Onboard Misting System - Page 2 - JeepForum.com
post #16 of 57 Old 05-07-2007, 03:52 PM
zman
Stogie, you can clean the nozzles in vinegar or pool acid if they become clogged. Also, do you run a bikini top or something. Full sun out west is brutal and I have to have some sort of shade, even with the misters. I have a small portable pump that has a misting nozzel on it that I use. Same function, just need to manually pump it every 5 minutes.
zman
1995 YJ on 40's * 2002 TJ on 37's * 2003 TJ on 33's * 2011 WK Larado X w Hemi
zman is offline
post #17 of 57 Old 05-07-2007, 03:58 PM
LJinDelaware
That is really cool! Great idea, I'm a little jealous its too humid here in Delaware to attempt it.
....and thats all I have to say about that.
LJinDelaware is offline
post #18 of 57 Old 05-07-2007, 04:08 PM
SpoiledRotten
SpoiledRotten's Avatar
Nice job. In MS, it's around 80 - 90 % humidity most of the summer. If simply turn on the A/C top up or down. It works very well when you are stuck in traffic.
Christian Jeepers _ Member #2
United Four Wheel Drive Association _ Member
National Rifle Association _ Member
SpoiledRotten is offline
post #19 of 57 Old 05-07-2007, 04:15 PM
KUK9
KUK9's Avatar
Good write up. I've been wanting to do this to mine for quite some time now. I saw (probably) the same online one as you, but never followed up on it. My only thing would be how to do it since I don't have OBA. Any ideas on how to do it in another fashion?
REDLYNER Racing #4550
My Build Thread:
http://www.jeepforum.com/forum/f22/adapt-die-kuk9s-stretch-tj-build-1160620
KUK9 is offline
post #20 of 57 Old 05-07-2007, 04:22 PM Thread Starter
stogie25
stogie25's Avatar
My setup does not use OBA, it uses an RV pump. Since you are local I would be happy to meat for a beer, and you could see it first hand.
Jarhead Jeep Club
O|||||||O
97 Black TJ (one owner), BFG KM2 35s, 4.7L Stroker, ARB's, Dana60 rear, Dana30HP Front Warn manual hub conversion, 6 inch mostly Tera long arm lift. Rhino lined tub. Allied Rock 8 beadlocks. Tera-Low 4:1. Sanden OBA. Sniperfab tube fenders.
My Build Thread
stogie25 is offline
post #21 of 57 Old 05-07-2007, 04:51 PM
5artist5
5artist5's Avatar
1972 CJ5
zman
Yes! Have them spray acid at the passengers if they do not entertain you! Or you could use it to threaten kids into behaving! For that matter you could use it as a mobile interrogation vehicle.
KI6RIC
72 CJ5 258-3spd d30-d20-d44
Originally Posted by Bsktbll109 View Post
Does your rearend guy do gears?
5artist5 is offline
post #22 of 57 Old 05-07-2007, 05:37 PM
Dogman
Dogman's Avatar
Last summer I had a hand pump version and the water usage is very little. I had a one gallon container and it would last a week or longer. Now, that is intermittent usage. I might have used more if I had this setup.
John 3:17
Dogman is offline
post #23 of 57 Old 05-08-2007, 10:40 AM
Signalsoldier
What is your psi range? I am assuming that if you are anywhere below 500 psi you wouldn't get a good spray.
Signalsoldier is offline
post #24 of 57 Old 05-08-2007, 10:46 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Hey that is a very cool idea, especially for Jeepers like me that live and wheel in desert areas. I can only think of one nice-to-do enhancement which would be to run distilled (or deionized which is the same thing) water (sold by the gallon in all supermarkets) if you live where hard water is prevalent. That'd prevent the nozzles from clogging with hard water deposits and from leaving white hard water desposits all over the Jeep's interior.
Jerry Bransford is online now
post #25 of 57 Old 05-08-2007, 11:08 AM
FLATFENDER54
FLATFENDER54's Avatar
Nice - ive seen one before on a very nice CJ the nozzles where in the roll cage along with the lines. He lived in Arizona and went out in the desert exploring a lot with only a bikini top and at slow speeds so his nozzles were in the front. His ran off of a coke canister (the kind for fountain drinks) Im not sure exactly how it worked. Its a great idea thanks for sharing.
01 TJ Sahara 4"short arm/rear gas&tire
carrier bumper/front winch bumper winch/detroitEz
1954 WILLYS CJ3B (under construction)
FLATFENDER54 is offline
post #26 of 57 Old 05-08-2007, 11:14 AM
5artist5
5artist5's Avatar
1972 CJ5
Oh, that is a great idea! If you have a CO2 system you can plumb it to the soda keg and run the system on compressed Co2. That is what they are designed for after all.
It might also be possible to use an onboard compressor to preasurize the soda keg.
That would be great also.
KI6RIC
5artist5 is offline
post #27 of 57 Old 05-08-2007, 11:40 AM
Jon_H
Jon_H's Avatar
I don't have anything to add, just wanted to say I love this
Kind of reminds me of those misters in the produce section at the supermarket. Very cool idea!
Jon H.
'97 TJ Sahara | 31" BFG A/Ts | Dynomax exhaust system
Stock Jeep Club Member #36
Silence is golden, but tape is silver.
Jon_H is offline
post #28 of 57 Old 05-08-2007, 11:46 AM
Baotchi
Baotchi's Avatar
2010 JK Wrangler
Are the misters the same kind you find in the gardening department at Home Depot to mist plants and grass in automated systems ? Can you turn the end to ajust the mist or is it fixed depending of the PSI you feed them?
Black 2010 Sport JK
Black 2003 Sport TJ Gone!
Baotchi is offline
post #29 of 57 Old 05-08-2007, 12:20 PM Thread Starter
stogie25
stogie25's Avatar
The misters that I have were from a patio misting system. My nozzles do not adjust. You could find some that do adjust. I'll bet the garden misters would work. You would have to see the misting pattern and make sure it is fine enough.
Here is a link for a patio system. There are many out there.
http://www.dripirrigation.com/index.php?cPath=43
Jarhead Jeep Club
O|||||||O
My Build Thread
stogie25 is offline
post #30 of 57 Old 05-08-2007, 01:36 PM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
And those systems work very well... try Vegas in August! They have them at most of the outdoor bars. Worked well at keeping me near the bar and spending money
I'll be Savvy someday!
neZZr is offline
onboard air system by nitrogen? 95yj_bstick YJ Wrangler Technical Forum 1 08-03-2014 09:05 PM
Sanden Onboard Air System Write up PolakX YJ Wrangler Technical Forum 4 12-16-2008 08:46 AM
onboard air system carolinatj TJ Wrangler Technical Forum 8 08-03-2007 09:54 AM
Onboard air system. Reelm n Rubi TJ Wrangler Technical Forum 3 09-14-2005 06:25 PM
Misting System BrandonParvin YJ Wrangler Technical Forum 3 06-02-2003 02:35 PM
