Oil Pump Problem?? - JeepForum.com
post #1 of 9 Old 09-07-2008, 07:22 PM Thread Starter
Elwood
Elwood's Avatar
2016 JK Wrangler
Oil Pump Problem??
A friend of mine in Daytona has a 97 Sahara with the 4.0 engine. Around 92k miles. She just bought it about a month ago.
She called a little bit ago and the "check guages" light came on in the cluster. Her oil pressure guage reads just barely above zero when it is running. She has checked the oil and it is full, there are no leaks anywhere. What stumps me is this: I would think that if an engine is running with very little to no oil getting on the top side, you should hear the rockers tapping. She claims it is a silent as it always is.
My first thought is oil pump failure, but the guage/sending unit could be failing as well?
Since I am 1100 miles away, obviously I am not going to be the one to fix the problem, but was wanting to see if anyone else has had this issue so she could be armed with a little bit of information so when she goes to a repair shop, she can be prepared.
Thanks!
A quote from my wife: "I don't even want to know how much it cost, I'm not in the mood to be that pissed off today."
Elwood is offline
post #2 of 9 Old 09-07-2008, 07:24 PM
carpekd
oil pressure sending units are bad to go out in the tj's...that's probably what it is.
carpekd is offline
post #3 of 9 Old 09-08-2008, 03:08 PM
Brown Dog
Vendor
Brown Dog's Avatar
Yup, that's my first guess.
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #4 of 9 Old 09-08-2008, 06:45 PM
finsout
check it with a mechanical gauge. if it has pressure it's probably the sender. if not, its a much deeper (and more expensive) problem.
finsout is offline
post #5 of 9 Old 09-08-2008, 07:22 PM
Rafikie
mine has been doing the same thing, figure it's the sending unit since at idle the pressure is way down but the sec you touch the gas it's right back to where it should be...
2000 TJ WW build in progress
RIP: 97 TJ juggy
WM4x4
Rafikie is offline
post #6 of 9 Old 09-08-2008, 07:26 PM
carpekd
Every time I've seen a sending unit go bad, the gauge either jumps erratically or doesn't work at all.
carpekd is offline
post #7 of 9 Old 09-08-2008, 07:51 PM
grinwa
grinwa's Avatar
When mine went out it pegged high.
'99 TJ
Experience is something you don't get until just after you need it.
grinwa is offline
post #8 of 9 Old 09-08-2008, 07:53 PM Thread Starter
Elwood
Elwood's Avatar
2016 JK Wrangler
Thanks for the replies!
I e-mailed her with the replies and hopefully, she will be armed with a bit of information when she see's a mechanic.
Thanks!
Elwood is offline
post #9 of 9 Old 09-08-2008, 07:56 PM
litebrite2001
OP, mine was doing the same thing. Everytime the car came to a stop the gauge would go to 0 and the check gauges light would come on. I replaced the sending unit and the problem went away. I bought the sending unit from autozone for $22. Cheaper than Advance and Oreillys. The sending unit is a cinch to replace. Its right next to the oil filter. I just used channel locks to remove it, and the new one already had thread coating on it.
litebrite2001 is offline
99 Tj Fuel Pump Problem Sgt.Redneck TJ Wrangler Technical Forum 6 07-17-2011 05:15 PM
Rubi pump problem crusher242 TJ Wrangler Technical Forum 4 04-06-2009 02:06 PM
fuel pump problem chucksworth YJ Wrangler Technical Forum 9 01-16-2009 10:55 AM
Possible Fuel Pump Problem??? Sammy Jenkins TJ Wrangler Technical Forum 1 01-17-2005 10:47 AM
gas pump problem bono426 YJ Wrangler Technical Forum 15 11-01-2004 03:45 PM
