OME price - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > OME price
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiPoison Spyder DeFenders™ - "Tubeless" Jeep FendeJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 05-16-2005, 10:30 PM   #1
gasmasher
OME price
so where is the best price for the OME 2" Lift kit?
Thanks
Kirk
97 sport Old man emu lift. auto.Hurculined tub.
30-9.50 BFT TA's
keep the greasy side down and your power dry.
gasmasher is offline   Reply With Quote
Unread 05-16-2005, 10:32 PM   #2
ColoradoTJ
DPG Offroad
Clint
Colorado Jeep Club Member #60
My Jeep
"If we weren't all crazy we would go insane" J.B.
ColoradoTJ is offline   Reply With Quote
Unread 05-16-2005, 11:34 PM   #3
UCTJ
x2 w/ DPG OFFROAD
UCTJ is offline   Reply With Quote
Unread 05-17-2005, 06:12 AM   #4
SeaHoCapt
x3 on Dirk and DPGOffRoad!
David
'97 TJ Sport,
3.5 lift (OME 2.5" SL, Daystar 1" BL, JKS 1" MML)
33x12.5x15 MT/R's on 15x8 MT Classic II
YORK OBA
Warn 95ti
SeaHoCapt is offline   Reply With Quote
Unread 05-17-2005, 06:19 AM   #5
IU98
Dirk, Dirk he's our man if he can't do it no one can. Gooo Dirk.
Ok so that was gay, but DPG offroad has great prices.
Chad
2000 Sahara-Two car seats a 2.5 ome lift with 1 inch spacers a 1.25bl, 1in mml, rear shock relocaters, extended rear swaybar links, jks quicker discos with 33in Kuhmo mt's on black steelies. Armor-kilby, jeeperman and warn. Dual white tops and an auto. Raingler rear and side nets along with grips. Ome steering stabilizer and xm for tunes. Dana 30/35 frt and rear-awaiting snappage. I have a pretty jeep and my children dig it.
IU98 is offline   Reply With Quote
Unread 05-17-2005, 06:52 AM   #6
erickpl
Be advised, OME is on SERIOUS backorder right now.
I placed an order with DPG the Tuesday after they got back from vacation (which was back in April). At that time, I was told it was a 3-4 week wait. No problem as my weekends have been swamped anyway. But in keeping in touch with Dirk, which is great btw, it seems ARB/OME is having records sales this spring and can't keep their parts, including the bumpers, shocks, springs, etc flowing fast enough to the US.
My springs are taking the slow, scenic, meandering, wandering, lost? boat to the US west coast. Hopefully they'll be here soon. Dirk has been very accomodating. I know it isn't his fault, as other OME vendors I've talked with can't get the parts any faster either. Just knowing DPGOffroad is keeping tabs on it makes it a bit easier going.
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline   Reply With Quote
Unread 05-17-2005, 07:08 AM   #7
MR.CLIFFORD
I like those DPG guys too
MR.CLIFFORD is offline   Reply With Quote
Unread 05-17-2005, 07:21 AM   #8
TJinWV
Actually I pieced mine together myself from Swiss Mountain (he's a vendor) and saved about $100 over Dirk's basic kit price. Just something to keep in mind.
Dan - TJinWV <>< | West Virginia Jeep Club
2002 TJ, 2" OME lift, ARBs
TJinWV is offline   Reply With Quote
Unread 05-17-2005, 07:37 AM   #9
thebulkinator
They dont offer the springs.....
thebulkinator is offline   Reply With Quote
Unread 05-17-2005, 07:38 AM   #10
diveguy
Dirk at DPG is great. And yes, very serious and extreme back-order, luckily I got mine the other day and it goes on tomorrow.
2008 Blue Sahara Unlimited
275/70R18 (33.2 x 10.5) BFG AT/KO
diveguy is offline   Reply With Quote
Unread 05-17-2005, 07:43 AM   #11
TJinWV
http://www.swissmountain4x4.com/shop...catID=3&sub=25
Click on the OME emblem.
Unread 05-17-2005, 07:46 AM   #12
thebulkinator
Found them thanks! I think I'll go that route. I can piece together the kit(which DPG) lists for 649 for 422 w/o the t/c spacers(I'm getting MORE MML and BL) and w/o the rear trackbar bracket which I already have.
Did you experience a front axle shift when putting in your 2.5 springs? I'm going to go with the HD also.
Unread 05-17-2005, 07:48 AM   #13
TJinWV
Yep. Haven't done anything to correct it yet (I've only had the kit installed since last weekend). Two options - redrill the OEM trackbar mounting location or get an adjustable trackbar. I'm leaning toward the first option because it's a good bit cheaper.
Unread 05-17-2005, 07:59 AM   #14
thebulkinator
How far did it shift?
Unread 05-17-2005, 08:04 AM   #15
TJinWV
I haven't measured it, but I'd estimate about an inch. It doesn't seem like it's causing a problem as it is, though - no rubbing or anything that I've noticed. I figure correcting it would increase tire wear, etc.
