Oil Pump Drive? - JeepForum.com
post #1 of 5 Old 02-16-2007, 03:26 PM Thread Starter
coloradojeep
Oil Pump Drive?
My 2006 unlimited started exhibiting a loud noise with a cold start. *primarily in the early morning and the outside temp at or below 20 F* It was a loud squeel loud enough to be heard in the house from outside. It would go away if you shut it off and turned it back over or if you let it warm up and drive a little *less then 2 blocks*
It tood the Jeep service department near my home almost two weeks to diagnose *We had the cold snap come and go during that time and they had a hard time replicating it* Thank goodness it made the noise for the service manager when he went to move it for us at the dealership for drop-off.
They claim the oil pump drive had been siezing *sp?* and replaced the oil pump drive gear and shaft.
My question is this...do I need to worry about any long-term damage from this in my engine and has anyone else experienced this problem as well. *It took them two weeks and I'm dissapointed to say the least*
One other piece that I am told is normal noise is to get a 'hum' for lack of technical description when moving into 2nd gear *This is a 6sp manual on 4.0 engine block* and goes away with depressing the clutch to move into 3rd gear. I am told this is 'normal for some jeeps' as it is associated with the throw out bearing. This is my first Jeep, but all other manuals that started making noise *trucks and cars* with the throwout bearing usually meant the bearing is bad or going to be if not taken care of.
Any input or thoughts would be appreciated!
Thanks!
coloradojeep is offline
post #2 of 5 Old 02-16-2007, 04:30 PM
ytodd
ytodd's Avatar
the impersonator was here too eh?
I recall something similar posted over on ROF about this and possibly a TSB being reference.
Worth checking over there if you don't get any input here.
ytodd is offline
post #3 of 5 Old 02-16-2007, 04:34 PM Thread Starter
coloradojeep
I'm kind of new around here. What's ROF? TSB...not familiar either.
Thanks!
post #4 of 5 Old 02-16-2007, 04:54 PM
ytodd
ytodd's Avatar
Thanks!
sorry....
ROF = www.rubiconownersforum.com some good tech there, and since the motor is the same in your LJ and the rubi the tech crosses over.
TSB = Technical Service Bulletin. Your dealer can research these for you or there are some places online too.
ytodd is offline
post #5 of 5 Old 02-16-2007, 07:14 PM Thread Starter
coloradojeep
sorry....
Thanks I'll check out rubi forums. I checked for TSB's but didn't find one to match on edmunds or ownersite. Is there anywhere else I can check for TSB's?
Power Steering pump leaking pink liquid - can the pump be fixed, or replaced? Sparty TJ Wrangler Technical Forum 10 01-13-2010 11:29 PM
YJ front drive spinning/posi-lock/no 4 wheel drive bdfletch YJ Wrangler Technical Forum 7 11-09-2009 11:58 PM
cps and oil pump drive rubi03 TJ Wrangler Technical Forum 0 03-13-2009 07:14 PM
Bad water pump... OK to drive? 98 Sahara TJ Wrangler Technical Forum 2 03-10-2009 07:54 AM
Oil pump drive gear hassles after recall crsmith TJ Wrangler Technical Forum 3 07-12-2005 08:35 PM
