one ton swap - JeepForum.com
post #1 of 39 Old 03-26-2013, 12:03 PM Thread Starter
jeeperz258
one ton swap
what would be the best one ton axles to swap into a tj wrangler???
jeeperz258 is offline
post #2 of 39 Old 03-26-2013, 12:14 PM
tyvanwie
Ones that do what you need them to. Might wanna start doing some research.
Sent from my iForum using JeepPhone
tyvanwie is offline
post #3 of 39 Old 03-26-2013, 01:38 PM
happymudder10
The easiest would be a Dana 44 from a TJ. But that is not a 1 ton axle.
The cheapest would be a Chevy 14 bolt in the back and a Ford Dana 60 in the front. If it were me, I'd leave them full width. Now realize, with the pumpkins hanging as low as they do especially on the 14 bolt, you need to run at least a 37" tire for clearance on the trail.
Just a traveling cat in a tall black hat riding a goat. Nothing to see here.
happymudder10 is offline
post #4 of 39 Old 03-26-2013, 01:44 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Best axles depends on your plans. As stated 1 tons require a decent tire. Steering will also need upgraded too.
RnEmOvr is offline
post #5 of 39 Old 03-26-2013, 01:48 PM
Jeepin72
Get some Dynatrac's! Otherwise there a number of options.
Jeepin72 is offline
post #6 of 39 Old 03-26-2013, 02:08 PM
NotURMailman
NotURMailman's Avatar
Best how?
What is your goal tire size and usage?
You want easy bolt in axle for 38" tires? Get some Currie RokJocks..
More info is needed as to your goals and skill set.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #7 of 39 Old 03-26-2013, 02:11 PM
SCchillipepper
40 spline Nine inch Spyder9, ruffstuff or diamond axle fab housing, Front ARB rear spool, 300M Shafts, Mega Hi9 Front, your choice rear drop out.
1998 TJ 35's Metalcloak Front Fenders 3" Currie Springs 4.88 Spartan Rear D44 front HPD30 under construction.
SCchillipepper is offline
post #8 of 39 Old 03-26-2013, 02:14 PM
NotURMailman
He didn't mention if he had recently won the lottery
post #9 of 39 Old 03-26-2013, 02:15 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
I like the way you think. but why cheap out so much with the RuffStuff housing, why not go with Overkill Engineering Atomic Axles?
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #10 of 39 Old 03-26-2013, 02:19 PM
SCchillipepper
He said best I just got carried away 78-79 Dana 60 front and 14 bolt rear. 14 is strong and as long as u run 40s you'll have the clearance. 60 good size and 35 inners 30 outers.
post #11 of 39 Old 03-26-2013, 02:35 PM
biffgnar
biffgnar's Avatar
What about the Dynatrac/Mopar Portals?
biffgnar is offline
post #12 of 39 Old 03-26-2013, 03:10 PM
SCchillipepper
Eh no 40 spline
post #13 of 39 Old 03-26-2013, 03:18 PM
biffgnar
biffgnar's Avatar
Eh no 40 spline
I'll settle for 35/41 combo for the extra clearance of the portals
biffgnar is offline
post #14 of 39 Old 03-26-2013, 07:14 PM
rckchucker
If you run anything smaller than a 40 with a 14 bolt you will drag it over everything. And you still will with 40's. Contrary to popular belief, the 78-79 D60 sucks in a TJ. Certainly there is more room to put a spring perch if you are running coils, but the pumpkin is so centered that you will run into issues with driveshaft clearance and the axle getting into radiator hoses. Your uptravel is more limited that with other front 60's. I have put the late 80's and early 90's Ford king pin 60's in TJ's and they work better. There is still plenty of room to put in a coil bucket. And unless you are breaking parts every time you go out, why get one tons? They are heavy. Your Jeep will be less streetable and your gas mileage will go down. They aren't cheap either. Teraflex, currie and dynatrac all offer bolt in 60's for a TJ and they are pricy, but unless you can do your own work setting up gears, lockers, and brackets, a set of junk yard one tons is not much cheaper.
That said. I'm part of the DD one ton club and I would never go back. My poor Dana 30 (RIP) couldn't handle what I threw at it. Do some research. Google Ultimate wrangler build up and swaps thread to keep you busy from now until your old.
rckchucker is offline
post #15 of 39 Old 03-26-2013, 09:45 PM
rda616
I like the sterling 10.25" over a 14 bff. Slightly less ground clearance then a 60, but much more then the 14 bff. You can also get a newer 10.5" with disc brakes, but need to have it drilled for the 8 on 6.5 pattern due to it being metric. The 05+ super duty 60 came with 35 spline outers as well, so it's a good one if you want to spend the coin. If it were me it would be front and rear ford 9" up to 40" tires. 35 down would be what I have now.
rda616 is offline
