Which one will stick out further? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Which one will stick out further?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBds fox ipf 2.0 racing series shocks now available at rockSpartan Lockers FREE SHIPPING Excellent Prices
Unread 08-04-2007, 02:55 PM   #1
gsxr150
1) -38 backspacing, 4 inch backside
2) -46 backspacing, 3 5/8 inch backside
I can't seem to figure out this whole wheel shopping thing...what wheel will stick out further?
gsxr150 is offline   Reply With Quote
Unread 08-04-2007, 02:59 PM   #2
Alcoholcamel
Here's a good site for info...
https://www.rsracing.com/tech-wheel.html
'05 Rubicon
4" FT Performance Lift, SRS Front/Rear Bumpers and Side Steps,
Pro Comp Series 7005 17x8s w/ Pro Comp Xtreme M/T 33s
Alcoholcamel is offline   Reply With Quote
Unread 08-04-2007, 03:02 PM   #3
gsxr150
Thanks, that's helpfull, but I'm confused with the different backspacing vs. backside measurement.
I hope there is a pro here that can tell me at a glance, which wheel will stick out further.
Unread 08-04-2007, 08:34 PM   #4
spyderbyte
I think you meant to say
1) -38 offset, 4 inch backspacing
2) -46 offset, 3 5/8 inch backspacing
in which case wheel 2 will stick out farther. (3/8" farther)
Most stock wheels have 5.5" of backspacing, the smaller the number, the farther the wheel sticks out.
Spyderbyte
Go with quality and cry once. Go cheap and cry often.
Originally Posted by Willys2004
Better to live with a little honor and class than die with a few extra greenbacks in your pocket.
spyderbyte is offline   Reply With Quote
Unread 08-04-2007, 09:04 PM   #5
jdragger
Offset is the distance from the center of the wheel to the surface that mounts on to the hub. Backspace is the distance from the inside edge of the wheel to the mounting surface. Offset can be positive or negative.
jdragger is offline   Reply With Quote
Unread 08-04-2007, 09:44 PM   #6
dirtbagofva
2010 JK Wrangler
Pos/Neg refers to form equal...4 back 4 foward is 0 back spacing or 4"s. if it a 10" rim it has 4" back spacing it is also refered to as 1" (+/-) not really sure. Generally jeeps wheels are refered to by the back spacing number and the width.
"It is a damned poor mind indeed that can't think of at least two ways of spelling any word."
Proud owner of 2010 JK, 1994 XJ and an 81 CJ-7
dirtbagofva is offline   Reply With Quote
Unread 08-04-2007, 09:57 PM   #7
gsxr150
Thanks guys, so they are very close...
Unread 09-05-2007, 01:48 PM   #8
Roughneck
I think I see a problem with that diagram. If you click on "How to measure backspacing & offset". They state the rim width is from between the bead seats. When it's actually the overall width, measured from the flanges. Theirs would throw you off about 1/4" - 1/2"
2006 Rubicon Unlimited
Wranglers lead the way. I mean, Rangers lead the way!
Roughneck is offline   Reply With Quote
Unread 09-05-2007, 02:03 PM   #9
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Originally Posted by Roughneck
...They state the rim width is from between the bead seats. When it's actually the overall width, measured from the flanges. Theirs would throw you off about 1/4" - 1/2"
Wheel width is measured between the bead surfaces, not to the outside of the wheel.
This is why a 8" wide wheel with 4" of backspacing does not have 0mm offset. Instead it has -12mm offset, which is the 1/2" difference caused by the thickness of the bead mounting surface.
Wheelin98TJ is offline   Reply With Quote
Unread 09-06-2007, 08:35 AM   #10
Roughneck
Yeah, I got corrected. I was confused on where the wheel width is measured from. It is between the bead surfaces, backspacing is measured from the rear flange.
cheers, LT
