Onboard air system. - JeepForum.com
post #1 of 4 Old 09-12-2005, 09:12 PM Thread Starter
Reelm n Rubi
Fish fear me
Reelm n Rubi's Avatar
Onboard air system.
I have a factory AMC 258 A/C compressor, does anyone know if this compressor is useable with a Kilby mounting system. Is the output (cfm) of this compressor any good. I am asking because the guy who sold me the 258 was wanting the compressor if I wasn't going to use it. I know the Kilby guys like the York compressors but if this one will work ok I'd like to use it.
2003 Lt. Khaki Rubicon automatic
Supercharged 4.7 stroker w/ Hesco aluminum head
70mm F&B throttle body
Kieth Black forged 944 pistons
Comp Cams custom ground camshaft
505 Performance PCM
Split Second Engineering fuel/timing management
Tom Woods CV driveshaft
50 lb/hr Trick Flow injectors
4" Full Traction LA with Bilstein 7100's
JKS 1" MM,BL. TeraFlex engine and steering armor
4.88's w/ 35 " Toyo Open Country m/t's
Moser Chromoly axle shafts front, Superior D44 rear
Warn 9.5ti on a M.O.R.E hi clearance bumper
Reid racing knuckles, Warn premium hubs
PIAA 525's, and 510's
XBOX Gamertag- ISHAGDyurGURL
For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30
Reelm n Rubi is offline
post #2 of 4 Old 09-13-2005, 01:02 AM
James04TJ
James04TJ's Avatar
Call or email Brad Kilby. I am sure he should be able to point you in the right direction.
*2004 TJ (Mine)* 1984 CJ-7 Buggy Project (Mine)* 1977 CJ-7 (Hers)*2005 Nylint Crawler (The Kid's)
James04TJ is offline
post #3 of 4 Old 09-13-2005, 08:14 AM Thread Starter
Reelm n Rubi
Fish fear me
I did, I just wanted to try here also.
505 Performance PCM
post #4 of 4 Old 09-14-2005, 07:25 PM Thread Starter
Reelm n Rubi
Fish fear me
Kilby got back to me and said That their system is meant to mount a York style compressor not the Sanderson style.
505 Performance PCM
onboard air system by nitrogen? 95yj_bstick YJ Wrangler Technical Forum 1 08-03-2014 10:05 PM
Onboard Misting System stogie25 TJ Wrangler Technical Forum 56 08-08-2012 02:49 AM
Onboard Diagnostic System Test Failure KCC TJ Wrangler Technical Forum 6 01-15-2010 07:02 PM
Sanden Onboard Air System Write up PolakX YJ Wrangler Technical Forum 4 12-16-2008 09:46 AM
onboard air system carolinatj TJ Wrangler Technical Forum 8 08-03-2007 10:54 AM
