OME Install: Comments, questions, and pure hatred for Torx bolts - JeepForum.com
post #1 of 12 Old 04-28-2007, 10:43 PM Thread Starter
PackMan
PackMan's Avatar
Location: Home of the Super Bowl XLI Champion Indianapolis Colts
OK, so hate is a very strong word.
WTH, it's appropriate. Torx is the tool of the Devil. In Hell, everything is built with Torx, and Hilter, Stalin, and Osama Bin Laden are forced to rebuild it all daily.
I got the front done today, with a few minor incidents and creativity:
1) The top shock mounts were a royal pain to remove. The piston would spin inside the shock, and no movement. This finally took an adjustable wrench on top, followed by a pair of needle-nose under the lower bushing once the nut got high enough.
2). My help couldn't show today, as his son got some stomach bug. I didn't want to wait, so I dug in... w/o a spring compressor. I could tell that a little pressure to push down the axle would help, but I wasn't going to drag my wife into this. So I got creative.
I pulled out the bottle jack, stuck it on the shock mount on the axle, and angled it up to push up against the frame. This pushed the axle down a couple of inches and I was able to get the springs in w/o unbolting the control arms. Careful not to over-do this, and expect the axle to bounce back up if it slips.
I still have to set the new adjustable track bar, and do an alignment, as well as re-torque everything. But I threw the new tires on it and started to the back.
I might have finished the spring install completely today were it not for the rear track bar. Nothing is going right with this thing:
1) The frame mount bolt will not come out. I got the nut off OK, but the trackbar twisted a bit once freed, and it's hung up in there. It's about 1/2 way out.
2) I can't budge the %$#@& Torx bolt on the axle mount. It would appear that I wasn't lucky enough to have a TJ built on Godzilla's day off in Toledo. What fool at DCX decided Torx were a good idea, especially in such a tight spot?
Before I started chewing up the Torx bolt to the point where it was totally hosed, I called it a night. I'm hoping some late-nighters here have some suggestions on how I might free that accursed thing.
PackMan is offline
post #2 of 12 Old 04-29-2007, 12:16 AM
Frank the Tank
Frank the Tank's Avatar
I did the same thing... a clear example of: brains > brawn!
As for the rear trackbar bolt being stuck, I had the same problem. If its the bolt at the axle-end that is stuck, try removing the bolt at the other end of the trackbar (frame -end). Also, make sure you make a run to your local parts store to buy a replacement hex bolt when you get that one out... trust me! If you think removing it was difficult, wait till its time to reinstall it.
Another thing that helped me were some heavy duty rachet straps. You can position them in various ways to pull you axle or trackbar into submission. Anyways, my $0.02, hope it helps.
Frank the Tank is offline
post #3 of 12 Old 04-29-2007, 04:20 AM
Jeepguy1977
Jeepguy1977's Avatar
Sorry to hijack, but LOVE the avatar Frank lol
1998 TJ, 4.0L Auto and various junk
Rolled Red Jeep Club Member #7
Jeepguy1977 is offline
post #4 of 12 Old 04-29-2007, 06:18 AM
bclevenger
My rear torx was siezed also, I heated, PB Blasted...for an hour then got out the grinder and ground the head off and popped it through the front side.
When you reassemble, do the frame side first, then the pumpkin side.... more clearance to pound on the bolt.
The front torx was siezed also, but I welded a nut to it and took the impact to it....it finally submitted.
Good luck.
bclevenger is offline
post #5 of 12 Old 04-29-2007, 06:55 AM
Russ Chung
Russ Chung's Avatar
I used a ratchet strap and a jack on one side while pushing down on the other side. As you already know, it's a PITA to get the holes to line up. When the axle droops, the rear track bar twists, so I had to use a combination of strap, bottle jack, floor jack and jack stands (and a hammer) to get everything lined up so I could get the bolts in and out.
If you don't like the way I drive, stay off the sidewalk!
KI6MLU
Russ Chung is offline
post #6 of 12 Old 04-29-2007, 08:13 AM Thread Starter
PackMan
PackMan's Avatar
Thanks for the input, guys. I figured I hadn't been the only guy to use the bottle jack trick before...
Looks like I'll have to remove the upper control arm on the driver's side to get to the other side of the trackbar. I wasn't sure if that was a nutsert or just a nut. That housing is bizarre, and thus far the most difficult thing I've run into.
If anyone else has ideas about the rear track bar, please weigh in. I'm sure I'll be screwing with this for a while.
PackMan is offline
post #7 of 12 Old 04-29-2007, 10:37 AM
Frank the Tank
Thanks, one of my girlfriends offered to pose for the pic, so I let her...
post #8 of 12 Old 04-29-2007, 11:17 AM
RichardBailey
Frank, you make me feel a little better. I was fighting with that mess last week. Rear track bar and pitman arm were both an absolute pain in the *****. Took my grinder to both after spending waaayy too much time being nice about it. Be patient, it IS worthwile.
Life is short, Live like you mean it!!
2005 Unlimited, Arctic silver, 4" Skyjacker lift, Nitto Mud Terrain 33 x 11.50 x 16s on ARE Victors, Black safari rack
4.0 Auto
65 Backdraft Cobra 408 CI 440rwhp
67 Mustang Coupe 289 stock
02 Powerstroke CC 4 x 4 to pull the toys
RichardBailey is offline
post #9 of 12 Old 04-29-2007, 02:07 PM Thread Starter
PackMan
PackMan's Avatar
I went to the local hardware store, the guy loaned me a piece of pipe to use as a cheater. It worked right away. I went back to get a 12mm bolt with an honest-to-God hex head to replace that, and he sold that pipe to me for a buck.
It is my new best friend.
PackMan is offline
post #10 of 12 Old 04-29-2007, 06:42 PM
fxanimator1
Well, O.K., but there's a guy on the rubiconOwnersForum that has the same avatar.
fxanimator1 is offline
post #11 of 12 Old 04-29-2007, 07:54 PM
Frank the Tank
I know... thats where I stole it from...
post #12 of 12 Old 04-29-2007, 09:36 PM
[ITA]Tsunami
Italian Wheeler in Mexico
[ITA]Tsunami's Avatar
sorry, can't resist, i didn't even read your post, you make me die! this goes directly on my sign..
Now i'll read your post
Originally Posted by mdm
However it is a strange twist in the cosmic thread that will not allow the driver of a Jeep that has experienced air bag deployment off-road to consume beef for 48 hours after the event. You can consume chicken, pork, turkey, or emu.
[ITA]Tsunami is offline
Torx head starter bolts - Anyone know what kind of bolts? patricknolan TJ Wrangler Technical Forum 0 08-13-2009 08:02 AM
Torx Bolts DeerStabber TJ Wrangler Technical Forum 21 03-15-2009 01:31 PM
*&$%^ Torx Bolts HELP!! HanksRide YJ Wrangler Technical Forum 30 01-16-2009 02:42 PM
Torx bolts Checo18 YJ Wrangler Technical Forum 13 10-03-2008 05:31 AM
