Oil Pressure = 80 Bad?? - JeepForum.com
post #1 of 8 Old 12-26-2010, 01:46 PM Thread Starter
LRMark26
Is running at high oil pressure bad? What kind of damage may it cause?
My oil pressure has been reading 80psi since I changed my oil last week. Changed oil (10W-30) and Oil Filter. It is 80 as soon as I start it. After driving about 20 miles, side roads and expressway, 10mph - 65mph, it will lower to about 65psi when I slow down getting off the expressway and will go back up slightly.
I looked through the service manual and could not find anything regarding High Oil Pressure only Low. I know the pressure relief is at 75psi, obviously this is not working.
Any thoughts?
(2000 Wrangler, 4.0 Manual)
LRMark26 is offline
post #2 of 8 Old 12-26-2010, 01:58 PM
havasu
On permanent vacation
havasu's Avatar
Was your oil pressure OK before changing the oil? All I know is that jeeps are notorious for malfunctioning and poor working gauges.
havasu is offline
post #3 of 8 Old 12-26-2010, 02:02 PM Thread Starter
LRMark26
As far as I know the gauge was functioning / oil pressure was fine before the oil change. I didn't notice the pressure being at 80.
LRMark26 is offline
post #4 of 8 Old 12-26-2010, 02:04 PM
wushaw
Rockin jeep
wushaw's Avatar
Screw in a mechanical gauge and re-check.
wushaw is offline
post #5 of 8 Old 12-26-2010, 02:12 PM
havasu
havasu's Avatar
^ This is your best bet!
havasu is offline
post #6 of 8 Old 12-26-2010, 02:16 PM
lakailimited06
mine has been doing the same thing..not sure when it really started but i did change the oil 10w30 and mobile 1 filter (like usual every 3500miles) and it had no effect...it has been 20-30* here idk about florida though lol...i dont recall this happening in the summer so im just assuming its the cooler weather or the sending units bad?
once i drive around a bit the oil does drop down between 55-65 and goes back up to 75 when on the highway...sorry to hijack just watching this thread as well for help...
99WJ 4.0
IRO 3", SYE, D30 aussie/8.8 aussie, 4.10s, 33's, skids/bumpers
lakailimited06 is offline
post #7 of 8 Old 12-26-2010, 02:24 PM Thread Starter
LRMark26
The temps have been chilly here, 20's - 30's in the AM and 50's - 60's in the afternoon. The pressure is reading high in the afternoon as well.
Is hooking a mechanical gauge up easy? Still a very very fresh do it yourself'r.
LRMark26 is offline
post #8 of 8 Old 12-26-2010, 02:39 PM
wushaw
Rockin jeep
wushaw's Avatar
HF has one. All ya do is unscrew the electrical sending unit and screw in the mechanical gauge and observe the reading.
Engine Oil Pressure Test Kit
wushaw is offline
engine , high pressure , oil , oil pressure
Need some Genius! Oil Pressure Pump/Switch/Crank Bearings Replaced - Pressure Low??! malo8899 YJ Wrangler Technical Forum 1 05-20-2010 01:32 PM
Possible to convert '03-'06 oil pressure gauge to display actual oil pressure? Night Wolf TJ Wrangler Technical Forum 40 05-03-2010 10:48 AM
Oil pressure ?? once more.. Tero YJ Wrangler Technical Forum 2 05-16-2009 05:21 PM
No oil pressure 93YJNewf YJ Wrangler Technical Forum 1 06-18-2007 06:31 PM
Oil pressure phlex234 YJ Wrangler Technical Forum 11 09-17-2004 11:43 AM
