OME vs. Hydro 7000 - JeepForum.com
post #1 of 6 Old 06-04-2006, 03:56 PM Thread Starter
Porndexter
OME vs. Hydro 7000
Okay, just bought a lift kit off ebay. It's the Rancho 2.5" lift (RS6503). It doesn't come with shocks. So, I know that from what I read the OME kit rides really nice on road. Is it the shocks or springs? Because if it's the shocks that are what make it better than stock ride on the road THEN i refer to Quadratec's catalog. In there they have a shockabsorber "spreadsheet" and even thought the OME is gas charged, bigger piston dia., bigger rod dia. etc. its' ride quality is rated as "soft-medium". The only other shock with that soft-medium ride quality is the Skyjacker Hydro 7000. Since I'm cheap, the 7000's are half the price. How are the 7000's on ride to those of you who run them and better yet who have ridden in Jeeps that have had both?
Porndexter is offline
post #2 of 6 Old 06-04-2006, 04:10 PM
JeepJohnson
From what I've gathered it seems that while OME's shock do ride nice w/other brands they ride even better with OME's springs. It also seems like OME's springs aren't your topical run of the mill springs and that their spring and shocks specifically are designed to compliment each other. What's up with the different spring lengths with OME, what does it do?
Low Output 2.5L Member #39
Originally Posted by phaldor View Post
The top is a Barkertop...
Originally Posted by Capeman29 View Post
OH WOW, it electrically smashes all the fabric and windows together and looks like a big burnt marshmallow hangin off the back of your rig!!!!
JeepJohnson is offline
post #3 of 6 Old 06-04-2006, 05:06 PM
trailraider
They have a couple of different part #'s for different setups. I think one set is light and intended for soft top models, and the other are for the hard top models. they also make a four inch spring (or was it four and half??) and that was for another company, but they are available.
1998 Sport, Optima, Nth Degree Tummy Tucker and PIAA 520's
trailraider is offline
post #4 of 6 Old 06-04-2006, 05:50 PM
thejafe
thejafe's Avatar
Yep, OME offers the 2" springs and the 4" springs. Their springs and shocks are designed to work in conjunction with one another and yes, their springs have varying heights. If you get an OME lift kit you'll see that the front driver coil is taller than the front passenger and it's the opposite for the rear. I've run the following shocks; stock, Doestch Tech, RE Twin Tubes and OME's with OME's being the best by FAR. I currently have the RE Twin Tubes but will be going back to the OME's as soon as the funds allow.
thejafe is offline
post #5 of 6 Old 06-04-2006, 10:01 PM
paintballjerry
paintballjerry's Avatar
I have the skyjacker nitros, they ride great to me. But I like a firmer ride though.
<=== My Specs are there in my Profile!!!
Co-Ed Naked Jeeper Club Member #69
Originally Posted by charlescho
don;t ask here what MPG you will get with what tires etc, you will get your butt raped by the forum bullies
paintballjerry is offline
post #6 of 6 Old 06-05-2006, 01:09 AM
tjwheeler
OME's are great i use them. my rig is dd/ww and it gets the job done in both aspects on and off-road. my .02$
tjwheeler is offline
RE 7000 SF 4.5 ?s 06 lj jcm1983 TJ Wrangler Technical Forum 8 12-02-2008 12:05 AM
jets for a weber 32/36 at 7000 ft johnrezz YJ Wrangler Technical Forum 0 10-21-2008 06:42 PM
Re 7000 4.5 LIFT !! BADEAGLE TJ Wrangler Technical Forum 12 11-02-2006 02:53 PM
OME and skyjacker 7000 hydro 05darkness TJ Wrangler Technical Forum 6 05-19-2006 02:38 PM
Pro Comp ES 3000 vs Shyjacker Hydro 7000 Linda or Greg TJ Wrangler Technical Forum 1 11-19-2005 12:31 AM
