One person spring removal/install - JeepForum.com
post #1 of 22 Old 03-15-2007, 09:20 AM Thread Starter
Snuffster
Looking for tips. I will be removing my 4 inch OME springs, and switching them to opposite sides for reinstall (don't ask lol). When I originally installed them I had a buddy help me. It was a two man job wedging those things over the lower spring perch, even with the opposite side of the axle jacked up all the way. I will have to do this by myself this time, and really don't want to have to use spring compressors. I was thinking about using the factory bottle jack between the lower shock mount and the frame to give more clearance. Thoughts?
'01 Wrangler Sport 4.0l, 4 inches and 33's
'99 Trans Am 427ci
'05 GTO stock
Originally Posted by LandRover
That was my master's degree talking.
Snuffster is offline
post #2 of 22 Old 03-15-2007, 09:24 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Just did a 4" lift installation for a friend last weekend with no real problems with the springs. Just remember to unbolt the shocks, antiswaybar links, and the TRACKBAR.
Getting
Jerry Bransford is online now
post #3 of 22 Old 03-15-2007, 09:25 AM
JeepinYahoo
JeepinYahoo's Avatar
1977 CJ5
A good prybar sometimes works to coax the spring into position if they are still being stubborn.
'77 CJ-5---'63 Scout 80 FOR SALE---'71 Scout 800B---'78 F-250 Camper Special---'75 Econoline 100
JeepinYahoo is offline
post #4 of 22 Old 03-15-2007, 09:27 AM
Jerry Bransford
Administrator
Absolutely and a very good suggestion, I forgot to mention that my prybar got a good workout last weekend doing just that.
Getting
post #5 of 22 Old 03-15-2007, 09:29 AM Thread Starter
Snuffster
When my buddy and I installed the springs, I was working a loooong prybar while he pushed on the spring. With the both of us, it was still a PIA getting them on there. I'm just trying to see how I can get that spring perch about 1 inch lower than I was able to get it before.
'99 Trans Am 427ci
'05 GTO stock
post #6 of 22 Old 03-15-2007, 10:17 AM
Crashnburn80
Crashnburn80's Avatar
It helps to remove the bumpstops and install them after you put the springs on. I found it to be much easier that way. If you take off the bucket that holds the actual bump stop, make sure it is inside the spring before securing the spring in place, the bumpstops can be wedged through the spring, but I doubt the buckets can.
Crashnburn80 is offline
post #7 of 22 Old 03-15-2007, 10:23 AM Thread Starter
Snuffster
Hmmm, I didn't think of that. One of those "why didn't I think of that" moments Thanks.
'99 Trans Am 427ci
'05 GTO stock
post #8 of 22 Old 03-15-2007, 11:34 AM
Metal
Metal's Avatar
I don't condone this practice but, I have used 2 ratchet straps to compress the springs. Works great, just a little scary to release them.
04 Unlimited, lifted, locked, 37s, etc.......
Originally Posted by mrblaine
Quit overthinking the lockers. Either get real lockers or forget it, 99 percent of everything else is just mental masturbation for the sake of discussion.
Metal is offline
post #9 of 22 Old 03-15-2007, 11:45 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
You can also use a bottle jack between the frame and axle to help push the axle down a little further.
Wheelin98TJ is offline
post #10 of 22 Old 03-15-2007, 11:48 AM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
or stand on it like i did
RnEmOvr is offline
post #11 of 22 Old 03-15-2007, 11:49 AM
Jerry Bransford
Administrator
And insert the spring while you're standing on the axle?
Getting
post #12 of 22 Old 03-15-2007, 11:55 AM
RnEmOvr
RnEmOvr's Avatar
i stood on the knuckle and slid spring in, but i did have spring compressors
RnEmOvr is offline
post #13 of 22 Old 03-15-2007, 12:02 PM
Jerry Bransford
Administrator
... but i did have spring compressors
Oh well there you go, that's about the only way I can see that happening then.
Getting
post #14 of 22 Old 03-15-2007, 12:08 PM
RnEmOvr
RnEmOvr's Avatar
you always want all the details, could be done with 2" springs as well
RnEmOvr is offline
post #15 of 22 Old 03-15-2007, 01:24 PM
devilishred
thgats how i got mine in, a little "leg" work, know what im sayin..
2001 TJ SPORT 5spd, 4.0
4.5 RE short arm, 1" BL, Daystar upper arms, mile marker 10.5 hydraulic, 33x12.5 TrXuS MTs some other stuff.........and lots of tools.
devilishred is offline
Hardtop Removal/Storage Solution - One Person Operation DeepSky JK Wrangler Technical Forum 42 11-30-2011 06:42 PM
Single Person JK Hardtop Removal?? Corleone JK Wrangler Technical Forum 39 06-22-2010 03:14 AM
Quick Spring Removal Question b3x TJ Wrangler Technical Forum 3 02-04-2010 09:09 AM
spring eye frame bolt removal johnroot01 YJ Wrangler Technical Forum 3 08-10-2009 10:05 AM
rear spring removal bfolla06 TJ Wrangler Technical Forum 2 01-16-2009 04:18 PM
