OME 2.5 Lift going up! - JeepForum.com
post #1 of 10 Old 08-10-2010, 07:17 AM Thread Starter
j_bydesign
Wrench Wheel Repeat
j_bydesign's Avatar
Almost 50K miles on my '04 Willy's edition and in of shocks... but why stop there?
Picked up an OME 2.5" springs and shocks as a kit. One of the most unique parts of buying this kits is you taylor it to what you have on your ride... heavy bumpers, winches...hard top...
started by jacking the entire vehicle up and propping her up on jack stands... all four tires off and supported the axles with jacks. Removed the shocks and disconnected the sway bars. lowered the jack supporting the axles and removed the springs... noting the location of where the lower end was situated (on the rear springs)... before installing the new rear springs an extention to the panar brackey was installed (a little drilling) spacers installed for the bump stops (mine are shot and will need to be replaced) then installed the springs (lining up the rears with the tail in the same location as the stock springs...I had to use a ratchet strap to compress the new springs slightly... mount up the new shocks...
doubled check all of the fasteners... pop the wheels back on and test ride!
huge difference in the ride... very comfortable now I just need to get her out on the trails and into the mud and muck of S FL!
before...
after...
now I have to swap out the 3" body lift for a 1"... as I have no intention of running bigger than 33" tires. I would highly recommend this kits it was very easy to install with basic skills and tools.
'04 TJ(wheeler) '65 CJ5(sold :( )...'05 LJ(Scrambler conversion, SOLD!) 89' Int. Harvester Toter (SOLD)! '80 CJ7 Resto Mod(sold) 1985 CJ7 Renegade (in process/million pieces) 2000Kenworth Hauler
j_bydesign is offline
post #2 of 10 Old 08-10-2010, 08:07 AM
TheBoogieman
Jeepaholic
TheBoogieman's Avatar
Nice choice of Jeep and tires. Ditch that BL before somebody see's it.
TheBoogieman is offline
post #3 of 10 Old 08-10-2010, 08:11 AM
DEVILDG03
2012 MK Patriot
Its really good cool snorkel as well
DEVILDG03 is offline
post #4 of 10 Old 08-10-2010, 08:16 AM
SOLIDJP44
i love the willys look, the canyon wheels on the km2's really helps the look
-00 Mildly Modified Wrangler SporT-Sold
2011 GMC ALL/Terrain Sierra z71-Current
SILVER JEEP CLUB MEMBER #55
SOLIDJP44 is offline
post #5 of 10 Old 08-10-2010, 09:47 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
nice you'll love the OME lift
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 10 Old 08-10-2010, 09:51 AM
Sundowner
Great looking Jeep! Those tires really do have a sidewall that reminds me of the older military mudders...very cool! Love the snorkel-intake-device-thingy.
Sundowner is offline
post #7 of 10 Old 08-10-2010, 04:17 PM Thread Starter
j_bydesign
Wrench Wheel Repeat
j_bydesign's Avatar
yeah the 3" body lift is on the way out I just ran out of time last weekend... going to install a 1"... thanks for all the comments regarding the H1 style intake... completely home grow... the cap is actually a sause pan from walmart! I did a write up... if you need any more info regarding the intake PM me
post #8 of 10 Old 08-10-2010, 04:18 PM Thread Starter
j_bydesign
Wrench Wheel Repeat
j_bydesign's Avatar
If anyone is looking for rock gaurds... the stock rubi style diamond plates... they are up for sale... make an offer?
post #9 of 10 Old 08-12-2010, 03:44 PM Thread Starter
j_bydesign
Wrench Wheel Repeat
j_bydesign's Avatar
here is the before... just a 3" BL and older tires (still 32s)
here is the 2.5" lift with teh 3" BL (soon to be swapped out for a 1"BL)
the 3" BL comes off this weekend and replaced with a 1" BL... the 1" MML is in and everything is running smoothly!
post #10 of 10 Old 08-12-2010, 04:12 PM
JeSimmers
JeSimmers's Avatar
Very nice, I like the wheel/tire combo...will be very sharp once you swap out body lift.
Red Jeep Club Member #454
JeSimmers is offline
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 08:51 PM
Tryin to figure out how I'm running 33's. Lift or body lift question. dm33buckeyes TJ Wrangler Technical Forum 21 08-14-2011 05:06 PM
Motor Mount Lift + Body Lift = Radiator Shroud Placement? tommanns YJ Wrangler Technical Forum 6 01-26-2009 09:04 PM
New Rough Country 2.5 Progressive rate Spring Lift and 1.25 Body Lift qf4phlyer JK Wrangler Technical Forum 7 11-24-2008 06:59 PM
2" Coil Spring lift, can body lift be added without ill effects ? Scuba Jeepster TJ Wrangler Technical Forum 2 02-22-2005 10:04 AM
