oil psi at idle - Page 2 - JeepForum.com
post #16 of 23 Old 07-28-2010, 05:23 PM
thisgardengrove
Originally Posted by wushaw View Post
You are absolutely right Jerry and if I lived in the cold climate I would run 5w-40w Rotella Synthetic.
One needs to run what weight oil for the climate he/she lives in.
every engine is designed to operate with specific oil weights and for this case jeep recommends 5w30 for cold climates and 10w30 for hot climates, running other oil wieghts not recommended for that engine can result in damage to the engine over time blocking oil passeges and etc. Rotella oils are generally recommended for use in diesel motors, especially the 15w40 weight. Just my 2 cents
thisgardengrove is offline
post #17 of 23 Old 07-28-2010, 05:31 PM
DevilDogDoc
Well firstvof Rotella is SM rated same as Mobile 1 and all other new passenger car oils. 2nd, my rig has 140000 there is bound to he some wear in there the extra viscosity helps fill in the gaps so to speak. My hot idle pressure is good and I have no issues at all with cooling etc. 3rd maybe you didn't see at the end of my last post that 15/40 was factory fill for export TJ's that didn't have to meet CAFE standards.
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #18 of 23 Old 07-28-2010, 05:45 PM
wushaw
Rockin jeep
wushaw's Avatar
Ya ya I hear ya but I also read the lable too. Also 100k miles of using it has proved it works just fine for my application....if it doesn't then how many miles will it last with 15w-40w Rotella? 2 or 300K...I can live with that.
I have run Rotella in everything I own from lawnmowers to my 13L Cat, no complaints from any of em as of yet.....I do Know my Jeep does not like Fram oil filters though, the Jeep made four of em in a row leak...I would have given up on the first one but I had to make a proper test to make sure it was the filters.
wushaw is offline
post #19 of 23 Old 07-28-2010, 05:56 PM
Jeepzcb09
Im between 40-45 psi while driving and 30-40 PSI at idle. I run 10w-30 Castrol GTX High Milage with a Wix filter
1998 TJ Sport : Rough Country, MetalCloak,KC, Goodyear, Crager, Alpine, AtoZ, Currie, Aussie
Believe.
Jeepzcb09 is offline
post #20 of 23 Old 07-28-2010, 06:17 PM
Dryseals
1980 CJ7
FYI, the oil pressure reading is back pressure from the engine components. Once the clearances in the crank and lesser so cam bearing increases, the oil pressure will be less. But that doesn't mean the oil flow is less. Adding a heavy weight oil to correct the oil reading is like pissing in your pants, is a nice warm feeling, but it's not doing your engine any good. Flow is what you want, it will prolong the life of your engine. Using a heavier weight oil to make the gauge look good is a bad idea.
I've run many engines with low oil pressure because they were just old and worn. But all of them kept running for a long time. If your engine was new and had low pressure, then I might worry. If it has 100K, then I wouldn't worry, I would just plan for a rebuild. And run it till it dies. You'll be surprized how long it will run just fine this way. But if you want to shorten it's life, by all means, increase the viscosity. And while your smiling at the new gauge reading, go ahead and relieve your self in the drivers seat...............
Dryseals is offline
post #21 of 23 Old 07-28-2010, 06:20 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Nicely put Dryseals, that says it in a nutshell.
Jerry Bransford is offline
post #22 of 23 Old 07-28-2010, 07:25 PM
wushaw
Rockin jeep
wushaw's Avatar
Very well put. I didn't notice any oil pressure increse in mine 8 years ago when I went to 15w-40w and it still runs the same psi.
wushaw is offline
post #23 of 23 Old 07-29-2010, 09:30 PM
Skyryder
Like I stated, I started using the 15-40 to get rid of the warning chime @ low/stall RPM, and it did just that! I didn't like the bells and whistles falsely going off when there wasn't a problem. When and if the time ever comes that using that oil causes premature engine wear and failure I'll pee your paints for ya.
Skyryder
'97 Black TJ - 4 banger - 5 speed
Proud user of the "K.I.S.S." Principle.
Black Jeep Society #264
Skyryder is offline
oil pressure , idle
High idle 2k rpm, idle jumping on braking - Moab in jeopardy AndrewMuadDib TJ Wrangler Technical Forum 9 09-06-2009 10:19 AM
idle relays with no idle solenoid and replacement carb defmornahan YJ Wrangler Technical Forum 3 10-08-2008 09:24 PM
high idle - cleaned tb, now higher idle! clarkvstewart YJ Wrangler Technical Forum 7 10-05-2008 10:48 AM
Idle Air Controller - Trying to Clean for Rough Idle - Need Help JBWood05TJ TJ Wrangler Technical Forum 21 08-24-2008 06:40 AM
Dead battery, no idle, now high idle. HELP! gudoldboy TJ Wrangler Technical Forum 0 06-29-2008 02:31 PM
