oil psi at idle - JeepForum.com
post #1 of 23 Old 07-27-2010, 03:27 PM Thread Starter
ek1
oil psi at idle
Hey jeepers, I recently bought a 97 Tj 4.0, 105,000 miles. I have 6 qts of 10-30 in it. My oil pressure holds steady at about 42 when driving, but my warm idle psi drops to about 10 and bounces from there to 12 and back. This seems a bit low to me and I thought i would get your opinions.
ek1 is offline
post #2 of 23 Old 07-27-2010, 03:54 PM
demon67
sounds like a bad gauge to me
demon67 is offline
post #3 of 23 Old 07-27-2010, 05:22 PM
wushaw
Rockin jeep
wushaw's Avatar
Screw a mechanical guage in it and see what it really is.
wushaw is offline
post #4 of 23 Old 07-27-2010, 06:36 PM
madmilitia
mine does the same but at warm idle it sits at about 20
madmilitia is offline
post #5 of 23 Old 07-27-2010, 06:38 PM
makaioM3
Mines does the same when warm. I have 135,000 miles on my 4.0. I'm not too worried about it.
97 TJ 4.0 Automatic
makaioM3 is offline
post #6 of 23 Old 07-27-2010, 06:47 PM
DevilDogDoc
Well per the big book min psi at hot idle is 13. Above 1600 36-75
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #7 of 23 Old 07-27-2010, 10:49 PM Thread Starter
ek1
I also read somewhere chrysler says it can operate at 3-4 psi at idle. I'm not really comfortable with it being that low. i actually have a mechanical gage sitting in my garage. I'll hook it up and see what happens. thanks for all the input
ek1 is offline
post #8 of 23 Old 07-28-2010, 02:31 AM
conrasm
conrasm's Avatar
Mine was idling ~20 psi, and was running around 40 psi when driving. Changed the oil today and it was idling close to 40 and 50 at ~2k rpms. Used 10w-30 oil, but filter was switched from fram to purolator. Not sure if that would affect it.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #9 of 23 Old 07-28-2010, 06:36 AM
Skyryder
I didn't like the low oil pressure at idle either. I would be going slow on the trails and trying to "idle" over an obstacle and the chime would go off. I changed to 15-40 and the problems went away. BTW I have the 4 banger and yes i know that is normally diesel rig oil.
Skyryder
'97 Black TJ - 4 banger - 5 speed
Proud user of the "K.I.S.S." Principle.
Black Jeep Society #264
Skyryder is offline
post #10 of 23 Old 07-28-2010, 08:00 AM
DevilDogDoc
I'm a fan of the 15/40 myself, Rotella flavor
post #11 of 23 Old 07-28-2010, 09:20 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That sounds perfectly normal, I would not be concerned. A good rule of thumb for acceptable oil pressure is approx. 10 psi per thousand engine rpms which means it is supposed to rise and fall in step with engine rpms. On newer TJs, they reprogrammed the gauge so it doesn't do that because it was unnecessarily alarming those who grew up on idiot gauges but on earlier TJs like your '97, it works like an oil pressure gauge is supposed to.
Originally Posted by DevilDogDoc View Post
I'm a fan of the 15W-40 myself, Rotella flavor
Why would you want 15W instead of 5W or 10W when the engine is cold/cool? Running a 15W just means the oil won't flow as easily after the engine is first started when the engine and oil is cold.
Jerry Bransford is online now
post #12 of 23 Old 07-28-2010, 03:39 PM
wushaw
Rockin jeep
wushaw's Avatar
Jerry I have started my Jeep in -7deg in Kansas running 15-40 Rotella, The lifters did rattle for a moment but no problems and I have run it for 100k miles, my oil press is still just fine and it sounds & runs like it did the day I drove it off the lot 10.5 years ago....well sorta it doesn't have any driveshafts in it right now and won't for awhile but I did start it a week ago & she fired right up after 8 months of not being run.
wushaw is offline
post #13 of 23 Old 07-28-2010, 04:13 PM
Jerry Bransford
Administrator
Annecdotal stories aside, there is no doubt that 5W or 10W oil will flow throughout and thus protect the engine faster when cold than 15W will.
post #14 of 23 Old 07-28-2010, 05:01 PM
wushaw
Rockin jeep
wushaw's Avatar
You are absolutely right Jerry and if I lived in the cold climate I would run 5w-40w Rotella Synthetic.
One needs to run what weight oil for the climate he/she lives in.
wushaw is offline
post #15 of 23 Old 07-28-2010, 05:22 PM
DevilDogDoc
Because where I live I doubt that 5 is really gonna change very much in the grand scheme of things. I started running Rotella back when it was zinc rich but now it's just habit I suppose. Besides isn't that flow number at like 0 degrees or something? Aside from all that 15/40 is factory fill in export TJ's so it can't be that bad for it right?
oil pressure , idle
High idle 2k rpm, idle jumping on braking - Moab in jeopardy AndrewMuadDib TJ Wrangler Technical Forum 9 09-06-2009 10:19 AM
idle relays with no idle solenoid and replacement carb defmornahan YJ Wrangler Technical Forum 3 10-08-2008 09:24 PM
high idle - cleaned tb, now higher idle! clarkvstewart YJ Wrangler Technical Forum 7 10-05-2008 10:48 AM
Idle Air Controller - Trying to Clean for Rough Idle - Need Help JBWood05TJ TJ Wrangler Technical Forum 21 08-24-2008 06:40 AM
Dead battery, no idle, now high idle. HELP! gudoldboy TJ Wrangler Technical Forum 0 06-29-2008 02:31 PM
