Old shocks - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Old shocks
Swag Off Road BIG-HIT TJ-YJ Rear BumperAll Bilstein shocks & struts - Lowest Prices Ever and Iron Rock Offroad products - get them from Kolak!
Unread 05-10-2015, 07:14 PM   #1
graydragon2
Put a Zone Offroad budget boost on today. Before I put it on, the jeep sat level even with a heavier bumper and winch up front. Afterwards it has a rake to the front since I don't have a rear bumper yet. It is a 1999 tj and it had the original Chrysler shocks on it. I knew it needed new shocks but didn't realize they were that bad.
graydragon2 is offline   Reply With Quote Quick reply to this message
Unread 05-10-2015, 07:26 PM   #2
afusco1222
Didn't the budget boost come with new shocks? Are you talking about needing new springs? Jeep Wranglers come with a 1" rake from the factory, adding the heavy bumper and winch probably lowered it somewhere between .5" and .75" so you should have a 1.5" or more rake. If you want to get rid of that you could add 2.5" lift springs with a soft spring rate.
afusco1222 is offline   Reply With Quote Quick reply to this message
Unread 05-11-2015, 03:36 AM   #3
graydragon2
It came with new shocks. I just didn't realize it had that much rake since it has been level since I bought it. I don't think the springs are that weak. I think the rake is just more emphasized with new shocks and little bit of lift
Unread 05-11-2015, 04:17 AM   #4
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
TJ's sit 1.5" higher in the rear. I always lift mine 1" more up front because I never ride people in the back.
Stock with less than 50,000 miles on it.
Lift that's 1" higher up front.
When I had 3.07s I would draft behind birds as an attempt to do the speed limit.
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 05-11-2015, 06:16 AM   #5
joe_jeep
What do shocks have to do with the rake?
Shocks dampen up and down travel.
"Normally" shocks dont carry a load, or provide lift.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline   Reply With Quote Quick reply to this message
Unread 05-11-2015, 09:18 AM   #6
graydragon2
Shouldn't have anything to do with it. Just didn't notice the rake without the lift I guess.
