Onboard Misting System - Page 3 - JeepForum.com
post #31 of 57 Old 05-08-2007, 02:43 PM
ThUmPeRcOn
You could have a wet t-shirt contest in your Jeep....a couple of honeys and wet mist
ThUmPeRcOn is offline
post #32 of 57 Old 05-08-2007, 03:28 PM
UTmike
UTmike's Avatar
You'll have to excuse my ignorance on the wiring. But why do you need to use a relay? Why can't you run from the battery, to the switch, straight to the pump? This sounds like a great idea and I'm definitely going to be trying it soon. Thanks for the nice write up.
4.5" RE Long Arm, 37" Mud Grapplers on Beadlocks, OX Locked Dana 60s front and rear
UTmike is offline
post #33 of 57 Old 05-08-2007, 03:49 PM
92blazn
92blazn's Avatar
2010 JK Wrangler
Originally Posted by stogie25
The expensive part is the pump. The Jerry can is not real cheap either. The rest is very inexpensive.
PARTS LIST APPROXIMATE PRICE
2 misting nozzles $10.00 at hardware store
1 RV water pump. 12V. 40psi. $130.00 from an RV shop
1 relay $5.00 from Radio Shack
1 switch $2.00 from Radio Shack
14g wire $400 from hardware store
loom $5.00 from auto parts store
inch ID hose $6.00 from auto parts store
inch ID hose $5.00 from auto parts store
Jerry can $40.00
hmmm I like this idea
Tx and 100+ deg weather and humidity making it 120+ might come in real handy with top off ,
Thanks
2004 TJ (SOLD), 2010 4 Door 4x4 JK , 99 TJ , 99 WJ
Originally Posted by The Mean Fish
I'm not actually going for the wheeling, I just want to watch Ed drive his Jeep. :o
92blazn is offline
post #34 of 57 Old 05-08-2007, 03:50 PM
zman
Originally Posted by 5artist5
Yes! Have them spray acid at the passengers if they do not entertain you! Or you could use it to threaten kids into behaving! For that matter you could use it as a mobile interrogation vehicle.
You unscrew the tips and soak them in a small cup for a couple minutes to remove the calcium.
zman
1995 YJ on 40's * 2002 TJ on 37's * 2003 TJ on 33's * 2011 WK Larado X w Hemi
zman is offline
post #35 of 57 Old 05-08-2007, 03:53 PM Thread Starter
stogie25
stogie25's Avatar
The pump draws 7A when running. I chose to use a relay to keep that current between the battery and the pump, and a low current line from the ignition for the switch.
Jarhead Jeep Club
O|||||||O
97 Black TJ (one owner), BFG KM2 35s, 4.7L Stroker, ARB's, Dana60 rear, Dana30HP Front Warn manual hub conversion, 6 inch mostly Tera long arm lift. Rhino lined tub. Allied Rock 8 beadlocks. Tera-Low 4:1. Sanden OBA. Sniperfab tube fenders.
My Build Thread
stogie25 is offline
post #36 of 57 Old 05-08-2007, 09:51 PM
UTmike
UTmike's Avatar
Did you use any fuses in the circuit? And if so where?
UTmike is offline
post #37 of 57 Old 05-08-2007, 10:46 PM Thread Starter
stogie25
stogie25's Avatar
I fused the main power to the pump, and I fused the switch.
Jarhead Jeep Club
O|||||||O
My Build Thread
stogie25 is offline
post #38 of 57 Old 05-09-2007, 08:37 PM
UTmike
UTmike's Avatar
I've got my pump and wiring, just waiting on the nozzles to get here. I think I'm going to install it on the vertical wall of this hidden area.
http://www.jeeps4ever.com/Jeepin_Roc...20Solution.htm
But instead of cutting out the tub, I'll go up from behind the wheel well and drill a small hole ontop by the roll bar for the 1/4" tube. What I'm curious about is how bad does this thing vibrate, and how loud does that make it?
UTmike is offline
post #39 of 57 Old 05-09-2007, 09:43 PM Thread Starter
stogie25
stogie25's Avatar
Would that I had this installed the day this was taken.
Name:  JeepsatHooters May2005 3.jpg
I hear the pump a little when it is running, but no vibration. Mine is mounted on an L bracket to the inside bolts that hold the PSC corner armor on.
Jarhead Jeep Club
O|||||||O
My Build Thread
stogie25 is offline
post #40 of 57 Old 05-10-2007, 08:40 PM
Dogman
Dogman's Avatar
Stogie, got the nozzles today - thanks! What a nice guy
Question about the pump: do they have a pressure switch and cycle on and off? Just curious...
John 3:17
Dogman is offline
post #41 of 57 Old 05-10-2007, 09:09 PM Thread Starter
stogie25
stogie25's Avatar
I am glad the nozzles got there.
There is a switch on the pump that has no user interface, so I assume that it is a pressure or a heat switch. Today I was using it, and found that I only use it for a few seconds at a time. I think I am going to make my switch a momentary-off-on switch. I might put the momentary on a timer circuit of about 7 seconds. I have not ran the pump long enough to get hot or turn itself off.
Jarhead Jeep Club
O|||||||O
My Build Thread
stogie25 is offline
post #42 of 57 Old 05-10-2007, 09:18 PM
Dogman
Dogman's Avatar
Let me know if you work that out. Thanks again.
John 3:17
Dogman is offline
post #43 of 57 Old 05-11-2007, 03:07 PM
UTmike
UTmike's Avatar
This is a great idea and wanted to thankyou for the idea and write up again. I just pretty much finished mine today...took about 6 hours. I mounted the pump in the cavity behind the rear passenger wheel well(I posted a link to a web site explaining the location earlier). I didn't cut into the tub, but instead pulled the lining from the wheel well down so I could reach up into the space. This pic shows the 4 bolts going through the wheel well, holding the pump on the other side of it.
This is a picture of the pump looking straight up from the ground, so it's kinda hard to get your bearings. I used a shurflo 2.8 gallons per minute 45psi pump. Way too much pressure. It cycles on and off about every second. You can't notice it from inside, but it will wear it out quicker.
I also decided to put on more nozzles. I ran those hose up the rear roll bar, and put one nozzle on the top back corner, then ran the hose up to the sound bar and around to the rear of the other roll bar for the other nozzle. I then put a T-adapter in the middle and a valve and made two more nozzle that point in the face of the drive and passenger. These can be turned on/off, so they're good for quick bursts to wet your face. I also put a faucet on the rear corner of the jeep that I attached to the pump, but the pressure was too strong for the way I connected it, so I am trying to find a better way that will hold up to the pressure. I also ran a line w/a valve on it along my spare tire carrier pointing behind the jeep so when I'm sitting behind it I can turn them on.
UTmike is offline
post #44 of 57 Old 05-11-2007, 04:29 PM
tjchad
tjchad's Avatar
I always just used a hand pump one that I got from Home Depot for 5 bucks. I could just take it with me when away from the vehicle and use it anywhere...
It was made by Misty Mate.
HOLY CRAP! I just checked their site and the very same one I got on clearance for 5 bucks is running 74 dollars! At that rate I'd rather take the challenge and make my own...
Chad- KI6BIG
'02 SportD442"BB
Pics:
tjchad is offline
post #45 of 57 Old 05-12-2007, 12:12 PM
ncb76
ncb76's Avatar
Nice setup. I've seen a few of these that use on board air to pressurize a section of PVC pipe. That may be a cheaper route for those that have on board air.
"Let Freedom, Friendship, Faith thy Soul Engage,
And serve, like them, thy country and thy age."
'97 TJ Sport | 2" Spacer Lift | JKS Disconnects | RS 5000's | 32x11.5 ProComp MT's on MT Classic II's
ncb76 is offline
onboard air system by nitrogen? 95yj_bstick YJ Wrangler Technical Forum 1 08-03-2014 10:05 PM
Sanden Onboard Air System Write up PolakX YJ Wrangler Technical Forum 4 12-16-2008 09:46 AM
onboard air system carolinatj TJ Wrangler Technical Forum 8 08-03-2007 10:54 AM
Onboard air system. Reelm n Rubi TJ Wrangler Technical Forum 3 09-14-2005 07:25 PM
Misting System BrandonParvin YJ Wrangler Technical Forum 3 06-02-2003 03:35 PM
