OME Spacer Problem ? (Pic) - JeepForum.com
post #1 of 4 Old 08-06-2010, 12:47 AM Thread Starter
inglisleslie
The spacer(yellow) looks uncomfortable to say the least. Would it be better to have the OEM spring retainer over the OME yellow spacer (Thats what I am thinking)? Or does it not really matter and will ride into place?
/l ,[ ______],
l---l_--OllllllllO- My BUILD Thread----> http://www.jeepforum.com/forum/f22/white-l-cog-1074040/index10.html
()_) ()_)--O-)_)
inglisleslie is offline
post #2 of 4 Old 08-06-2010, 10:58 AM Thread Starter
inglisleslie
thoughts...?
/l ,[ ______],
()_) ()_)--O-)_)
post #3 of 4 Old 08-06-2010, 11:00 AM
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
It should be behind the spring retainer.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline
post #4 of 4 Old 08-06-2010, 09:20 PM Thread Starter
inglisleslie
here it is fixed
/l ,[ ______],
()_) ()_)--O-)_)
spacer , ome , old man emu , spring , coil
Belt problem, blinker problem, and a random problem... Mike89db TJ Wrangler Technical Forum 10 12-14-2009 05:34 AM
Spacer wrench?! How to remove a too-tight spacer? STW TJ Wrangler Technical Forum 2 02-27-2007 03:35 PM
throttle body spacer problem adam34 TJ Wrangler Technical Forum 13 10-30-2006 09:39 PM
throttle body spacer linkage bracket spacer ? kmo0189 YJ Wrangler Technical Forum 3 09-24-2006 10:42 AM
is trackbar a big problem with just a 2" spacer lift? mike06X TJ Wrangler Technical Forum 1 10-19-2005 06:40 PM
