ome springs - JeepForum.com
post #1 of 12 Old 08-04-2009, 06:50 PM Thread Starter
kody4
ome springs
i was wondering does ome make 4inch lift springs or is 2.5 the highest they go if so does anyone have any pictures and how do they ride
kody4 is offline
post #2 of 12 Old 08-04-2009, 06:53 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
they make 4" springs. they're closer to 4.5-5" from what i've heard tho.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 12 Old 08-04-2009, 06:55 PM Thread Starter
kody4
that would be fine where can u get them from? do u know how they ride
kody4 is offline
post #4 of 12 Old 08-04-2009, 07:29 PM
Boodyrider
OME springs are slightly lower rate than stock so should ride nice. The difference in ride is more about the shock and the available uptravel though. More uptravel, more soft ride in general. Pair with stiff crappy shocks though, you could still have a bad ride, especially if you ignore all the other parts needed for a successful lift that tall.
MANY places carry the OME springs.
Here is one: http://www.rocky-road.com/tjtrailblazer.html
They will sell the springs separate from the kit, just call.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #5 of 12 Old 08-04-2009, 07:31 PM
Unlimited04
actually OME's are quite a bit stiffer spring rate than stock. in fact, they're some of the more stiff springs on the market.
http://www.jeepforum.com/forum/f9/faq-coil-spring-measurements-638947/#post6077636
http://www.jeepforum.com/forum/f11/springs-heights-their-spring-rates-613756/
Useful Write-Ups:
Funny:
post #6 of 12 Old 08-04-2009, 07:36 PM
outlawjosywales
a buddy of mine has a 4.5" aev la kit with ome shocks. he likes them
Go Anywhere.
outlawjosywales is offline
post #7 of 12 Old 08-04-2009, 08:33 PM
nriver
2011 JK Wrangler
I have the OME ZJ front springs. They net me about 1/2 less lift than my FT 4" springs. FWIW
Why do I post here?
nriver is offline
post #8 of 12 Old 08-04-2009, 11:45 PM Thread Starter
kody4
ok cause i have the ft ulitimate 4inch three link set up with skyjacker hydros and i dont care for the springs there just to stiff
kody4 is offline
post #9 of 12 Old 08-05-2009, 07:37 AM
nriver
2011 JK Wrangler
Cool, same suspension. Not sure I think the FT springs are to stiff. Wondering if your issues are related to shocks or load.
How long have the springs been in? Thinking I thought they were a bit rough first, but now they are fine.
Are you bottoming out? hitting the bumpstops?
I also have run the OME LJ springs in the rear. Thinking they were about an inch or more shorter than the FT springs. They can bottom out the rear sooner than the FT springs. I had put a spacer out back to get a bit of extra height.
Why do I post here?
nriver is offline
post #10 of 12 Old 08-05-2009, 08:15 AM
VTJeePTJ
OME does make some nice coils to be sure but I will also x2 the note that the 4" springs are much firmer than their 2.5 coils, and in fact firmer than most 4" coils. While very high quality, the 4" springs are designed for a very heavily loaded and optioned TJ so if you feel that your current coils are too stiff, you aren't likely going to find any relief by switching to the OME springs assuming you are running the same shocks. You also may gain some additional height as the OME 4" coils run tall so, in theory, you could make the ride even more harsh by increasing your control arm angle even more.
I also would attribute more of the ride to your shocks. I run the skyjacker hydros (got them for free) and while they aren't horrible for their price range, they also certainly are nowhere near the performance of a good monotube shock such as the OME's, RE monotubes, Bilsteins, etc.
2003 Jeep TJ- 4" Nth LA, 4.88/ARBs, Rubicrawler, 33's, Savvy Steering, Poison Spyder Armor, etc.
VTJeePTJ is offline
post #11 of 12 Old 08-05-2009, 08:19 AM Thread Starter
kody4
i have a 2.5l so my ft springs just feel really stiff. i have only had that lift kit about a month and a half though and my skyjacker hydros about three months. did your ft springs soften quite a bit since when you bought them.
ya i have heard the ome shocks are good i might have to look into those
kody4 is offline
post #12 of 12 Old 08-05-2009, 08:47 AM
klimb2xs
I have been running the OME 4" LJ springs for just under a year. I noticed that they rode very firm until I got them off road and flexed them out. Now I think they have a comfortable ride for DD use.
Originally Posted by walldk View Post
Step away from from the vehicle and seek professional help.
klimb2xs is offline
Rubi springs VS stock Sport springs seekrtruth TJ Wrangler Technical Forum 12 08-22-2009 08:58 AM
How much for stock springs from dealer? OME springs? DINOCAVE Wrangler General Discussion 4 08-21-2008 03:52 PM
How do lifts perform? BB/ZJ springs/Lift Springs? TJ_ITmgr TJ Wrangler Technical Forum 3 10-27-2007 01:14 AM
Comparing XJ Springs to YJ Springs - Height Question Big-n-Broke-YJ YJ Wrangler Technical Forum 16 03-11-2007 01:56 PM
Replace Stock Springs with Rubi Springs NewBinCO TJ Wrangler Technical Forum 9 09-01-2006 11:33 PM
