The "One-Millionth" Can My Jeep Handle 35's? - JeepForum.com
post #1 of 16 Old 07-11-2010, 06:32 PM Thread Starter
JeeperFound
I am currently running 33" tires and have had no problems or worries from day one. But a friend of mine wants to trade his 35" tires for my 33" tires. I think I wheel the **** out of my Jeep but I'm pretty conservative with it. I don't try stuff I think I'll break something on. Do you think my locked D30 and my chromalloy/locked d35 will handle them?
Thanks in advanced!!!
My daughter just asked me if I can buy a motorcycle when I'm done with my Jeep!!
JeeperFound is offline
post #2 of 16 Old 07-11-2010, 07:30 PM
fang_x
my friend ran 35s on his stock axles. was fine for minor offroading, and going through mud!
'98 TJ Manual -2.5" rcx long arm on 31
'99 Xj, Stock on 30"
'86 Monte Carlo 357 stroker. 450hp.
fang_x is offline
post #3 of 16 Old 07-11-2010, 07:39 PM
Fropleyqk
Fropleyqk's Avatar
You should be OK but you already know the answer to your question. Theyre more likely to break than upgraded axles. Some will chime in and say theyve wheeled for years and had no problems, others will tell stories of exploding axles. And then everyone will start arguing about the 8.8 being stronger than the 44. Just like the other million threads about the same thing. The end.
Fropleyqk is offline
post #4 of 16 Old 07-11-2010, 09:09 PM
dbshea
If it's the millionth time, why not check what other members are running in previous posts? Like every other post will say, yes and no. You can but it's not recommended. I ran 35s cautiously until my 8.8 was finished. If your brakes and wallet can handle the worst possible outcome then go for the swap.
dbshea is offline
post #5 of 16 Old 07-11-2010, 09:56 PM
UltimateCC
i ran 35s on a locked dana 30 for 3 weeks of wheeling and it broke...before that i had done 6months straight of wheeling (every weekend) without a single broken part...
UltimateCC is offline
post #6 of 16 Old 07-11-2010, 11:58 PM
RaggedOleMan
Is your Superior CCE + Detroit the 30 spline variety? If so, it's my understanding the odds are in your favor to run 35's. If it's the 27 spline & the lunchbox Detroit, it's my understanding the odds are against you on 35's...
I'm about to install a Superior CCE (27 spline) with a PowerTrax, (sitting on the work bench...) and have been advised by someone I trust on the matter not to run 35's with that set up.
RaggedOleMan is offline
post #7 of 16 Old 07-12-2010, 02:12 AM
never monday
within seconds of installing 35" tires on a stock TJ it will explode in a ball of flame, roll out of you driveway as the parking brake cable melts. Crash into a bus ,loaded with nun's and children. Thus rendering you Jeepless, broke and sad.
never monday is offline
post #8 of 16 Old 07-12-2010, 02:19 AM
AlexGeorgakis
Why? that would be funny!
AlexGeorgakis is offline
post #9 of 16 Old 07-12-2010, 02:25 AM
never monday
Originally Posted by ageorgakis View Post
Why?
post #10 of 16 Old 07-12-2010, 02:59 AM
Lemmiwinks
The more important question here is. Why would you buddy want to trade 35" for 33"s? Is the remaining tread the same?
I am on 32' new mt/r's and so far more than once I have been able to crawl without getting stuck while watching a couple of guys on 35's get stuck. It's not about bigger tires, it comes down to ability.
Just my $0.02
Lemmiwinks is offline
post #11 of 16 Old 07-12-2010, 04:13 AM
Fropleyqk
Fropleyqk's Avatar
/thread. next.
post #12 of 16 Old 07-12-2010, 08:05 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
I've always run 35's with an open diff.I wouldn't do it on a locked d35.
TheBoogieman is offline
post #13 of 16 Old 07-12-2010, 08:12 AM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
i would stick to the 33's.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #14 of 16 Old 07-12-2010, 10:05 AM
Apex
Recon death squad
Apex's Avatar
Nope, won't work.
the other 999,999 people who asked took all the luck from you. Sorry.
Apex is offline
post #15 of 16 Old 07-12-2010, 11:06 AM
rs4race
You might be able to pull it off. I have been wheeling on d30/d44 combo locked front and rear and havent had a problem with the d30 breaking. Sometimes I take the harder lines too. Im generally a lucky guy tho, and plan on putting alloy shafts in the d30 or upgrading it.
How about a little more info on your d35? With alloy shafts and new gears that are properly set up you might be able to pull it off. There are a couple people running a super 35 and claim they run some rugged stuff and dont have problems.
I almost went with a super 35 kit, but in the end I built a d44 with alloy shafts so I wont have to constantly worry about when it will break...
My Build
http://www.jeepforum.com/forum/f22/rs4races-build-957569/
rs4race is offline
35" , tires , handle , axles
Flex pics needed - Currie A/R with 4.5" RE springs, 10" shocks, RE long arms on 35's. VanBCguy TJ Wrangler Technical Forum 4 04-26-2010 01:55 AM
6" lift or 4" and 1" body for 35's? leukus TJ Wrangler Technical Forum 17 04-19-2009 08:02 PM
Smoothest "daily driver" lift to run 35's? silvel2edge JK Wrangler Technical Forum 7 04-14-2009 12:04 PM
Jeep Jamboree Murphy NC (Stock TJ w/ 31" tires handle it?) BRS1998 TJ Wrangler Technical Forum 16 09-23-2008 03:16 PM
need the "seat forward" knob / handle thingy CB4 TJ Wrangler Technical Forum 5 12-02-2007 02:48 PM
