One inch body lift and auto Trans ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > One inch body lift and auto Trans ?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFree Shipping on Soft ShacklesNew! JK/U skid plate system.
Unread 04-17-2015, 08:58 AM   #1
1398653
I put a 1.25 inch body lift and 1 inch mml on my TJ and MML was a pita due to A/C. I didn't need to mess with transfer case linkage or fan shroud.
On my LJ I want to put on a one inch body lift but NO MML. Will I need to mess with transfer case linkage with one inch? I figure I will need to mess with fan shroud. If so on the transfer case linkage, it is difficult?
Steve, Olean NY, 2004 TJ Rubicon & 2006 LJ Unlimited
1398653 is offline   Reply With Quote Quick reply to this message
Unread 04-17-2015, 09:03 AM   #2
Jeepsr4me
Get under there and look at how the linkage attaches to the body.. its part of the shaft pivot. The body lift should come with a lowering bracket you put on to lower that pivot down a little.
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread 04-17-2015, 09:11 AM   #3
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The tcase shifter mechanism is normally ok with a 1" or 1.25" body lift. I've run two TJs with 1" body lifts without the tcase shifter binding.
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote Quick reply to this message
Unread 04-17-2015, 09:14 AM   #4
atomant1
Junior Member
atomant1's Avatar
what is MML?
atomant1 is offline   Reply With Quote Quick reply to this message
Unread 04-17-2015, 09:16 AM   #5
Jerry Bransford
Administrator
Originally Posted by atomant1 View Post
what is MML?
Motor Mount Lift.
Getting Savvy...
Unread 04-17-2015, 10:19 AM   #6
1398653
Thanks Jerry, I wont worry about it then unless I have a problem with shifting in 4wd hi and low
Unread 04-17-2015, 10:45 AM   #7
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Originally Posted by jerry bransford View Post
the tcase shifter mechanism is normally ok with a 1" or 1.25" body lift. I've run two tjs with 1" body lifts without the tcase shifter binding.
x 2.
When I had 3.07s I would draft behind birds as an attempt to do the speed limit.
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 04-17-2015, 12:11 PM   #8
atomant1
Junior Member
atomant1's Avatar
Originally Posted by Jerry Bransford View Post
Motor Mount Lift.
Thanks Jerry, I think you answered that one for me before, but it keeps eluding me every time I see it.
Unread 04-17-2015, 07:55 PM   #9
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
When you install the body lift be sure to place the transfer case shift lever in neutral and you'll probably need to adjust it when you're done... HTH
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote Quick reply to this message
