Oil Pressure Issue - JeepForum.com
post #1 of 18 Old 12-03-2012, 10:34 AM Thread Starter
trakwrkr
Oil Pressure Issue
I've been reading various forums trying to come up with an answer to my oil pressure issue.
I have 2000 TJ 4.0L.
After lots of driving the oil pressure will drop to 0 and make the idiot light come on. It appears that once I change the oil the problem goes away for a little bit, but it's coming back on. The engine will stutter at a light when the pressure drops but it's fine after I get going again.
The oil is at the right level. I took it to the local Jeep dealership and they said it was fine, but I don't think they ran it long enough for the problem to come up. They said that the oil could be thinning and causing the problem. I've NEVER heard of that before. The dealer doesn't have a good rep.
I'm looking for some ideas.
trakwrkr is offline
post #2 of 18 Old 12-03-2012, 12:01 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
The gauge on the dash is not accurate at all. Mine stays pegged but I have tested with real pressure gauge and it was fine. I would test it with a better gauge, It could be your sender unit (most likely) or an oil pump if the pressure truly is low
RnEmOvr is offline
post #3 of 18 Old 12-04-2012, 11:35 AM
JBTJ
Sending unit is almost always the problem every time. I've replaced mine 3 times in 11 years.
JBTJ is offline
post #4 of 18 Old 12-04-2012, 11:39 AM
TheBoogieman
Disturbed Rubicon owner
TheBoogieman's Avatar
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
Why also would he need a rare as hen's teeth Dana 44 out of another TJ which will eventually lead to him swapping in a POS 8.8 because he can't find one?
TheBoogieman is offline
post #5 of 18 Old 12-07-2012, 02:42 PM
appfire
How many miles do you have? If its high mileage, I would think when your oil warms up its thinner and your bearings may be worn thus the drop in pressure. I have been fighting this for a year now. A can of stp oil treatment has helped alot.
Chris
All politicans are crooks. They should have to work and pay for everything like we do.
appfire is offline
post #6 of 18 Old 12-07-2012, 03:53 PM
NE4X4
My 97 did the same thing and I too installed a manual guage and the press. was fine. When I replaced the sender there was no change. Good luck.
NE4X4 is offline
post #7 of 18 Old 12-07-2012, 07:29 PM
mukluk
Does your oil smell like gasoline when you change it?
mukluk is offline
post #8 of 18 Old 12-13-2012, 07:39 PM Thread Starter
trakwrkr
Sorry guys it took so long... Finally got it to a good mechanic and it is the oil pump, now waiting to see if the bearings need to be replaced.
The engine does have 140k miles on it, and the stp treatment only helped a little bit.
My wife says I bought a POS. I say I bought a project.
This is the main thing on the laundry list to be fixed!!
trakwrkr is offline
post #9 of 18 Old 12-13-2012, 07:55 PM
MallCrawling
Oil pump bad on a 4.0 with only 140k miles on it? Guess it's possible but the oil pumps usually are the last part to go since they're so well lubricated. I would have almost guaranteed that it was the sender also. Oh well. Good luck!
-Jimmy
MallCrawling is offline
post #10 of 18 Old 12-13-2012, 10:09 PM
oakmckinley
I am on the sender boat too!
I have changed mine 3x's also on my 4.0L. Wierd enough never on my 2.5L. If you aren't on top of oil changes the sensor will get clogged with crud.
Can't hurt to change the sensor for less than $50 and see, and much easier than an oil pump.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #11 of 18 Old 12-15-2012, 08:40 AM Thread Starter
trakwrkr
Sensor was Checked, unfortunately I just bought this in the last 6 months. So I don't have the maintenance history. Luckily I come to find out the mechanic is a jeep owner!
Thanks
trakwrkr is offline
post #12 of 18 Old 12-20-2012, 11:34 AM Thread Starter
trakwrkr
Got it back from the mechanic, $750 later, and now the check engine light comes on!!
trakwrkr is offline
post #13 of 18 Old 12-20-2012, 06:12 PM
mukluk
Unless the light didn't work previously, I'd say this isn't an improvement...
mukluk is offline
post #14 of 18 Old 12-21-2012, 10:58 AM
BamaJeepman21
Was the $750 for an oil pump? Also the bearings shouldn't be going out at only 140k, unless it was lugged it's entire life.
Did the mechanic do a mechanical gauge on the sensor to make sure it wasn't the sending unit? The sending unit itself is only a $25 part. Wouldn't hurt to change it out and see.
-Jack
BamaJeepman21 is offline
post #15 of 18 Old 01-02-2013, 08:48 PM Thread Starter
trakwrkr
I have no idea, what's going on! My good deal isn't turning out to be such a good deal.
The light is now off, wondering if it was the gas I out in it. I stopped at a different place to get gas, now after a while of going to my usual place the light has gone off and stayed off.
Love Wranglers, hate mine!
trakwrkr is offline
2000 , oil pressure , tj
