bulb. Your low one is blown
'97 Tj Sport, 4.6L Stroker, 5-Speed, 4-in suspension lift, 35" TrXus M/t's, Dana30/Ford 8.8 w/ Aussie Locker, Teraflex ExtremeShort SYE, custom front and rear bumpers, Flowmaster Off-road Series, and a bunch of other goodies........MoPar or No-Car!!!
Muddy Tj Zack is offline
post #5 of 14 Old 04-14-2006, 10:06 AM Thread Starter
UNCLEBRO
Thanks for the help.
Now, is it an easy straight forward job to replace or do I need professional help?
UNCLEBRO is offline
post #6 of 14 Old 04-14-2006, 10:09 AM
RockRunner85
You need a torx 15 screwdriver (almost positive on the size). You remove the 3 torx bolts on the chrome beauty ring around the headlight. Then there was a few more torx bolts holding the headlight in. After that its just a matter of unplugging the wiring harness on the back of the bulb (open hood for this) and reversing the process.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
RockRunner85 is offline
post #7 of 14 Old 04-14-2006, 10:09 AM
abnormal
Platinum Member
abnormal's Avatar
Just remove the screws holding the ring in and then the screws holding the light in. Simple.
abnormal is offline
post #8 of 14 Old 04-14-2006, 11:15 AM Thread Starter
UNCLEBRO
all changed out and looking good.
and only $14.99
thanks again for your help.
UNCLEBRO is offline
post #9 of 14 Old 04-14-2006, 11:26 AM
Polaris
Polaris's Avatar
I hope you changed both at the same time. They're meant to be replaced in pairs because as they age they yellow and dim.
BTW you should have went with Silverstars
2000 TJ Sport, 3-speed slushbox
HP30, ChroMoly shafts, Ford 8.8 rear, 4.10s 35s
ORIGINAL Black Jeep Club Member #34
Polaris is offline
post #10 of 14 Old 04-14-2006, 11:32 AM
masetj
I agree with Polaris on the Silverstars. Just replaced mine and they look and project much better than I expected for only $24 a peice! Probably the best mod-for-the-money I've spent yet. Besides the custom hand throttle that was only $2
masetj is offline
post #11 of 14 Old 07-13-2013, 01:06 AM
coveredntatts
I have the same issue with my 02 Sahara and replacing the bulb didn't fix it. Any suggestions?
coveredntatts is offline
post #12 of 14 Old 07-13-2013, 06:52 AM
GringoLoco
GringoLoco's Avatar
If you don't have low beam on only one side even with new bulbs, I'd suspect the wiring, probably right at the plug, is broken or loose. Try wiggling the wires around at the plug. You might end up needing to replace the plug.
YELLOW Jeep Club Member #5606
13 mpg - edit: 12 mpg
No hi-lift on the hood (yet)
Odd noises
Still can't get it to take off from a treadmill....
GringoLoco is offline
post #13 of 14 Old 07-13-2013, 07:54 AM
steamnsteel
Go and get another headlight, I blew one last summer and two bulbs later I had a good one. I even tried plugging it in to the other side thinking something had happened to my wire plug while doing the change.
Use the Silverstars they are a great improvement over the factory bulbs.
2006 LJ Rubicon 6 speed: Currie arms, Currie Track Bars (They don't hit either), Nth tuck, Nth Springs and oil pan skid, JKS mml, bml, Antirock.
I un-insatalled the wife mod.....lost one Jeep.
steamnsteel is offline
post #14 of 14 Old 07-13-2013, 09:58 AM
DKenyon28
DKenyon28's Avatar
One Headlight is my favorite Wallflowers song.
DKenyon28 is offline
help with headlight bdhawk TJ Wrangler Technical Forum 2 11-10-2009 01:34 PM
Need Serious Headlight Help!! MuddyWrangla YJ Wrangler Technical Forum 4 01-16-2005 12:25 AM
Headlight ON then OFF JeepDrivr93 YJ Wrangler Technical Forum 4 10-17-2004 11:27 AM
Headlight aim Digitalchaos TJ Wrangler Technical Forum 18 12-29-2002 10:14 PM
Headlight Help jfarrell YJ Wrangler Technical Forum 3 04-06-2002 11:37 AM
