onboard air system - JeepForum.com
post #1 of 9 Old 08-01-2007, 11:03 PM Thread Starter
carolinatj
onboard air system
Has anyone installed the viair onboard system from northridge 4x4, and if so where did you mount the air tank. I am thinking about mounting the on the left side of the tc skid plate if there is room. Will soon be adding a jks 1 1/4 body lift and mml and sye kit. thansk in advance for replys.
carolinatj is offline
post #2 of 9 Old 08-02-2007, 10:24 AM Thread Starter
carolinatj
this got buried quick. anyone?
post #3 of 9 Old 08-02-2007, 10:30 AM
RockRunner85
I have mine mounted on the driver side behind the tcase skid. Basically opposite side of the muffler. I made some brackets for the tank which clamp onto the frame. I can get you some pics later.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
RockRunner85 is offline
post #4 of 9 Old 08-02-2007, 10:32 AM
Flatbroke
not sure if the one in this thread is from northridge but it may help to see it anyway.
http://www.jeepforum.com/forum/showt...highlight=viar
Yellow 02 Sport
Originally Posted by XRussoX
Haha
I actually look at a Jeepers nuts to see how informed they are. Ditch your nuts man!
Russo
Flatbroke is offline
post #5 of 9 Old 08-02-2007, 10:33 AM
MeloYelo
I mounted my Viair 2.5 gallon tank on the driver side behind the T-Case.
Havent hit it on any rocks yet.
2002 TJ Sport, Locked in rear. Armor dents and character.
05 WK 5.7L Limited. Stock...... for now.
Colorado Jeep Club Member #79
MeloYelo is offline
post #6 of 9 Old 08-02-2007, 10:52 AM Thread Starter
carolinatj
Thanks for the quick replys. will be ordering the kit soon.
post #7 of 9 Old 08-02-2007, 01:48 PM
Crashnburn80
Crashnburn80's Avatar
This is next on my Jeeps wish list. Is mounting behind the Tcase common?
That seems like a very impact prone place and would certainly be damaged at some point. I was thinking under the hood in the back drive side, in front of the firewall (I think theres room) though I haven't measured. Anyone mounted this tank under the hood?
| 1.25" BL |
| Riddler diff covers |
| 33" MTRs | Warn M8000 |
and much more...
Crashnburn80 is offline
post #8 of 9 Old 08-02-2007, 08:55 PM
aussie stu
The hotter the air the more it will expand...im guessing that putting it under the hood will mean the more work for the compressor to fill the tank....but i have no idea.
Black 98 TJ / 4.5" Coils / 1" BL + MML / 4.56 / 35's Silverstones MT-117 on 16 X 8's / D44 & ARB Airlocker / D30 & lockright / Rocklights / wind sheild IPF's / Custom WARN rear tyre carrier / extended brake lines / Custom Triangulated 4 link long arm / Front adj. panard (no rear) / rear storage draw system / OBA / AA SYE / Bestop duster, windjammer, bikini combo / Bushwackers flares / UHF / TBS / Wilderness Rack / 3" stainless steel snorkel / T-Max 9000 6HP winch
aussie stu is offline
post #9 of 9 Old 08-03-2007, 10:54 AM
MeloYelo
I think it is pretty common to put the air tank behind the T-Case. I have seen some people mount it under the hood and behind the rear seat.
I have had mine on for only one year now and I have done some pretty rocky trails and nothing has hit it yet. I believe this has to do with the breakover angle the Wrangler has. If I do manage to get close to hitting it, the tcase skid plate usually hits it first and by the time it gets close to the air tank the rear tire is climbing so it clears.
I love having my OBA system. Airing up and running air tools off of your jeep is a nice option to have.
MeloYelo is offline
onboard air system by nitrogen? 95yj_bstick YJ Wrangler Technical Forum 1 08-03-2014 10:05 PM
Onboard Misting System stogie25 TJ Wrangler Technical Forum 56 08-08-2012 02:49 AM
Onboard Diagnostic System Test Failure KCC TJ Wrangler Technical Forum 6 01-15-2010 07:02 PM
Sanden Onboard Air System Write up PolakX YJ Wrangler Technical Forum 4 12-16-2008 09:46 AM
Onboard air system. Reelm n Rubi TJ Wrangler Technical Forum 3 09-14-2005 07:25 PM
