Quantcast Omix-Ada 1941-45 MB jeep taillights fit a tj? - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Omix-Ada 1941-45 MB jeep taillights fit a tj?
Old 07-30-2010, 03:38 PM   #1
thisgardengrove
Tail Light Assembly by Omix-Ada and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware-RH3
and
i like the look of them anyone know if they would bolt right up?
thisgardengrove is offline   Reply With Quote
Old 07-30-2010, 03:43 PM   #2
Benderff
intentionally left blank
Benderff's Avatar
Bolt right up? No way. Could you make them work with a little time and effort? Sure/
Benderff is online now   Reply With Quote
Old 07-30-2010, 04:07 PM   #3
thisgardengrove
Anyone used these before? i'm trying to find a alternative to my ORO lite dots. i cant put round led's in the tub due to the OR-Fab tire carrier bracket
Old 07-30-2010, 08:25 PM   #4
BlueFlame
Bear in mind that those lights stick out just like the factory lights do.
Also they will not be legal on a TJ (Only legal on a stock 1941-45 MB and GPW) due to having no reflectors on rear or side.
But they'd be easy to bolt on in place of the stock TJ lights.
BlueFlame is offline   Reply With Quote
Old 07-31-2010, 10:15 AM   #5
Faramir66103
I've got a set of these on my '66 M-416 trailer. I'm told there's a design flaw so that when they encounter water either from rain or stream crossings, they let water in but not out. I opened them up and found them full of water and the internals completely corroded. I couldn't even get the bulbs out of the holders. In an effort to not spend too much cash on the trailer, I completely removed the internals, lined the inside with aluminum foil to act as some sort of reflector and replaced the internals with the guts from some magnetic trailer lights I had in a bin. They work, but are still terribly dim. As soon as I can find a set of stock TJ tail lights, I'm going to get rid of them. I'm just not comfortable with their visibility on the road from a safety standpoint.
FWIW,
Adam
'99 TJ Sport, 4.0 I6, 5 speed manual transmission, Hi Lift w/offroad kit, Viair 450C compressor, Garmin GPS, Skid Row Engine/Transmission, steering box & radiator skid plates, Kilby gas tank plate, AtoZ Fab full length rocker guards, Performance Accessories 1" Body Lift, OME 2.5" HD springs & shocks, JKS trackbars front & rear, BFG AT 33x12.5r15, EBC Yellow pads and Centric rotors
Faramir66103 is offline   Reply With Quote
Old 07-31-2010, 01:16 PM   #6
breckboarder55
Have you checked out Saavy's yet?
IMO they look great once you paint the Aluminum black.
To Veterans past and present, thank you for your service!
99 Jeep Wrangler-Just another TJ on 33"s
55 Dodge Royal Lancer- Resto Project
87 Mazda RX-7 Turbo II-Built.
87 Mazda RX-7 SE-Burn Victim
02 Toyota Celica GT-S-DD/beater
breckboarder55 is offline   Reply With Quote
tail light, omix-ada
Glock Forum
