Olympic Sierra Rack mounted to spare. Anybody have one? - JeepForum.com
post #1 of 6 Old 07-22-2006, 07:46 AM Thread Starter
DINOCAVE
formerly CPT Jeep
DINOCAVE's Avatar
With my daughter now able to ride in my jeep in a forward facing car seat (the rear facing seat didn't fit for crap), storage space is non-existant. I'm thinking of buying this:
http://www.quadratec.com/products/12036_800_07.htm
It says it will hold 75lbs, but if I fabricate some quick disconnect braces that run from the bottom of the carrier to the bumper or door, then I should be able to carry more. I would love to be able to mount my Hi-Lift UNDER the rack (in a waterproof case).
So, bottom line: Is this a quality product? Is the tailgate able to support the extra weight?
DINOCAVE is offline
post #2 of 6 Old 07-22-2006, 07:49 AM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
I'd just be careful because you have the weight of the tire on the bracket and the wright of the rack and the weight of whatevet else you put in it. I suppose the supports would help, but be very careful, you dont want to brake your spare tire bracket.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #3 of 6 Old 07-22-2006, 07:55 AM Thread Starter
DINOCAVE
formerly CPT Jeep
DINOCAVE's Avatar
Yeah, I recognize that weakness which is why I would fabricate some supports. And after thinking about it more based on your response, I would probably run them to the bumper. That way a lot of the weight would be supported there.
Anyone have one?
DINOCAVE is offline
post #4 of 6 Old 07-22-2006, 08:06 AM
Erik T.
Erik T.'s Avatar
I own the Olympic Stinger, I had heard rumors of Olympic being crappy products before I bought mine but blew them off.
When I got my Stinger there was a run in the powdercoat from the tip all the way to the bottom of the drivers side. Also, on the same side underneth where it bolts to the frame the hole was off so the bolt went in at an angle.
I understand sometimes products get screwed up, it happens. But when my Stinger was obviously hand wrapped(with sections of cardboard and packaging tape, then placed in a large clear plastic bag... It shows how terrible their quality control is. Whoever wrapped it should have noticed the powdercoat run - it's impossible to miss.
I didn't bother emailing back the company, as I'll have it Line-X'd anyways(I don't trust powdercoat for anything). And eventually I'll get around to having the bolt hole reamed out at the local shop to fit a bit better.
But you get what you pay for, Olympic is a cheaper alternative to other brands. And personally while I like the look of their products - I will never buy from them again.
-Erik.
Hack work? :rofl: You just described half the modified jeeps on this board.
Erik T. is offline
post #5 of 6 Old 07-22-2006, 09:03 AM Thread Starter
DINOCAVE
formerly CPT Jeep
DINOCAVE's Avatar
Hmmm. Are there any other carriers that mount to the spare? Mine would be mounted full time, so I don't want a hitch rack. I also don't like the ones that mount ABOVE the spare. Too hard to access and cargo would stick up too high.
So I'm sold on a spare tire rack and this is the only one I can find. I may be stuck with it.
DINOCAVE is offline
post #6 of 6 Old 07-25-2006, 01:10 PM
jneal
Nice....Keep Wheelin!
jneal's Avatar
Did any one else get a laugh thinking he was going to put his daughter in the rack?!?!
Maybe its just me.
jneal is offline
spare tire mounted ski rack MY01XL JK Wrangler Technical Forum 0 01-05-2009 11:52 AM
olympic sierra rack bloke279 TJ Wrangler Technical Forum 1 05-31-2007 10:09 AM
Olympic Sierra Rack takthekak TJ Wrangler Technical Forum 4 07-12-2006 05:32 PM
sierra rack limecolbyjack TJ Wrangler Technical Forum 4 07-05-2005 08:55 AM
Sierra Rack / Trail Rack MDEnce YJ Wrangler Technical Forum 0 07-01-2004 01:03 PM
